查看: 1178|回復(fù): 0
AD程序不知道對不對,求大神指導(dǎo)
ID:273783 發(fā)表于 2018-1-9 14:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "INTRINS.H"
#include"reg51.h"
#include"ADC.h"
sbit         AD_SCLK        =    P1^3;
sbit     AD_CS                =         P1^4;
sbit         AD_DIN                =    P1^0;
sbit         AD_DOUT        =    P1^1;
sbit         AD_DRDY        =    P1^2;
#define Delay2us()         _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
名稱:void AD7705_Write_Reg(uchar Data_byte);
功能:寫AD7705寄存器
指令:無
調(diào)用:無
返回:無
void AD7705_Write_Reg(UINT8 Data_byte)
        UINT8 i;
        AD_CS=0;
        Delay2us()
        AD_SCLK = 0;
          Delay2us()
        for(i = 0; i < 8; i++)
                AD_SCLK = 0;
                  if(Data_byte & 0x80)AD_DIN = 1;
                        AD_DIN = 0;
                  Delay2us()
                  AD_SCLK = 1;
          Data_byte <<= 1;
          Delay2us()
        AD_CS=1;
名稱:uchar AD7705_Read_Reg();
功能:讀AD7705寄存器
指令:無
調(diào)用:無
返回:Data_read
UINT8 AD7705_Read_Reg(void)
        UINT8 i,Data_read;
        UINT16 j;
        AD_SCLK = 1;
        Delay2us()
        AD_DRDY=1;
        for(j=0;j<10000;j++)if(AD_DRDY)break;
        Delay2us()
        AD_CS=0;
             AD_SCLK = 0;
             Delay2us()
                  Data_read <<= 1;
                AD_SCLK = 1;
                if(AD_DOUT)
                                  Data_read = Data_read|0x01;
                                Data_read = Data_read&0xfe;
                  Delay2us()
            Delay2us()
           Delay2us()
          AD_DRDY = 1;
        AD_CS=1;
          return(Data_read);
void AD7705_Start(UINT8 temp )
          if(temp==1)
                AD7705_Write_Reg(0x21);        //選擇時鐘寄存器,寫寄存器,正常模式
                AD7705_Write_Reg(0x08);        //時鐘寄存器,二分頻,主頻2.4576MHz,所以CLK=0;
                AD7705_Write_Reg(0x11);        //選擇設(shè)置寄存器,寫寄存器,正常模式
                  AD7705_Write_Reg(0x70);        //自校準,增益為1,單極性
                AD7705_Write_Reg(0x20);        //選擇時鐘寄存器,寫寄存器,正常模式
                AD7705_Write_Reg(0x10);        //選擇設(shè)置寄存器,寫寄存器,正常模式
                  AD7705_Write_Reg(0x78);        //自校準,增益為1,單極性
void AD7705_Reset(UINT8 temp)
        UINT8 i;
        AD_DIN=1;
        for(i=1;i<=50;i++)
                Delay2us()
                AD_SCLK = !AD_SCLK;
                Delay2us()
        AD7705_Start(temp);
