立即注冊 登錄
返回首頁
uid:196768的個人空間
日志
基于51單片機的電子節(jié)拍器設(shè)計
已有 2156 次閱讀2017-5-5 08:05 |個人分類:51| 單片機, 節(jié)拍器, 電子
[文件名]  C51音樂程序(八月桂花)
[功能]    通過單片機演奏音樂
#include <REG52.H>
#include <INTRINS.H>
//本例采用89C52, 晶振為11.0592MHZ
//關(guān)于如何編制音樂代碼, 其實十分簡單,各位可以看以下代碼.
//頻率常數(shù)即音樂術(shù)語中的音調(diào),而節(jié)拍常數(shù)即音樂術(shù)語中的多少拍;
//所以拿出譜子, 試探編吧!
//定義各個低音頻率
#define Low_1 262
#define Low_2 294
#define Low_3 330
#define Low_4 349
#define Low_5 392
#define Low_6 440
#define Low_7 494
#define Mid_1 523
#define Mid_2 587
#define Mid_3 659
#define Mid_4 698
#define Mid_5 784
#define Mid_6 880
#define Mid_7 988
#define High_1 1046
#define High_2 1175
#define High_3 1318
#define High_4 1397
#define High_5 1568
#define High_6 1760
#define High_7 1976
sbit Beep =  P1^5 ;
sbit StopSpeaker =  P2^7 ;//鄒靜 Add 靜機狀態(tài)檢查所用端口
unsigned char n=0;  //n為節(jié)拍常數(shù)變量
unsigned char code music_tab[] ={
0x18, 0x30, 0x1C , 0x10, //格式為: 頻率常數(shù), 節(jié)拍常數(shù), 頻率常數(shù), 節(jié)拍常數(shù),
0x20, 0x40, 0x1C , 0x10,
0x18, 0x10, 0x20 , 0x10,
0x1C, 0x10, 0x18 , 0x40,
0x1C, 0x20, 0x20 , 0x20,
0x1C, 0x20, 0x18 , 0x20,
0x20, 0x80, 0xFF , 0x20,
0x30, 0x1C, 0x10 , 0x18,
0x20, 0x15, 0x20 , 0x1C,
0x20, 0x20, 0x20 , 0x26,
0x40, 0x20, 0x20 , 0x2B,
0x20, 0x26, 0x20 , 0x20,
0x20, 0x30, 0x80 , 0xFF,
0x20, 0x20, 0x1C , 0x10,
0x18, 0x10, 0x20 , 0x20,
0x26, 0x20, 0x2B , 0x20,
0x30, 0x20, 0x2B , 0x40,
0x20, 0x30, 0x1C , 0x10,
0x18, 0x20, 0x15 , 0x20,
0x26, 0x40, 0x20 , 0x20,
0x2B, 0x20, 0x26 , 0x20,
0x20, 0x20, 0x30 , 0x80,
0x20, 0x10, 0x1C , 0x10,
0x20, 0x20, 0x26 , 0x20,
0x2B, 0x20, 0x30 , 0x20,
0x2B, 0x40, 0x20 , 0x15,
0x1F, 0x05, 0x20 , 0x10,
0x1C, 0x10, 0x20 , 0x20,
0x20, 0x20, 0x30 , 0x30,
0x18, 0x40, 0x1C , 0x20,
0x20, 0x20, 0x26 , 0x40,
0x13, 0x60, 0x18 , 0x20,
0x15, 0x40, 0x13 , 0x40,
0x18, 0x80, 0x00
unsigned int code ShengRiCode[]={ Low_5,Low_5,Low_6,Low_5,Mid_1,Low_7,
 Low_5,Low_5,Low_6,Low_5,Mid_2,Mid_1,
 Low_5,Low_5,Mid_5,Mid_3,Mid_1,Low_7,Low_6,
 Mid_4,Mid_4,Mid_3,Mid_1,Mid_2,Mid_1,
 0xff
}; //Happy Brisday
unsigned int code ShengRiJP[]={0x96,0x36,0x36,0x02,0x02,0x04,0x04,
  0x04,0x08,
  0x04,0x08,
  0x04,0x04,0x04,
  0x03,0x01,0x04,0x04,
  0x04,0x08
void int0()  interrupt 1   //采用中斷0 控制節(jié)拍
{  TH0=0xd8;
   TL0=0xef;
   n--;
void delay (unsigned char m)   //控制頻率延時
 unsigned i=3*m;  //頻率延時時間3m
 while(--i);
void delayms(unsigned char a)  //豪秒延時子程序
  while(--a);                  //采用while(--a) 不要采用while(a--); 各位可編譯一下看看匯編結(jié)果就知道了!
void StopStatus()
unsigned char m,n;
n=0;
TR0=0; //關(guān)定時器1
for(m=0;m<1500;m++) //靜機時間
if(StopSpeaker==0) //低電平唱
n=1;//正常狀態(tài)
TR0=1; //開定時器
break;
else //高電平,靜機狀態(tài)轉(zhuǎn)換的延時時間
delay(1);
if(n==0)   //高電平不唱n依然為0,即不響,進入靜機狀態(tài)
Beep=0;  //蜂鳴器端口為0,不響
{ unsigned char p,m;   //m為頻率常數(shù)變量
  unsigned char i=0;
  TMOD&=0x0f;
  TMOD|=0x01;
  TH0=0xd8;TL0=0xef;
  IE=0x82;
play:
    a: p=music_tab[i];
       if(p==0x00)       { i=0, delayms(1000); goto play;}     //如果碰到結(jié)束符,延時1秒,回到開始再來一遍
       //else if(p==0xff)  { i=i+1;delayms(100),TR0=0; goto a;}  //若碰到休止符,延時100ms,繼續(xù)取下一音符
  else if(StopSpeaker==1)  { StopStatus();delay(1);} //高電平進入靜機狀態(tài),延時100ms,繼續(xù)取下一音符
           // else    {m=ShengRiCode[i++], n=music_tab[i++];}  //取頻率常數(shù) 和 節(jié)拍常數(shù)
  else    {m=ShengRiCode[i++], n=ShengRiJP[2];}  //取頻率常數(shù) 和 節(jié)拍常數(shù)
             TR0=1;                                             //開定時器1
           while(n!=0) Beep=~Beep,delay(m);                         //等待節(jié)拍完成, 通過P1口輸出音頻(可多聲道哦!)
路過
雞蛋
鮮花
握手
雷人
評論 (0 個評論)
返回頂部
