查看: 2787|回復(fù): 2
ad7705驅(qū)動(dòng)子程序 項(xiàng)目上實(shí)踐過(guò)得
ID:144296 發(fā)表于 2017-12-3 12:52 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include "AD7705.h"
功能:延時(shí)
參數(shù):循環(huán)次數(shù)
返回:無(wú)
void adc_delay(unsigned char NUM)
  for(;NUM>0;NUM--);
功能:寫(xiě)入AD芯片一個(gè)字節(jié)
參數(shù):要寫(xiě)入的命令或參數(shù)
返回:無(wú)
void write_adc_byte(unsigned char chr)
unsigned char i;
for(i=0;i<8;i++)
  ADC_CLK= 0;
  chr=chr<<1;
  ADC_DI= CY;
  ADC_CLK= 1;
ADC_CLK = 1;
功能:從AD芯片讀取一個(gè)字(16位)
參數(shù):無(wú)
返回:讀取的字(16位)
unsigned int read_adc_word()
unsigned char i;
unsigned int coder = 0;
for(i=0;i<16;i++)
  ADC_CLK = 0;
  coder = coder<<1;
  if(ADC_DO)coder+=1;
  ADC_CLK = 1;
ADC_CLK = 1;
return(coder);
功能:AD芯片復(fù)位
參數(shù):無(wú)
返回:無(wú)
void adc_rest()
unsigned char i,j;
ADC_DI  = 1;
ADC_CLK = 1;
ADC1_CS = 1;
// ADC2_CS = 1;
ADC_RESET = 0;
for(i=300;i>0;i--)
for(j=300;j>0;j--);
ADC_RESET = 1;
功能:AD芯片初始化
參數(shù):calmode      工作模式選擇(如:ADC_SELF  ……)
      gainsetting  輸入增益選擇(如:ADC_GAIN_128  ……)
      operation    單極性/雙極性(如:ADC_BIPOLAR  ……)
      rate         輸出更新率(如:ADC_50  ……)
返回:無(wú)
void adc1_init(unsigned char calmode, unsigned char gainsetting, unsigned char operation, unsigned char rate)
ADC1_CS = 0;
write_adc_byte(0xFF);
ADC1_CS = 1;
adc_delay(100);
ADC1_CS = 0;
write_adc_byte( 0x20 );//
ADC1_CS = 1;
adc_delay(100);
ADC1_CS = 0;
write_adc_byte( rate );//
ADC1_CS = 1;
adc_delay(100);
ADC1_CS = 0;
   write_adc_byte( 0x10 );//
   ADC1_CS = 1;
adc_delay(100);
ADC1_CS = 0;
write_adc_byte( calmode|gainsetting|operation);//
ADC1_CS = 1;
adc_delay(100);
功能:讀取AD轉(zhuǎn)換碼
參數(shù):通道號(hào)   如:1、2
返回:讀取的AD轉(zhuǎn)換結(jié)果(如果等于零表示正忙)
unsigned int adc1_read_value(unsigned char ch)
unsigned int  value;
if(!ADC1_DRDY)
  ADC1_CS = 0;
  if(ch == 1)
         write_adc_byte(0x38);//
     else if(ch == 2)
         write_adc_byte(0x39);//
  else    {ADC1_CS = 1;return 0;}
  ADC1_CS = 1;
  adc_delay(1);
  ADC1_CS = 0;
  value = read_adc_word();
  ADC1_CS = 1;
  return value;
  return 0;
收藏收藏2 分享淘帖 頂 踩
ID:511272 發(fā)表于 2019-8-4 10:43 | 只看該作者
你好,能發(fā)一下頭文件嗎,我想看看初始化是怎么定義的
功能:AD芯片初始化
返回:無(wú)
ID:511272 發(fā)表于 2019-8-4 15:43 | 只看該作者
感謝樓主,調(diào)出來(lái)了
