DESCRIPTION
The DS1621 Digital Thermometer and Thermostat provides 9-bit temperature readings, which indicate
the temperature of the device. The thermal alarm output, TOUT, is active when the temperature of the
device exceeds a user-defined temperature TH. The output remains active until the temperature drops
below user defined temperature TL, allowing for any hysteresis necessary.
User-defined temperature settings are stored in nonvolatile memory so parts may be programmed prior to
insertion in a system. Temperature settings and temperature readings are all communicated to/from the
DS1621 over a simple 2-wire serial interface.
DS1621引腳圖
2018-1-9 03:38 上傳
2018-1-9 03:38 上傳
完整的pdf格式文檔51黑下載地址:
DS1621.pdf
(498.16 KB, 下載次數(shù): 13)
2018-1-3 20:02 上傳
點擊文件名下載附件
DS1621 下載積分: 黑幣 -5
