#define L_max 200
#define L_min 150
#define L_a 0.5
#define filter_init 10
#define L_t 20
byte val = 0x00; //調(diào)節(jié)與控制命令字
int i, LoopCount = 0; //平衡點(diǎn)調(diào)整,PID各調(diào)整設(shè)定系數(shù)
int E_0 = 0, E_1 = 0, PWM_Out, Left_PWM, Right_PWM; //誤差,PWM輸出,左右電機(jī)PWM輸出
double Kp = 0.0, Kd = 0.0; //PID系數(shù)
double Len_filter = 0, Len_0 = 180; //測(cè)距濾波,機(jī)械平衡距離
unsigned int TrigPin = 4, EchoPin = 5, Len_Echo = 0; //HC-SR04觸發(fā)信號(hào),回波檢測(cè),回波時(shí)間
unsigned int M_IN1 = 6, M_IN2 = 7, M_IN3 = 8, M_IN4 = 9; // L298:IN1-IN4
unsigned int M_ENA = 10, M_ENB = 11; // L298:ENA-ENB
unsigned long systime0; //系統(tǒng)時(shí)間
//電機(jī)輸出
void SetMotorVoltage(int Left_MotorVol, int Right_MotorVol) {
if(Left_MotorVol >= 0) {
digitalWrite(M_IN1, LOW);
digitalWrite(M_IN2, HIGH);
}else {
digitalWrite(M_IN1, HIGH);
digitalWrite(M_IN2, LOW);
Left_MotorVol = -Left_MotorVol;
if(Right_MotorVol >= 0) {
digitalWrite(M_IN3, LOW);
digitalWrite(M_IN4, HIGH);
}else {
digitalWrite(M_IN3, HIGH);
digitalWrite(M_IN4, LOW);
Right_MotorVol = -Right_MotorVol;
if(Left_MotorVol > 255) Left_MotorVol = 255; //防止PWM值超過(guò)255
if(Right_MotorVol > 255) Right_MotorVol = 255; //防止PWM值超過(guò)255
analogWrite(M_ENA, Left_MotorVol);
analogWrite(M_ENB, Right_MotorVol);
//初始化
void setup() {
Serial.begin(115200);
pinMode(M_ENA, OUTPUT); //電機(jī)控制
pinMode(M_IN1, OUTPUT);
pinMode(M_IN2, OUTPUT);
pinMode(M_ENB, OUTPUT);
pinMode(M_IN3, OUTPUT);
pinMode(M_IN4, OUTPUT);
pinMode(EchoPin, INPUT); //超聲波測(cè)距
pinMode(TrigPin, OUTPUT);
digitalWrite(TrigPin, LOW);
i = 0;
systime0 = millis();
//主循環(huán)程序
void loop() {
if(millis() - systime0 >= L_t) {
digitalWrite(TrigPin, HIGH); //發(fā)送超聲波測(cè)量觸發(fā)脈沖
delayMicroseconds(15);
Len_Echo = pulseIn(EchoPin, HIGH); //回波時(shí)間測(cè)量
if((Len_Echo < L_max) && (Len_Echo > L_min)) {
Len_filter *= L_a; //一階濾波
Len_filter += (1 - L_a) * Len_Echo;
i ++;
if(i > filter_init){
i = 100;
LoopCount ++;
E_0 = Len_0 - Len_filter;
PWM_Out = Kp * E_0 + Kd * (E_0 - E_1);
E_1 = E_0;
Left_PWM = PWM_Out;
Right_PWM = PWM_Out;
SetMotorVoltage(Left_PWM, Right_PWM);
}else {
SetMotorVoltage(0, 0); //超出平衡范圍,停止PWM輸出
i = 0; Len_filter = 0;
//處理串口指令,發(fā)送相應(yīng)數(shù)據(jù)
if (Serial.available() > 0) {
val = Serial.read();
//參數(shù)調(diào)節(jié)
if(val == 0x01) Kp += 0.01;
if(val == 0x02) Kp -= 0.01;
if(val == 0x03) Kd += 0.01;
if(val == 0x04) Kd -= 0.01;
if(val == 0x05) Len_0 ++;
if(val == 0x06) Len_0 --;
if(val == 0x07) {
Serial.print(Len_0); Serial.print(" ");
Serial.print(Kp); Serial.print(" "); Serial.println(Kd); //查看設(shè)置參數(shù)
if(val == 0x08) {
Serial.print(Len_filter); Serial.print(" "); Serial.println(PWM_Out); //
