uid:208491 日志
PC控制程序
已有 515 次閱讀2017-6-6 20:35
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
//以上幾句是自動(dòng)生成的
using System.IO.Ports;//我加的,包含串口相關(guān)的
using System.Text.RegularExpressions;//我加的
namespace WindowsFormsApplication1
    public partial class PCZigbeeLed : Form
        private SerialPort comm = new SerialPort();//我加的,新建一個(gè)串口變量
        private bool closing = false;//是否正在關(guān)閉串口,執(zhí)行Application.DoEvents,并阻止再次invoke
        private bool Listening = false;//是否沒(méi)有執(zhí)行完invoke相關(guān)操作
        public PCZigbeeLed()//自動(dòng)生成的函數(shù)
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            string[] ports = SerialPort.GetPortNames();
            Array.Sort(ports);
            comboPortName.Items.AddRange(ports);
            comboPortName.SelectedIndex = comboPortName.Items.Count > 0 ? 0 : -1;
            //初始化SerialPort對(duì)象
            comm.NewLine = "/r/n";
            comm.RtsEnable = true;//根據(jù)實(shí)際情況吧。
            //comm.DataReceived += comm_DataReceived;
    private void comboPortName_SelectedIndexChanged(object sender, EventArgs e)
        private void buttonOpenClosecom_Click(object sender, EventArgs e)
            //根據(jù)當(dāng)前串口對(duì)象,來(lái)判斷操作
            if (comm.IsOpen)
                closing = true;
                while (Listening) Application.DoEvents();
                //打開(kāi)時(shí)點(diǎn)擊,則關(guān)閉串口
                comm.Close();
                //this.timer1.Stop();
                closing = false;
                //關(guān)閉時(shí)點(diǎn)擊,則設(shè)置好端口,波特率后打開(kāi)
                comm.PortName = comboPortName.Text;
                comm.BaudRate = 9600;
                try
                    comm.Open();
                catch (Exception ex)
                    //捕獲到異常信息,創(chuàng)建一個(gè)新的comm對(duì)象,之前的不能用了。
                    //現(xiàn)實(shí)異常信息給客戶(hù)。
                    MessageBox.Show(ex.Message);
            //設(shè)置按鈕的狀態(tài)
            buttonOpenClosecom.Text = comm.IsOpen ? "關(guān)閉串口" : "打開(kāi)串口";
        private void buttonOpenLight_Click(object sender, EventArgs e)
            byte[] SendBuf = new byte[2];
            SendBuf[0] = 0x31;
            SendBuf[1] = 0x31;
            comm.Write(SendBuf, 0, 2);
            System.Threading.Thread.Sleep(100);
        private void buttonCloseLight_Click(object sender, EventArgs e)
            SendBuf[0] = 0x31;
            SendBuf[1] = 0x30;
路過(guò)
雞蛋
鮮花
握手
雷人
評(píng)論 (0 個(gè)評(píng)論)
返回頂部
