立即注冊(cè) 登錄
返回首頁(yè)
uid:434819的個(gè)人空間
日志
HC-SR04超聲波測(cè)距
已有 854 次閱讀2018-11-30 15:46 |個(gè)人分類:hc sr04
#include <reg51.h>
#define ulong unsigned long
extern void cs_t(void);
extern void delay(uint);
extern void display(uchar*);
//data uchar display(uchar*);
data uchar testok;
void main (void)
data uchar dispram[5];
data uint i;
data ulong time;
P0=0xff;
P2=0xff;
TMOD=0x11;
IE=0x80;
while (1)
 cs_t();
 delay(1);
testok=0;
EX0=1;
ET0=1;
while(! testok) display(dispram);
if (1==testok)
   time=TH0;
   time=(time<<8)| TL0;
   time*=172;
   time/=10000;
   dispram[0]=(uchar) (time%10);
   time/=10;
   dispram[1]=(uchar) (time%10);
   time/=10;
   dispram[2]=(uchar) (time%10);
   dispram[3]=(uchar) (time/10);
   if (0==dispram[3]) dispram[3]=17;
   } else
   dispram [0]=16;
   dispram [1]=16;
   dispram [2]=16;
   dispram [3]=16;
 for (i=0;i<300;i++) display(dispram);
void cs_r(void) interrupt 0
 TR0=0;
 ET0=0;
 EX0=0;
 testok=1;
void overtime(void) interrupt 1
 EX0=0;
 TR0=0;
 ET0=0;
 testok=2;
                     NAME      CS_T
?PR?CS_T?CS_T         SEGMENT   CODE
                     PUBLIC   CS_T
                             RSEG     ?PR?CS_T?CS_T
CS_T:                PUSH      ACC
                     MOV       TH0, #00H
                     MOV       TL0, #00H
                     MOV       A, #4D
                     SETB       TR0
CS_T1:               CPL        p1.0
                     NOP
                                  NOP
                                  NOP
                     NOP
                     NOP
                     NOP
                     NOP
                     NOP
                     NOP
                     NOP
                     DJNZ       ACC,CS_T1
                     POP        ACC
                     RET
                     END
 name   delay
?pr?_delay?delay   segment   code
public   _delay
 rseg    ?pr?_delay?delay
_delay:    push   acc
           mov a,r7
           jz   dela1
           inc   r6
dela1:   mov   r5,#50d
         djnz   r5, $
         djnz   r7,dela1
         djnz    r6,dela1
            pop   acc
           ret
end
    NAME  DISPLAY
?PR?_DISPLAY?display   segment  code
?co?_DISPLAY?display    segment  data
                        EXTRN    CODE    (_DELAY)
                        PUBLIC    _DISPLAY
                        RSEG    ?CO?_DISPLAY?DISPLAY
?_display?byte:
dispbit:   ds  1
dispnum:   ds  1
           rseg    ?pr?_display?display
_display:  push acc
           push  dph
           push  dpl
          push  psw
           inc   dispnum
            mov a,dispnum
           cjne  a,#4d,disp1
DISP1:    JC  DISP2
           MOV  DISPNUM,#00H
           MOV  DISPBIT,#0FEH
DISP2:     MOV  A,R1
           ADD   A,DISPNUM
           MOV  R0,A
           MOV  A,@R0
           MOV  DPTR,#DISPTABLE
           MOVC   A,@A+DPTR
           MOV P0,A
           MOV A,DISPNUM
           CJNE  A,#2D,DISP3
           CLR   P0.7
DISP3:       MOV P2,DISPBIT
             MOV R5,#00H
             MOV  R7,#0AH
             LCALL  _DELAY
             MOV P0,#0FFH
             MOV  P2,#0FFH
             MOV A,DISPBIT
             RL   A
              MOV DISPBIT,A
             POP  PSW
             POP   DPL
            POP   DPH
             POP   ACC
              RET
DISPTABLE:     DB      0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H,88H,83H,0C6H,0A1H,86H,8EH,0BFH,0FFH
 END
路過(guò)
雞蛋
鮮花
握手
雷人
評(píng)論 (0 個(gè)評(píng)論)
返回頂部
