立即注冊 登錄
返回首頁
uid:85764的個人空間
日志
12864液晶驅(qū)動程序
已有 1639 次閱讀2015-7-15 23:37 | 程序
#include"12864.h"
#include<intrins.h>
#include <math.h>
#define uint  unsigned int
***************         延時函數(shù)          *****************************
void delaynop()
 _nop_();_nop_();
 _nop_();_nop_();
void delayms(uint t)
  uint i,j;
  for(i=0;i<t;i++)
   for(j=0;j<125;j++);
***************         忙檢測            *****************************
bit Lcd_busy()
    bit result;
    LCD_RS = 0;
    LCD_RW = 1;
    LCD_EN = 1;
    delaynop();
    result = (bit)(P0&0x80);
    LCD_EN = 0;
    return(result);
***************         寫指令           *****************************
void Lcd_wcom(uchar cmd)
 while(Lcd_busy());
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_EN = 0;
    _nop_();
    _nop_();
    P0 = cmd;
    delaynop();
    LCD_EN = 1;
    delaynop();
    LCD_EN = 0;
***************         寫數(shù)據(jù)           *****************************
void Lcd_wdate(uchar dat)
 while(Lcd_busy());
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_EN = 0;
    P0 = dat;
    delaynop();
    LCD_EN = 1;
    delaynop();
    LCD_EN = 0;
***************         讀數(shù)據(jù)            *****************************
unsigned char Lcd_rdate()
 uchar read_data;
 Lcd_busy();
 P0=0xff;
 LCD_RS=1;
    LCD_RW=1;
    LCD_EN=0;
    LCD_EN=1;
 read_data=P0;
 LCD_EN=0;
 return  read_data;
***************         設(shè)置地址          *****************************
void Set_address(uchar x,uchar y)
 switch(y)
  case 1: Lcd_wcom(0x7f+x);break;
  case 2: Lcd_wcom(0x8f+x);break;
  case 3: Lcd_wcom(0x87+x);break;
  case 4: Lcd_wcom(0x97+x);break;
***************         顯示單個字符      *****************************
void Lcd_12864_char(uchar dat)
 if((dat>=0)&&(dat<=9))
    dat|=0x30;
    Lcd_wdate(dat);
***************         顯示字符串        *****************************
void Lcd_12864_str(uchar x,uchar y,uchar *p)
 Set_address(x,y);
 while(*p!='\0')
   Lcd_wdate(*p);
   p++;
***************         顯示圖片          *****************************
void Lcd_12864_picture(uchar *gImage)
 uchar x=0x80,y=0x80;
 uchar i,j;
 for(i=0;i<64;i++)
  for(j=0;j<16;j++)
   Lcd_wcom(0x34);
   Lcd_wcom(y);
   Lcd_wcom(x);
   Lcd_wdate(*(gImage+i*16+j));
   Lcd_wdate(*(gImage+i*16+j+1));
   Lcd_wcom(0x36);
   x++;
   j++;
  y++;
  if(y>0x9f)
   y=0x80;
  x=0x80+((i+1)/32)*8;
 Lcd_wcom(0x30);
***************         清屛操作         *****************************
void clear_lcd()
 Lcd_wcom(0x01);
 _nop_();
void clearRAM()
 uchar x,y;
 for(y=0;y<64;y++)
 for(x=0;x<16;x++)
  Lcd_wcom(0x34);
  Lcd_wcom(y+0x80);
  Lcd_wcom(x+0x80);
  Lcd_wcom(0x30);
  Lcd_wdate(0x00);
  Lcd_wdate(0x00);
***************         顯示初始化        *****************************
void Lcd_12864_init(void)
  clear_lcd();
  Lcd_wcom(0x30);
  delayms(5);
  Lcd_wcom(0x02);
  delayms(5);
  Lcd_wcom(0x0c);
  delayms(5);
  Lcd_wcom(0x03);
  delayms(5);
  Lcd_wcom(0x06);
  clear_lcd();
***************         打點(diǎn)操作         *****************************
void  Lcd_12864_drawpoint(uchar x,uchar y,uchar color)
 uchar row,tier,tier_bit;
 uchar read_H,read_L;
 Lcd_wcom(0x34);
 delayms(1);
 Lcd_wcom(0x36);
 tier=x>>4;
 tier_bit=x&0x0f;
 if(y<32)
  row=y;
  row=y-32;
  tier+=8;
 Lcd_wcom(row+0x80);
 Lcd_wcom(tier+0x80);
 Lcd_rdate();
 read_H=Lcd_rdate();
 read_L=Lcd_rdate();
 Lcd_wcom(row+0x80);
 if(tier_bit<8)
  switch(color)
   case 0:read_H&=(~(0x01<<(7-tier_bit)));break;
   case 1:read_H|=(0x01<<(7-tier_bit));break;
   case 2:read_H^=(0x01<<(7-tier_bit));break;
   default :break;
  Lcd_wdate(read_H);
  Lcd_wdate(read_L);
  switch(color)
   case 0:read_L&=(~(0x01<<(15-tier_bit)));break;
   case 1:read_L|=(0x01<<(15-tier_bit));break;
   case 2:read_L^=(0x01<<(15-tier_bit));break;
   default :break;
  Lcd_wdate(read_H);
  Lcd_wdate(read_L);
 Lcd_wcom(0x30);
***************         畫水平線          *****************************
void  Lcd_12864_drawline_x(uchar x0,uchar x1,uchar y,uchar color)
 uchar temp;
 if(x0>x1)
  temp=x1;
  x1=x0;
  x0=temp;
 for(;x0<=x1;x0++)
 Lcd_12864_drawpoint(x0,y,color);
***************         畫垂直線         *****************************
void  Lcd_12864_drawline_y(uchar x,uchar y0,uchar y1,uchar color)
 uchar temp;
 if(y0>y1)
  temp=y1;
  y1=y0;
  y0=temp;
 for(;y0<y1;y0++)
 Lcd_12864_drawpoint(x,y0,color);
***************           畫  圓  (采用Bresenham算法)        *****************************
void  Lcd_12864_drawcircle(uchar x,uchar y,uchar R,uchar color)
 uchar a,b;
 int c;
 a=0;b=R;c=3-2*R;
 while(a<b)
  Lcd_12864_drawpoint(x+a,y+b,color);
  Lcd_12864_drawpoint(x-a,y+b,color);
  Lcd_12864_drawpoint(x+a,y-b,color);
  Lcd_12864_drawpoint(x-a,y-b,color);
  Lcd_12864_drawpoint(x+b,y+a,color);
  Lcd_12864_drawpoint(x-b,y+a,color);
  Lcd_12864_drawpoint(x+b,y-a,color);
  Lcd_12864_drawpoint(x-b,y-a,color);
  if(c<0)
   c=c+4*a+6;
   c=c+4*(a-b)+10;
   b-=1;
  a+=1;
 if(a==b)
***************           畫任意直線   (采用Bresenham算法)   *****************************
void  Lcd_12864_drawLine(uchar start_x,uchar start_y,uchar end_x,uchar end_y,uchar color)
 int t,distance;
 int x=0,y=0,delta_x,delta_y;
 char inc_x,inc_y;
 delta_x=end_x-start_x;
 delta_y=end_y-start_y;
 if(delta_x>0)
  inc_x=1;
 if(delta_x==0)
  Lcd_12864_drawline_y(start_x,start_y,end_y,color);
  return;
  inc_x=-1;
 if(delta_y>0)
  inc_y=1;
 if(delta_y==0)
  Lcd_12864_drawline_x(start_x,end_x,start_y,color);
  return;
  inc_y=-1;
  delta_x=abs(delta_x);
  delta_y=abs(delta_y);
  if(delta_x>delta_y)
  distance=delta_x;
   distance=delta_y;
  Lcd_12864_drawpoint(start_x,start_y,color);
  for(t=0;t<=distance+1;t++)
  x+=delta_x;
  y+=delta_y;
  if(x>distance)
   x-=distance;
   start_x+=inc_x;
  if(y>distance)
   y-=distance;
   start_y+=inc_y;
路過
雞蛋
鮮花
握手
雷人
評論 (0 個評論)
返回頂部
