#include <reg52.h> //調(diào)用單片機(jī)頭文件
#define uchar unsigned char //無(wú)符號(hào)字符型 宏定義 變量范圍0~255
#define uint unsigned int //無(wú)符號(hào)整型 宏定義 變量范圍0~65535
#include <intrins.h>
uchar a_a;
//數(shù)碼管段選定義 0 1 2 3 4 5 6 7 8 9
uchar code smg_du[]={0x28,0xee,0x32,0xa2,0xe4,0xa1,0x21,0xea,0x20,0xa0,
0x60,0x25,0x39,0x26,0x31,0x71,0xff}; //斷碼
uchar dis_smg[8] ={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8};
//數(shù)碼管位選定義
sbit smg_we1 = P3^4; //數(shù)碼管位選定義
sbit smg_we2 = P3^5;
sbit smg_we3 = P3^6;
sbit smg_we4 = P3^7;
sbit c_send = P3^2; //超聲波發(fā)射
sbit c_recive = P3^3; //超聲波接收
sbit beep = P2^3; //蜂鳴器IO口定義
uchar smg_i = 3; //顯示數(shù)碼管的個(gè)位數(shù)
bit flag_300ms ;
long distance; //距離
uint set_d; //距離
uchar flag_csb_juli; //超聲波超出量程
uint flag_time0; //用來(lái)保存定時(shí)器0的時(shí)候的
uchar menu_1; //菜單設(shè)計(jì)的變量
/***********************1ms延時(shí)函數(shù)*****************************/
void delay_1ms(uint q)
uint i,j;
for(i=0;i<q;i++)
for(j=0;j<120;j++);
/***********************處理距離函數(shù)****************************/
void smg_display()
dis_smg[0] = smg_du[distance % 10];
dis_smg[1] = smg_du[distance / 10 % 10];
dis_smg[2] = smg_du[distance / 100 % 10] & 0xdf; ;
#define RdCommand 0x01 //定義ISP的操作命令
#define PrgCommand 0x02
#define EraseCommand 0x03
#define Error 1
#define Ok 0
#define WaitTime 0x01 //定義CPU的等待時(shí)間
sfr ISP_DATA=0xe2; //寄存器申明
sfr ISP_ADDRH=0xe3;
sfr ISP_ADDRL=0xe4;
sfr ISP_CMD=0xe5;
sfr ISP_TRIG=0xe6;
sfr ISP_CONTR=0xe7;
/* ================ 打開(kāi) ISP,IAP 功能 ================= */
void ISP_IAP_enable(void)
EA = 0; /* 關(guān)中斷 */
ISP_CONTR = ISP_CONTR & 0x18; /* 0001,1000 */
ISP_CONTR = ISP_CONTR | WaitTime; /* 寫(xiě)入硬件延時(shí) */
ISP_CONTR = ISP_CONTR | 0x80; /* ISPEN=1 */
/* =============== 關(guān)閉 ISP,IAP 功能 ================== */
void ISP_IAP_disable(void)
ISP_CONTR = ISP_CONTR & 0x7f; /* ISPEN = 0 */
ISP_TRIG = 0x00;
EA = 1; /* 開(kāi)中斷 */
/* ================ 公用的觸發(fā)代碼 ==================== */
void ISPgoon(void)
ISP_IAP_enable(); /* 打開(kāi) ISP,IAP 功能 */
ISP_TRIG = 0x46; /* 觸發(fā)ISP_IAP命令字節(jié)1 */
ISP_TRIG = 0xb9; /* 觸發(fā)ISP_IAP命令字節(jié)2 */
_nop_();
/* ==================== 字節(jié)讀 ======================== */
unsigned char byte_read(unsigned int byte_addr)
EA = 0;
ISP_ADDRH = (unsigned char)(byte_addr >> 8);/* 地址賦值 */
ISP_ADDRL = (unsigned char)(byte_addr & 0x00ff);
ISP_CMD = ISP_CMD & 0xf8; /* 清除低3位 */
ISP_CMD = ISP_CMD | RdCommand; /* 寫(xiě)入讀命令 */
ISPgoon(); /* 觸發(fā)執(zhí)行 */
ISP_IAP_disable(); /* 關(guān)閉ISP,IAP功能 */
EA = 1;
return (ISP_DATA); /* 返回讀到的數(shù)據(jù) */
/* ================== 扇區(qū)擦除 ======================== */
void SectorErase(unsigned int sector_addr)
unsigned int iSectorAddr;
iSectorAddr = (sector_addr & 0xfe00); /* 取扇區(qū)地址 */
ISP_ADDRH = (unsigned char)(iSectorAddr >> 8);
ISP_ADDRL = 0x00;
ISP_CMD = ISP_CMD & 0xf8; /* 清空低3位 */
ISP_CMD = ISP_CMD | EraseCommand; /* 擦除命令3 */
/* ==================== 字節(jié)寫(xiě) ======================== */
void byte_write(unsigned int byte_addr, unsigned char original_data)
EA = 0;
// SectorErase(byte_addr);
ISP_ADDRH = (unsigned char)(byte_addr >> 8); /* 取地址 */
ISP_CMD = ISP_CMD & 0xf8; /* 清低3位 */
ISP_CMD = ISP_CMD | PrgCommand; /* 寫(xiě)命令2 */
ISP_DATA = original_data; /* 寫(xiě)入數(shù)據(jù)準(zhǔn)備 */
ISP_IAP_disable(); /* 關(guān)閉IAP功能 */
EA =1;
/******************把數(shù)據(jù)保存到單片機(jī)內(nèi)部eeprom中******************/
void write_eeprom()
SectorErase(0x2000);
byte_write(0x2000, set_d % 256);
byte_write(0x2001, set_d / 256);
byte_write(0x2058, a_a);
/******************把數(shù)據(jù)從單片機(jī)內(nèi)部eeprom中讀出來(lái)*****************/
void read_eeprom()
set_d = byte_read(0x2001);
set_d <<= 8;
set_d |= byte_read(0x2000);
a_a = byte_read(0x2058);
/**************開(kāi)機(jī)自檢eeprom初始化*****************/
void init_eeprom()
read_eeprom(); //先讀
if(a_a != 1) //新的單片機(jī)初始單片機(jī)內(nèi)問(wèn)eeprom
set_d = 50;
a_a = 1;
write_eeprom(); //保存數(shù)據(jù)
/********************獨(dú)立按鍵程序*****************/
uchar key_can; //按鍵值
void key() //獨(dú)立按鍵程序
static uchar key_new;
key_can = 20; //按鍵值還原
P2 |= 0x07;
if((P2 & 0x07) != 0x07) //按鍵按下
delay_1ms(1); //按鍵消抖動(dòng)
if(((P2 & 0x07) != 0x07) && (key_new == 1))
{ //確認(rèn)是按鍵按下
key_new = 0;
switch(P2 & 0x07)
case 0x06: key_can = 3; break; //得到k2鍵值
case 0x05: key_can = 2; break; //得到k3鍵值
case 0x03: key_can = 1; break; //得到k4鍵值
key_new = 1;
/****************按鍵處理顯示函數(shù)***************/
void key_with()
if(key_can == 1) //設(shè)置鍵
menu_1 ++;
if(menu_1 >= 2)
menu_1 = 0;
smg_i = 3; //只顯示3位數(shù)碼管
if(menu_1 == 1)
smg_i = 4; //只顯示4位數(shù)碼管
if(menu_1 == 1) //設(shè)置報(bào)警
if(key_can == 2)
set_d ++ ; //加1
if(set_d > 400)
set_d = 400;
if(key_can == 3)
set_d -- ; //減1
if(set_d <= 1)
set_d = 1;
dis_smg[0] = smg_du[set_d % 10]; //取小數(shù)顯示
dis_smg[1] = smg_du[set_d / 10 % 10] ; //取個(gè)位顯示
dis_smg[2] = smg_du[set_d / 100 % 10] & 0xdf ; //取十位顯示
dis_smg[3] = 0x60; //a
/****************報(bào)警函數(shù)***************/
void clock_h_l()
static uchar value;
if(distance <= set_d)
value ++; //消除實(shí)際距離在設(shè)定距離左右變化時(shí)的干擾
if(value >= 2)
beep = ~beep; //蜂鳴器報(bào)警
value = 0;
beep = 1; //取消報(bào)警
/***********************數(shù)碼位選函數(shù)*****************************/
void smg_we_switch(uchar i)
switch(i)
case 0: smg_we1 = 0; smg_we2 = 1; smg_we3 = 1; smg_we4 = 1; break;
case 1: smg_we1 = 1; smg_we2 = 0; smg_we3 = 1; smg_we4 = 1; break;
case 2: smg_we1 = 1; smg_we2 = 1; smg_we3 = 0; smg_we4 = 1; break;
case 3: smg_we1 = 1; smg_we2 = 1; smg_we3 = 1; smg_we4 = 0; break;
/***********************數(shù)碼顯示函數(shù)*****************************/
void display()
static uchar i;
i++;
if(i >= smg_i)
i = 0;
smg_we_switch(i); //位選
P1 = dis_smg[i]; //段選
/******************小延時(shí)函數(shù)*****************/
void delay()
_nop_(); //執(zhí)行一條_nop_()指令就是1us
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
/*********************超聲波測(cè)距程序*****************************/
void send_wave()
c_send = 1; //10us的高電平觸發(fā)
delay();
c_send = 0;
TH0 = 0; //給定時(shí)器0清零
TL0 = 0;
TR0 = 0; //關(guān)定時(shí)器0定時(shí)
while(!c_recive); //當(dāng)c_recive為零時(shí)等待
TR0=1;
while(c_recive) //當(dāng)c_recive為1計(jì)數(shù)并等待
flag_time0 = TH0 * 256 + TL0;
if((flag_time0 > 40000)) //當(dāng)超聲波超過(guò)測(cè)量范圍時(shí),顯示3個(gè)888
TR0 = 0;
flag_csb_juli = 2;
distance = 888;
break ;
flag_csb_juli = 1;
if(flag_csb_juli == 1)
TR0=0; //關(guān)定時(shí)器0定時(shí)
distance =flag_time0; //讀出定時(shí)器0的時(shí)間
distance *= 0.017; // 0.017 = 340M / 2 = 170M = 0.017M 算出來(lái)是米
if((distance > 500)) //距離 = 速度 * 時(shí)間
distance = 888; //如果大于3.8m就超出超聲波的量程
/*********************定時(shí)器0、定時(shí)器1初始化******************/
void time_init()
EA = 1; //開(kāi)總中斷
TMOD = 0X11; //定時(shí)器0、定時(shí)器1工作方式1
ET0 = 0; //關(guān)定時(shí)器0中斷
TR0 = 1; //允許定時(shí)器0定時(shí)
ET1 = 1; //開(kāi)定時(shí)器1中斷
TR1 = 1; //允許定時(shí)器1定時(shí)
/***************主函數(shù)*****************/
beep = 0; //開(kāi)機(jī)叫一聲
delay_1ms(150);
P0 = P1 = P2 = P3 = 0xff; //初始化單片機(jī)IO口為高電平
send_wave(); //測(cè)距離函數(shù)
smg_display(); //處理距離顯示函數(shù)
time_init(); //定時(shí)器初始化程序
init_eeprom(); //開(kāi)始初始化保存的數(shù)據(jù)
if(flag_300ms == 1)
flag_300ms = 0;
clock_h_l(); //報(bào)警函數(shù)
if(beep == 1)
if(menu_1 == 0)
key(); //按鍵函數(shù)
if(key_can < 10)
key_with(); //按鍵處理函數(shù)
/*********************定時(shí)器1中斷服務(wù)程序************************/
void time1_int() interrupt 3
static uchar value; //定時(shí)2ms中斷一次
TH1 = 0xf8;
TL1 = 0x30; //2ms
display(); //數(shù)碼管顯示函數(shù)
value++;
if(value >= 150)
value = 0;
flag_300ms = 1;
