查看: 2275|回復(fù): 6
error c129:missing';'before'++'這個問題是出在哪?找了很久怎么改都不行
ID:1005923 發(fā)表于 2022-3-12 21:13 | 顯示全部樓層 |閱讀模式
ID:908826 發(fā)表于 2022-3-13 09:39 | 顯示全部樓層
把你整個工程文件發(fā)出來看看吧。
ID:776619 發(fā)表于 2022-3-13 10:26 | 顯示全部樓層
前一句大括號}后面應(yīng)加分號。
ID:1005923 發(fā)表于 2022-3-13 14:03 | 顯示全部樓層
#include<reg51.h>
/*******宏定義***********/
/******位定義************/
sbit SH_CP=P3^1;           /*移位寄存器時鐘輸入*/
sbit ST_CP=P3^3;           /*存儲寄存器時鐘輸入*/
sbit DS=P3^2;                /****串行數(shù)據(jù)輸入****/
/******變量和數(shù)組*******/
uint key;
uint timecount;
uchar cnta;
uchar cntb;
uchar code key_num[8][8]={
        0,1,2,3,4,5,6,7,
        8,9,10,11,12,13,14,15,
        16,17,18,19,20,21,22,23,
        24,25,26,27,28,29,30,31,
        32,33,34,35,36,37,38,39,
        40,41,42,43,44,45,46,47,
        48,49,50,51,52,53,54,55,
        56,57,58,59,60,61,62,63,
uchar code table[ ]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
uchar code digit_tab[10][8]={                                    /***字模 陽碼 逐列式 逆向 ***/
        {0xFF,0xC7,0xBB,0xBB,0xBB,0xBB,0xC7,0xFF},  /*"0",0*/
        {0xFF,0xB7,0xB7,0x83,0xBF,0xBF,0xFF,0xFF},    /*"1",1*/
        {0xFF,0xB7,0x9B,0x9B,0x9B,0xAB,0x93,0xFF},   /*"2",2*/
        {0xFF,0xD7,0xBB,0xB3,0xB3,0xAB,0xCB,0xFF}, /*"3",3*/
        {0xFF,0xEF,0xD7,0xDB,0x9B,0x81,0xFF,0xFF},   /*"4",4*/
        {0xFF,0xC3,0xAB,0xAB,0xAB,0xAB,0xDB,0xFF},/*"5",5*/
        {0xFF,0xC7,0xAB,0xAB,0xAB,0xAB,0xDF,0xFF},/*"6",6*/
        {0xFF,0xF3,0xFB,0x8B,0xEB,0xF3,0xFB,0xFF},   /*"7",7*/
        {0xFF,0xD3,0xAB,0xAB,0xAB,0xAB,0xD3,0xFF},/*"8",8*/
        {0xFF,0xF7,0xAB,0xAB,0xAB,0x8B,0xC7,0xFF}, /*"9",9*/
//        {0x00,0x38,0x44,0x44,0x44,0x44,0x38,0x00},/*"0",0*/
//        {0x00,0x48,0x48,0x7C,0x40,0x40,0x00,0x00},/*"1",1*/
//        {0x00,0x48,0x64,0x64,0x64,0x54,0x6C,0x00},/*"2",2*/
//        {0x00,0x28,0x44,0x4C,0x4C,0x54,0x34,0x00},/*"3",3*/
//        {0x00,0x10,0x28,0x24,0x64,0x7E,0x00,0x00},/*"4",4*/
//        {0x00,0x3C,0x54,0x54,0x54,0x54,0x24,0x00},/*"5",5*/
//        {0x00,0x38,0x54,0x54,0x54,0x54,0x20,0x00},/*"6",6*/
//        {0x00,0x0C,0x04,0x74,0x14,0x0C,0x04,0x00},/*"7",7*/
//        {0x00,0x2C,0x54,0x54,0x54,0x54,0x2C,0x00},/*"8",8*/
//        {0x00,0x08,0x54,0x54,0x54,0x74,0x38,0x00},/*"9",9*/
/**************函數(shù)定義***********************/
/*******函數(shù)名稱:Ser_IN**********************/
/*******函數(shù)描述:串行數(shù)據(jù)輸入****************/
/*******輸入?yún)?shù):Data************************/
/*******返回值    : 無**************************/
void Ser_IN(uchar Data)
        uchar i;
        for(i=0;i<8;i++)
                SH_CP=0;
                DS=Data&0x08;
                Data<<=1;
                SH_CP=1;
/*******函數(shù)名稱:Par_OUT********************/
/*******函數(shù)描述:并行數(shù)據(jù)輸出****************/
/*******輸入?yún)?shù):無**************************/
void Par_OUT()
        ST_CP=1;
        ST_CP=0;
/*******函數(shù)名稱:Timer0**********************/
/*******函數(shù)描述:T0中斷函數(shù)******************/
void Timer0(void)  interrupt 1using 0
        TH0=(65536-3000)/256;
        TL0=(65536-3000)%256;
        Ser_IN(table[cntb]);                   //列掃描//
        Ser_IN(digit_tab[cntb][cnta]);      //串行數(shù)據(jù)輸入//
        Par_OUT();                             //并行數(shù)據(jù)輸出
        cnta++;
        if(cnta==8)
                cnta=0;
        timecount++;
        if(timecount==1000)
                timecount=0;
                cntb ++;
                if(cntb==10)
                        cntb=0;
        key=key_scan();
        if(key!=-1)
                switch(key)
                        case 0:cntb=0;break;
                        case 1:cntb=1;break;
            case 2:cntb=2;break;
                  case 3:cntb=3;break;
                        case 4:cntb=4;break;
            case 5:cntb=5;break;
                  case 6:cntb=6;break;
                        case 7:cntb=7;break;
            case 8:cntb=8;break;
                  case 9:cntb=9;break;
                        case 10:cntb=10;break;
/*******函數(shù)名稱:key_scan*********************/
/*******函數(shù)描述:鍵盤掃描********************/
/*******返回值    :  鍵值************************/
int key_scan()
         uint i,j;
         for(i=0;i<8;i++)
                P0=table[i];
                if(P2!=0xff)
                        delayms(2);
                        if(P2!=0xff)
                                 for(j=0;j<8;j++)
                                        if(P2==table[j])
                                                return key_num[i][j];
                        return -1;
/*******函數(shù)名稱:delayms**********************/
/*******函數(shù)描述:延時函數(shù)********************/
/*******輸入?yún)?shù):uint m***********************/
/*******返回值    :無***************************/
void delayms(uint m);
        uint i,j;
        for(i=0;i<m;i++)
                for(j=0;j<125;j++);
/*******函數(shù)名稱:main************************/
/*******函數(shù)描述:主函數(shù)**********************/
        TMOD=0x01;
        TR0=1;
        ET0=1;
        EA=1;
ID:1005923 發(fā)表于 2022-3-13 14:18 | 顯示全部樓層
13205495918 發(fā)表于 2022-3-13 09:39
把你整個工程文件發(fā)出來看看吧。
整個工程文件都在壓縮包里了
keil.rar
6.48 KB, 下載次數(shù): 3
ID:155507 發(fā)表于 2022-3-14 10:28 | 顯示全部樓層
給你改了,對比一下就知道哪里錯了。
  1. #include <reg51.h>
  2. #include <intrins.h>
  3. /*******宏定義***********/
  4. #define uint unsigned int
  5. #define uchar unsigned char
  6. /******位定義************/
  7. sbit SH_CP=P3^1;           /*移位寄存器時鐘輸入*/
  8. sbit ST_CP=P3^3;           /*存儲寄存器時鐘輸入*/
  9. sbit DS=P3^2;                /****串行數(shù)據(jù)輸入****/
  10. /******變量和數(shù)組*******/
  11. uint key;
  12. uint timecount;
  13. uchar cnta;
  14. uchar cntb;
  15. int key_scan(void);
  16. void delayms(uint m);
  17. uchar code key_num[8][8]={
  18.         0,1,2,3,4,5,6,7,
  19.         8,9,10,11,12,13,14,15,
  20.         16,17,18,19,20,21,22,23,
  21.         24,25,26,27,28,29,30,31,
  22.         32,33,34,35,36,37,38,39,
  23.         40,41,42,43,44,45,46,47,
  24.         48,49,50,51,52,53,54,55,
  25.         56,57,58,59,60,61,62,63,
  26. };//;// <--------------中文符號
  27. uchar code table[ ]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  28. uchar code digit_tab[10][8]={                                    /***字模 陽碼 逐列式 逆向 ***/
  29.         {0xFF,0xC7,0xBB,0xBB,0xBB,0xBB,0xC7,0xFF},  /*"0",0*/
  30.         {0xFF,0xB7,0xB7,0x83,0xBF,0xBF,0xFF,0xFF},    /*"1",1*/
  31.         {0xFF,0xB7,0x9B,0x9B,0x9B,0xAB,0x93,0xFF},   /*"2",2*/
  32.         {0xFF,0xD7,0xBB,0xB3,0xB3,0xAB,0xCB,0xFF}, /*"3",3*/
  33.         {0xFF,0xEF,0xD7,0xDB,0x9B,0x81,0xFF,0xFF},   /*"4",4*/
  34.         {0xFF,0xC3,0xAB,0xAB,0xAB,0xAB,0xDB,0xFF},/*"5",5*/
  35.         {0xFF,0xC7,0xAB,0xAB,0xAB,0xAB,0xDF,0xFF},/*"6",6*/
  36.         {0xFF,0xF3,0xFB,0x8B,0xEB,0xF3,0xFB,0xFF},   /*"7",7*/
  37.         {0xFF,0xD3,0xAB,0xAB,0xAB,0xAB,0xD3,0xFF},/*"8",8*/
  38.         {0xFF,0xF7,0xAB,0xAB,0xAB,0x8B,0xC7,0xFF}, /*"9",9*/
  39.         //        {0x00,0x38,0x44,0x44,0x44,0x44,0x38,0x00},/*"0",0*/
  40.         //        {0x00,0x48,0x48,0x7C,0x40,0x40,0x00,0x00},/*"1",1*/
  41.         //        {0x00,0x48,0x64,0x64,0x64,0x54,0x6C,0x00},/*"2",2*/
  42.         //        {0x00,0x28,0x44,0x4C,0x4C,0x54,0x34,0x00},/*"3",3*/
  43.         //        {0x00,0x10,0x28,0x24,0x64,0x7E,0x00,0x00},/*"4",4*/
  44.         //        {0x00,0x3C,0x54,0x54,0x54,0x54,0x24,0x00},/*"5",5*/
  45.         //        {0x00,0x38,0x54,0x54,0x54,0x54,0x20,0x00},/*"6",6*/
  46.         //        {0x00,0x0C,0x04,0x74,0x14,0x0C,0x04,0x00},/*"7",7*/
  47.         //        {0x00,0x2C,0x54,0x54,0x54,0x54,0x2C,0x00},/*"8",8*/
  48.         //        {0x00,0x08,0x54,0x54,0x54,0x74,0x38,0x00},/*"9",9*/
  49. };
  50. /**************函數(shù)定義***********************/
  51. /*********************************************/
  52. /*******函數(shù)名稱:Ser_IN**********************/
  53. /*******函數(shù)描述:串行數(shù)據(jù)輸入****************/
  54. /*******輸入?yún)?shù):Data************************/
  55. /*******返回值    : 無**************************/
  56. /*********************************************/
  57. void Ser_IN(uchar Data)
  58. {
  59.         uchar i;
  60.         for(i=0;i<8;i++)
  61.         {
  62.                 SH_CP=0;//;//<-----------------中文符號
  63.                 DS=Data&0x08;
  64.                 Data<<=1;
  65.                 SH_CP=1;
  66.                 _nop_();
  67.         }
  68. }
  69. /*********************************************/
  70. /*******函數(shù)名稱:Par_OUT********************/
  71. /*******函數(shù)描述:并行數(shù)據(jù)輸出****************/
  72. /*******輸入?yún)?shù):無**************************/
  73. /*******返回值    :  無**************************/
  74. /*********************************************/
  75. void Par_OUT()
  76. {
  77.         ST_CP=1;
  78.         _nop_( );
  79.         _nop_( );
  80.         ST_CP=0;
  81. }
  82. /*********************************************/
  83. /*******函數(shù)名稱:Timer0**********************/
  84. /*******函數(shù)描述:T0中斷函數(shù)******************/
  85. /*******輸入?yún)?shù):無**************************/
  86. /*******返回值    :  無**************************/
  87. /*********************************************/
  88. void Timer0(void)  interrupt 1 using 0 //<--------這里不對
  89. {
  90.         TH0=(65536-1000)/256;              //12MHZ晶振定時時間為1ms
  91.         TL0=(65536-1000)%256;
  92.         Ser_IN(table[cntb]);                   //列掃描//
  93.         Ser_IN(digit_tab[cntb][cnta]);      //串行數(shù)據(jù)輸入//
  94.         Par_OUT();                             //并行數(shù)據(jù)輸出
  95.         cnta++;
  96.         if(cnta==8)
  97.         {
  98.                 cnta=0;
  99.         } ;
  100.
  101.         timecount++;
  102.         if(timecount==1000)
  103.         {
  104.                 timecount=0;
  105.                 cntb ++;
  106.                 if(cntb==10)
  107.                 {
  108.                         cntb=0;
  109.                 }
  110.         }
  111.         key=key_scan();
  112.         if(key!=-1)
  113.         {
  114.                 switch(key)
  115.                 { //<-------這里少了
  116.                 case 0:cntb=0;break;
  117.                 case 1:cntb=1;break;
  118.                 case 2:cntb=2;break;
  119.                 case 3:cntb=3;break;
  120.                 case 4:cntb=4;break;
  121.                 case 5:cntb=5;break;
  122.                 case 6:cntb=6;break;
  123.                 case 7:cntb=7;break;
  124.                 case 8:cntb=8;break;
  125.                 case 9:cntb=9;break;
  126.                 case 10:cntb=10;break;
  127.                 }
  128.         }
  129. }        //<--------這里少了
  130. /*********************************************/
  131. /*******函數(shù)名稱:key_scan*********************/
  132. /*******函數(shù)描述:鍵盤掃描********************/
  133. /*******輸入?yún)?shù):無**************************/
  134. /*******返回值    :  鍵值************************/
  135. /*********************************************/
  136. int key_scan()
  137. {
  138.         uint i,j;
  139.         for(i=0;i<8;i++)
  140.         {
  141.                 P0=table[i];
  142.                 if(P2!=0xff)
  143.                 {
  144.                         delayms(2);
  145.                         if(P2!=0xff)
  146.                         {
  147.                                 for(j=0;j<8;j++)
  148.                                 {
  149.                                         if(P2==table[j])
  150.                                         return key_num[i][j];
  151.                                 }
  152.                         }
  153.                 }
  154.                 else
  155.                 return -1;
  156.         }
  157.         return -1; //<---------要加這個
  158. }
  159. /*********************************************/
  160. /*******函數(shù)名稱:delayms**********************/
  161. /*******函數(shù)描述:延時函數(shù)********************/
  162. /*******輸入?yún)?shù):uint m***********************/
  163. /*******返回值    :無***************************/
  164. /*********************************************/
  165. void delayms(uint m) //; <------------不用加
  166. {
  167.         uint i,j;
  168.         for(i=0;i<m;i++)
  169.             for(j=0;j<125;j++);
  170. }
  171. /*********************************************/
  172. /*******函數(shù)名稱:main************************/
  173. /*******函數(shù)描述:主函數(shù)**********************/
  174. /*******輸入?yún)?shù):無**************************/
  175. /*******返回值    :無***************************/
  176. /*********************************************/
  177. void main()
  178. {
  179.         TMOD=0x01;
  180.         TH0=(65536-1000)/256;
  181.         TL0=(65536-1000)%256;
  182.         TR0=1;
  183.         ET0=1;
  184.         EA=1;
  185.         while(1)
  186.         {
  187.                 ;
  188.         }
  189. }
ID:978751 發(fā)表于 2022-3-20 13:00 | 顯示全部樓層
IF和IF之間不能有其它語句隔開,你把COUNT++;移到底下就行了.
