uid:65574 日志
中國功夫
已有 672 次閱讀2014-8-29 12:08 | 中國功夫
;*  標(biāo)題:  數(shù)碼管計(jì)時(shí)與流水燈同時(shí)運(yùn)行
;*  文件:  中國功夫.C
;*  日期:  2014829日
;*  版本:  V80001.0
;*  作者:  Eking
;*  備注:
;*  描述:
;*  數(shù)碼管計(jì)時(shí)與流水燈同時(shí)運(yùn)行
#include <reg52.h>  //包含特殊功能寄存器定義的頭文件
sbit LE1=P2^0;           //位選573鎖存器使能
sbit LE2=P2^1;           //段選573鎖存器使能
unsigned char code LedChar[16]={  //數(shù)碼管顯示字符轉(zhuǎn)換表
 0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,
                   //  0    1    2    3    4    5    6    7
                     0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};//0~F的段碼
                   //  8    9    A    B    C    D    E    F
unsigned char LedBuff[9] = {  //數(shù)碼管+獨(dú)立LED顯示緩沖區(qū),初值0x00確保啟動(dòng)時(shí)都不亮
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 ,0x00
unsigned char cnt200 = 0;  //200ms計(jì)數(shù)
unsigned int cnt1000 = 0;  //1000ms計(jì)數(shù)
void ShowCount();
void FlowingLight();
void main()
    EA = 1;       //使能總中斷
    TMOD = 0x01;  //設(shè)置T0為模式1
    TH0  = 0xFC;  //T0賦初值0xFC67,定時(shí)1ms
    TL0  = 0x67;
    ET0  = 1;     //使能T0中斷
    TR0  = 1;     //啟動(dòng)T0
    while (1)
        if (cnt200 >= 200)  //200ms刷新一次流水燈
            cnt200 = 0;
            FlowingLight();
        if (cnt1000 >= 1000)  //1s刷新一次計(jì)數(shù)值
            cnt1000 = 0;
            ShowCount();
/* 流水燈實(shí)現(xiàn)函數(shù) */
void FlowingLight()
    static unsigned char dir = 0;   //移位方向變量dir,用于控制移位的方向
    static unsigned char shift = 0x01;  //循環(huán)移位變量shift,并賦初值0x01
    P0 = ~shift;      //循環(huán)移位變量取反,控制8個(gè)LED
    if (dir == 0)             //移位方向變量為0時(shí),左移
        shift = shift << 1;   //循環(huán)移位變量左移1
        if (shift == 0x80)    //左移到最左端后,改變移位方向
            dir = 1;
    else                      //移位方向變量不為0時(shí),右移
        shift = shift >> 1;   //循環(huán)移位變量右移1
        if (shift == 0x01)    //右移到最右端后,改變移位方向
            dir = 0;
/* 秒計(jì)數(shù)顯示函數(shù) */
void ShowCount()
    char i;  //循環(huán)變量
    unsigned char buf[8];   //中間轉(zhuǎn)換緩沖區(qū)
    static unsigned long sec = 0;  //記錄經(jīng)過的秒數(shù)
    sec++;  //秒計(jì)數(shù)自加1
    buf[0] = sec%10;  //sec按十進(jìn)制位從低到高依次提取到buf數(shù)組中
    buf[1] = sec/10%10;
    buf[2] = sec/100%10;
    buf[3] = sec/1000%10;
    buf[4] = sec/10000%10;
    buf[5] = sec/100000%10;
buf[6] = sec/1000000%10;
buf[7] = sec/10000000%10;
    for (i=7; i>=1; i--)  //從最高為開始,遇到0不顯示,遇到非0退出循環(huán)
        if (buf[i] == 0)
            LedBuff[i] = 0x00;
            break;
    for ( ; i>=0; i--)  //將剩余的有效數(shù)字位如實(shí)轉(zhuǎn)換
        LedBuff[i] = LedChar[buf[i]];
/* 定時(shí)器0中斷服務(wù)函數(shù) */
void InterruptTimer0() interrupt 1
    static unsigned char i = 0;   //動(dòng)態(tài)掃描的索引
    TH0 = 0xFC;  //重新加載初值
    TL0 = 0x67;
    cnt200++;
    cnt1000++;
    //以下代碼完成數(shù)碼管動(dòng)態(tài)掃描刷新
P1 = 0x00;   //顯示消隱
LE2 = 1;
LE2 = 0;
    switch (i)
        case 0: P1=0x7F; LE1=1; LE1=0; i++; P1=LedBuff[0]; LE2=1; LE2=0; break;
case 1: P1=0xBF; LE1=1; LE1=0; i++; P1=LedBuff[1]; LE2=1; LE2=0; break;
case 2: P1=0xDF; LE1=1; LE1=0; i++; P1=LedBuff[2]; LE2=1; LE2=0; break;
case 3: P1=0xEF; LE1=1; LE1=0; i++; P1=LedBuff[3]; LE2=1; LE2=0; break;
case 4: P1=0xF7; LE1=1; LE1=0; i++; P1=LedBuff[4]; LE2=1; LE2=0; break;
case 5: P1=0xFB; LE1=1; LE1=0; i++; P1=LedBuff[5]; LE2=1; LE2=0; break;
case 6: P1=0xFD; LE1=1; LE1=0; i++; P1=LedBuff[6]; LE2=1; LE2=0; break;
case 7: P1=0xFE; LE1=1; LE1=0; i=0; P1=LedBuff[7]; LE2=1; LE2=0; break;
        default: break;
路過
雞蛋
鮮花
握手
雷人
評(píng)論 (0 個(gè)評(píng)論)
返回頂部
