#define KEY P1 //鍵盤所連接的I/O接口組定義
函數(shù)名:8個獨立式鍵盤驅(qū)動程序
調(diào) 用:? = Key ();
參 數(shù):無
返回值:unsigned char 鍵值0~8
結(jié) 果:有鍵按下時返回值為鍵值1~8,無鍵按下時返回值為0
備 注:在主函數(shù)中不斷調(diào)用
unsigned char Key ( ){ //8個獨立鍵盤處理程序
unsigned char a,b;
KEY = 0xff; //設(shè)定鍵盤初始電平狀態(tài)
if (KEY != 0xff){ //讀取鍵盤狀態(tài)是否改變
Delay (20); //延時20ms去抖動
if (KEY != 0xff){ //重新讀取
a = KEY; //寄存狀態(tài)值到a
switch(a){ //鍵盤狀態(tài)查表
case 0xfe: b = 1; break;
case 0xfd: b = 2; break;
case 0xfb: b = 3; break;
case 0xf7: b = 4; break;
case 0xef: b = 5; break;
case 0xdf: b = 6; break;
case 0xbf: b = 7; break;
case 0x7f: b = 8; break;
default: b = 0 ; break;
return (b); //將b中的鍵值代號送入函數(shù)返回值
