#include <MSP430f249.h>
uchar const led_tab[]={ 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71}; //共陰數(shù)碼管段選碼表,無小數(shù)點
uchar disp_buf[4]; //顯示緩沖區(qū)
void delayus(uint t)
uint i;
while(t--)
for(i=1300;i>0;i--);
void timecount(uint count){
uint i;
disp_buf[1] = count / 10; //對主干道計數(shù)值取十位數(shù)
disp_buf[0] = count % 10; //對主干道計數(shù)值取個位數(shù)
disp_buf[3] = count / 10; //對支干道計數(shù)值取十位數(shù)
disp_buf[2] = count % 10; //對支干道計數(shù)值取個位數(shù)
for(i = 0;i < 25; i++) //總共循環(huán)25次,計時1s
P1OUT = 0;
P4OUT = 0;
P1OUT = led_tab[disp_buf[1]];
P4OUT = led_tab[disp_buf[3]];
P2OUT = ~(BIT0+BIT2); //顯示十位數(shù)
delayus(2); //軟件仿真時,取20不閃爍
P1OUT = 0;
P4OUT = 0;
P1OUT = led_tab[disp_buf[0]];
P4OUT = led_tab[disp_buf[2]];
P2OUT = ~(BIT1+BIT3); //顯示個位數(shù)
void system_Initial(void)
P3SEL &= 0x00; //選擇P3為輸入/輸出口
P3DIR |= 0Xff; //選擇P3為輸出功能
P1DIR = 0xFF; // 設(shè)置方向為輸出
P4DIR = 0xFF; // 設(shè)置方向為輸出
P2DIR = BIT0 + BIT1+BIT2+BIT3;
P1OUT = 0x00; //LED輸出全部關(guān)閉
P4OUT = 0x00; //LED輸出全部關(guān)閉
P2OUT = BIT0 + BIT1+BIT2+BIT3;
P2IE |= BIT4+BIT5+BIT6; //P2.2中斷使能
P2IES |= BIT4+BIT5+BIT6; //P2.2下降沿中斷
P2IFG &=~(BIT4+BIT5+BIT6); //P2.2清除中斷標(biāo)志
_EINT();
// 端口2中斷服務(wù)程序
#pragma vector=PORT2_VECTOR
__interrupt void Port_2(void)
P2IFG &= ~(BIT4+BIT5+BIT6); //清除中斷標(biāo)志
int main(void)
uchar count = 12; //計數(shù)值
WDTCTL = WDTPW + WDTHOLD; // 關(guān)閉看門狗
system_Initial();
if(!(0x10 & P2IN)) {
while(1){
for(count=15;count>=1;count--){
P3OUT=0x04+0x08;
timecount(count);
for(count=5;count>=1;count--){
P3OUT=0x02+0x08;
timecount(count);
P3OUT=0x01+0x20;
timecount(count);
P3OUT=0x01+0x10;
timecount(count);
