立即注冊 登錄
返回首頁
uid:254444的個人空間
日志
基于51單片機的rlc測量儀的程序
熱度 1已有 1910 次閱讀2017-11-27 23:03
程序2:電阻、電容和電感測量值的顯示
//簡易電阻、電容、電感測量儀程序
//初始化
#include <reg52.h>
#define ulong unsigned long
#define    PI 3.1415926
uchar code table1[8]="Welcome!";
uchar table2[16]="f(Hz)=";
uchar table3[16]="R(Ohm)=";
uchar table4[16]="C(pF)=";
uchar table5[16]="L(uH)=";
uchar num,a=0,th0,tl0;
uint C,L;
ulong f,R;
sbit lcden=P2^4;                         //液晶使能端
sbit lcdrs=P2^5;                        //液晶數(shù)據(jù)命令選擇端
sbit key_R=P1^5;                      //測量電阻按鍵
sbit key_C=P1^6;                      //測量電容按鍵
sbit key_L=P1^7;                      //測量電感按鍵
sbit R_out=P1^2;                        //測量電阻信號輸入
sbit C_out=P1^3;                        //測量電容信號輸入
sbit L_out=P1^4;                        //測量電感信號輸入
//聲明子函數(shù)
void delayms(uint xms);               //延時函數(shù)
void write_com(uchar com);        //液晶寫命令函數(shù)
void write_data(uchar date);         //液晶寫數(shù)據(jù)函數(shù)
void led_init();                            //液晶初始化函數(shù)
void t_init();                               //定時器0初始化函數(shù)
void keyscan();                            //鍵盤檢測函數(shù)(確定被測元件為電阻、電容或電感)
void display_f(ulong f);              //頻率顯示函數(shù)
void display_R(ulong R);             //電阻顯示函數(shù)
void display_C(uint C);              //電容顯示函數(shù)
void display_L(uint L);               //電感顯示函數(shù)
//主函數(shù)
  led_init();
  t_init();
  keyscan();
  write_com(0x01);
       display_f(f);
       switch(a)
         case 1:R=(ulong)(5000000.0/0.6931472/f-150+0.5);display_R(R);break;
         case 2:C=(int)(100000000.0/153/0.6931472/f+0.5);display_C(C);break;
         case 3:L=(int)(1000000000000.0/0.1/PI/PI/f/f+0.5);display_L(L);break;
//中斷函數(shù)
void T0_count() interrupt 1
  switch(a)
   case 1:while(R_out);
              while(!R_out);
                TH0=0;
                TL0=0;
                while(R_out);
                while(!R_out);
                th0=TH0;
                tl0=TL0;
                TR0=0;
                break;
   case 2:while(C_out);
              while(!C_out);
                TH0=0;
                TL0=0;
                while(C_out);
                while(!C_out);
                th0=TH0;
                tl0=TL0;
                TR0=0;
                break;
       case 3:while(L_out);
              while(!L_out);
                TH0=0;
                TL0=0;
                while(L_out);
                while(!L_out);
                th0=TH0;
                tl0=TL0;
                TR0=0;
                break;
   f=1000000.0/1.085069/(th0*256+tl0)+0.5;
//延時函數(shù)
  uint i,j;
  for(i=xms;i>0;i--)
       for(j=110;j>0;j--);
//液晶寫命令函數(shù)
  lcdrs=0;
  P0=com;
  delayms(5);
  lcden=1;
  delayms(5);
  lcden=0;
  lcdrs=1;
  P0=date;
  delayms(5);
  lcden=1;
  delayms(5);
  lcden=0;
//液晶初始化函數(shù)
void led_init()
  lcden=0;
  write_com(0x38);                    //設(shè)置16×2顯示,5×7點陣,8位數(shù)據(jù)接口
  write_com(0x0c);                    //設(shè)置開顯示,不顯示光標(biāo)
  write_com(0x06);                    //寫一個字符后地址指針加1
  write_com(0x01);                    //顯示清0,數(shù)據(jù)指針清0
  write_com(0x80);                    //顯示歡迎界面
  for(num=0;num<8;num++)
        write_data(table1[num]);
        delayms(5);
//定時器0初始化函數(shù)
void t_init()
  TMOD=0x01;                         //設(shè)置定時器0工作方式1(M1M0=0x0001)
  TH0=0;                                  //裝初值
  TL0=0;
  EA=1;                                    //開總中斷
  ET0=1;                                   //開定時器0中斷
  TR0=1;                                   //啟動定時器0
void keyscan()
  if(key_R==0)
       delayms(10);
       if(key_R==0)
         a=1;
    if(key_C==0)
         delayms(10);
         if(key_C==0)
           a=2;
      if(key_L==0)
           delayms(10);
           if(key_L==0)
             a=3;
              while(key_R&&key_C&&key_L);              //按鍵按下時退出死循環(huán)
//頻率顯示函數(shù)
  uchar count=0;
  ulong f0;
  f0=f;
  while(f)
        f=f/10;
        count++;
  for(num=5+count;num>5;num--)
      table2[num]=f0%10+48;
       f0=f0/10;
  write_com(0x80);
  for(num=0;num<6+count;num++)
       write_data(table2[num]);
       delayms(5);
//電阻顯示函數(shù)
  uchar count=0;
  ulong R0;
  R0=R;
  while(R)
        R=R/10;
        count++;
  for(num=6+count;num>6;num--)
      table3[num]=R0%10+48;
       R0=R0/10;
  write_com(0x80+0x40);
  for(num=0;num<7+count;num++)
       write_data(table3[num]);
       delayms(5);
//電容顯示函數(shù)
  uchar count=0;
  uint C0;
  C0=C;
  while(C)
        C=C/10;
        count++;
      table4[num]=C0%10+48;
       C0=C0/10;
       write_data(table4[num]);
       delayms(5);
//電感顯示函數(shù)
  uchar count=0;
  uint L0;
  L0=L;
  while(L)
        L=L/10;
        count++;
      table5[num]=L0%10+48;
       L0=L0/10;
       write_data(table5[num]);
       delayms(5);
路過
雞蛋
鮮花
握手
雷人
發(fā)表評論 評論 (2 個評論)
回復(fù) 哈哈哈哈慕 2019-8-9 20:26
有沒有原理圖啊
您能給個原理圖嗎?
返回頂部
