uid:162554 日志
倒計(jì)時(shí)C程序
已有 614 次閱讀2017-6-28 15:22
#include <reg52.h>
#include <intrins.h>
#define uint  unsigned int
uint countb=0,counta=0;                // counta 為10ms計(jì)數(shù)器,countb為1s計(jì)數(shù)器,均為全局變量
sbit s1 = P2^0;
sbit s2 = P2^1;
sbit s3 = P2^2;
sbit s4 = P2^3;
sbit en = P2^5;
sbit speaker = P2^4;
sbit k1=P3^2;
sbit k2=P3^3;
uchar a1,a2,b1,b2;
code ledseg7[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};           //0~9不帶小數(shù)點(diǎn)的段碼表
            //   0    1    2    3    4    5    6    7    8    9
code ledseg8[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};
            //   0    1    2    3    4    5    6    7    8    9            //0~9帶小數(shù)點(diǎn)的段碼表
/********延時(shí)函數(shù)********/
void Delay(uint xms)              //延時(shí)程序,xms是形式參數(shù)
        uint i,j;
        for(i=xms;i>0;i--)
        for(j=100;j>0;j--);                //此處分號(hào)不可少
/*******顯示函數(shù)********/
void display(uchar a,uchar b,uchar c,uchar d)
        en = 1;           //啟用數(shù)碼管信號(hào)
        s1 = 0;
        P0 = ledseg7[a];
        Delay(5);
        s1 = 1;
        s2 = 0;
        P0 = ledseg8[b];
        Delay(5);
        s2 = 1;
        s3 = 0;
        P0 = ledseg7[c];
        Delay(5);
        s3 = 1;
        s4 = 0;
        P0 = ledseg7[d];
        Delay(5);
        s4 = 1;
/********重置,暫停設(shè)置******/
void key()
        if(k1==0)         //開始,暫停
        Delay(10);
                   if(k1==0)
                     while(!k1);
                         TR0=~TR0;
        if(k2==0)          //復(fù)位
           Delay(10);
           if(k2==0)
            TH0=0xDC; TL0=0x00;
        countb=0;
                counta=0;
        TR0=0;
        while(k2!=0);
/********定時(shí)器T0中斷函數(shù)*******/
void timer0() interrupt  1
        TH0=0xDC;TL0=0x00;
        counta++;                            //計(jì)數(shù)值加1
          if(counta==100)                //若counta為99,(100*10ms=1s)
                  counta=0;                        // counta清0
                countb++;
        if(countb==30)
                TR0=0;
                s3=1;
                counta=0,countb=0;
                speaker=0;
                Delay(500);
                speaker=1;
                Delay(500);
                speaker=0;
                Delay(500);
                speaker=1;
        P0=0xff;
           TMOD=0x01;                         //定時(shí)器T0方式1
           TH0=0xDC; TL0=0x00;              //10ms定時(shí)初值
        TR0=0;
           EA=1;
           ET0=1;         //開總中斷,開定時(shí)器T0中斷,啟動(dòng)定時(shí)器T0
            key();
                b2=countb/10;      //取出記數(shù)秒數(shù)的十位
                   b1=countb%10;      //取出計(jì)數(shù)秒的個(gè)位
                a2=counta/10;      //取出記數(shù)百分秒數(shù)的十位
                   a1=counta%10;             //取出計(jì)數(shù)百分秒的個(gè)位
                   display(b2,b1,a2,a1);  //調(diào)顯示函數(shù)
路過(guò)
雞蛋
鮮花
握手
雷人
全部作者的其他最新日志
評(píng)論 (0 個(gè)評(píng)論)
返回頂部
