立即注冊 登錄
返回首頁
uid:92918的個人空間
日志
求大神講解
已有 1036 次閱讀2017-12-16 19:53
*                       普中科技
* 實 驗 名 : LED點陣數(shù)字倒計時
* 實驗說明       :
* 連接方式       : 見接線圖
* 注    意
#include <REG51.H>
//--重定義函數(shù)變量--//
#define uint  unsigned int
#define ulong unsigned long
//--定義SPI要使用的 IO--//
sbit MOSIO = P3^4;
sbit R_CLK = P3^5;
sbit S_CLK = P3^6;
//---全局變量聲明--//
ulong column;   //點陣列
ulong row;      //點陣行
ulong dt;
//--點陣顯示數(shù)組--//
uchar code tab0[] =
{0x00, 0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08,
 0x00, 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80,
 0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08, 0x00,
 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80, 0x00};
//--10字模--//
uchar code tab1[] =
{0, 0, 0, 0, 0, 0, 8, 24, 14, 36, 8, 66, 8, 66, 8, 66,
 8, 66, 8, 66, 8, 66, 8, 36, 62, 24, 0, 0, 0, 0, 0, 0};
//--09字模--//
uchar code tab2[] =
{0, 0, 0, 0, 0, 0, 24, 24, 36, 36, 66, 66, 66, 66, 66,
 66, 66, 100, 66, 88, 66, 64, 66, 64, 36, 36, 24, 28, 0, 0, 0, 0} ;
//--08字模--//
uchar code tab3[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66, 66, 66, 66, 36,
66, 24, 66, 36, 66, 66, 66, 66, 36, 66, 24, 60, 0, 0, 0, 0};
//--07字模--//
uchar code tab4[] =
{0, 0, 0, 0, 0, 0, 24, 126, 36, 34, 66, 34, 66, 16, 66, 16,
 66, 8, 66, 8, 66, 8, 66, 8, 36, 8, 24, 8, 0, 0, 0, 0};
//--06字模--//
uchar code tab5[] =
{0, 0, 0, 0, 0, 0, 24, 56, 36, 36, 66, 2, 66, 2, 66, 26, 66,
 38, 66, 66, 66, 66, 66, 66, 36, 36, 24, 24, 0, 0, 0, 0};
//--05字模--//
uchar code tab6[] =
{0, 0, 0, 0, 0, 0, 24, 126, 36, 2, 66, 2, 66, 2, 66, 26, 66,
 38, 66, 64, 66, 64, 66, 66, 36, 34, 24, 28, 0, 0, 0, 0};
//--04字模--//
uchar code tab7[] =
{0, 0, 0, 0, 0, 0, 24, 32, 36, 48, 66, 40, 66, 36, 66, 36, 66,
34, 66, 34, 66, 126, 66, 32, 36, 32, 24, 120, 0, 0, 0, 0};
//--03字模--//
uchar code tab8[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66, 66, 32, 66, 24, 66,
 32, 66, 64, 66, 64, 66, 66, 36, 34, 24, 28, 0, 0, 0, 0};
//--02字模--//
uchar code tab9[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66, 66, 66, 66, 32, 66,
 32, 66, 16, 66, 8, 66, 4, 36, 66, 24, 126, 0, 0, 0, 0};
//--01字模--//
uchar code tab10[] =
{0, 0, 0, 0, 0, 0, 24, 8, 36, 14, 66, 8, 66, 8, 66, 8, 66, 8, 66,
8, 66, 8, 66, 8, 36, 8, 24, 62, 0, 0, 0, 0};
//--00字模--//
uchar code tab11[] =
{0, 0, 0, 0, 0, 0, 24, 24, 36, 36, 66, 66, 66, 66, 66, 66, 66, 66,
//--GO--//
uchar code tab12[] =
{0, 0, 0, 0, 0, 0, 60, 28, 34, 34, 34, 65, 1, 65, 1, 65, 1, 65, 113,
 65, 33, 65, 34, 65, 34, 34, 28, 28, 0, 0, 0, 0};
//--全局函數(shù)聲明--//
void HC595SendData(  uchar BT3, uchar BT2,uchar BT1,uchar BT0);
* 函 數(shù) 名         : main
* 函數(shù)功能   : 主函數(shù)
* 輸    入         : 無
* 輸    出         : 無
void main(void)
int k, i, ms;
i = 60; //顯示時間
//--顯示10--//
for(ms = i; ms > 0; ms--)
for(k = 0; k < 16; k++)
HC595SendData(~tab1[2*k +1],~tab1[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
HC595SendData(0xff,0xff,0,0);
//--顯示09--//
HC595SendData(~tab2[2*k +1],~tab2[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
//--顯示08--//
HC595SendData(~tab3[2*k +1],~tab3[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
//--顯示07--//
HC595SendData(~tab4[2*k +1],~tab4[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
//--顯示06--//
HC595SendData(~tab5[2*k +1],~tab5[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
   //--顯示05--//
for(k = 0; k < 16; k++) //歡
HC595SendData(~tab6[2*k +1],~tab6[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
   //--顯示04--//
HC595SendData(~tab7[2*k +1],~tab7[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
//--顯示03--//
HC595SendData(~tab8[2*k +1],~tab8[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
//--顯示02--//
HC595SendData(~tab9[2*k +1],~tab9[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
//--顯示01--//
HC595SendData(~tab10[2*k +1],~tab10[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
//--顯示00--//
HC595SendData(~tab11[2*k +1],~tab11[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
HC595SendData(0xff,0xff,0,0);        //清屏
   //--一直顯示G0--//
for(k = 0; k < 16; k++) //中
HC595SendData(~tab12[2*k +1],~tab12[2*k],tab0[2*k],tab0[2*k + 1]);
* 函 數(shù) 名         : HC595SendData
* 函數(shù)功能   : 通過595發(fā)送四個字節(jié)的數(shù)據(jù)
* 輸    入         : BT3:第四個595輸出數(shù)值
*                  * BT2: 第三個595輸出數(shù)值
*                  * BT1:第二個595輸出數(shù)值
*                  * BT0:第一個595輸出數(shù)值
* 輸    出         : 無
uchar i;
//--發(fā)送第一個字節(jié)--//
for(i=0;i<8;i++)
MOSIO = BT3 >> 7 ; //從高位到低位
BT3 <<= 1;
S_CLK = 0;
S_CLK = 1;
for(i=0;i<8;i++)
MOSIO = BT2 >>7; //從高位到低位
BT2 <<= 1;
S_CLK = 0;
S_CLK = 1;
for(i=0;i<8;i++)
MOSIO = BT1 >> 7; //從高位到低位
BT1 <<= 1;
S_CLK = 0;
S_CLK = 1;
for(i=0;i<8;i++)
MOSIO = BT0 >> 7; //從高位到低位
BT0 <<= 1;
S_CLK = 0;
S_CLK = 1;
//--輸出--//
R_CLK = 0; //set dataline low
R_CLK = 1; //片選
路過
雞蛋
鮮花
握手
雷人
評論 (0 個評論)
返回頂部
