查看: 5005|回復(fù): 8
請(qǐng)教,為什么MAX6675讀取溫度不能實(shí)時(shí)顯示!
ID:218368 發(fā)表于 2018-3-29 16:43 | 顯示全部樓層 |閱讀模式
用51通過(guò)MAX6675讀取溫度,并在1602上顯示。
現(xiàn)在的程序只能顯示開(kāi)機(jī)讀取的溫度,溫度變化后,不能顯示在1602上,請(qǐng)大俠看看是程序什么地方出了問(wèn)題。
單片機(jī)源碼:
  1. #include <reg51.h>
  2. #include <Intrins.h>
  3. #include <LCD1602.H>
  4. #include <math.H>
  5. #define uchar unsigned char
  6. #define uint unsigned int
  7. sbit MAX6675_SO=P1^0;
  8. sbit MAX6675_SCK=P1^1;
  9. sbit MAX6675_CS=P1^2;
  10. bit ack,flag=0,flag1=0;
  11. uint  tz;
  12. int t_zhi=0;
  13. char code keytab[]={0xEE,0xDE,0xBE,0x7E,0xED,0xDD,0xBD,0x7D,0xEB,0xDB,0xBB,0x7B,0xE7,0xD7,0xB7,0x77};
  14. unsigned char code str3[]={"              "};
  15. unsigned char data disdata[5];
  16. unsigned int ReadMAX6675()
  17. {
  18. unsigned char count;
  19. unsigned int Value;
  20. MAX6675_CS=0;
  21. MAX6675_SCK=0;
  22. Value=0;
  23. _nop_() ;_nop_();_nop_();_nop_();
  24. for(count=0;count<16;count++)
  25. {
  26.   Value=Value<<1;
  27.   MAX6675_SCK=1;
  28.   _nop_() ;_nop_();_nop_();_nop_();
  29.   if(MAX6675_SO==1)
  30.      Value|=0x01;
  31.      MAX6675_SCK=0;
  32. }
  33. MAX6675_CS=1;
  34. return Value;
  35. }
  36. unsigned int GetCurrentTemp(unsigned int CurrentValue)
  37. {
  38.   unsigned int TempValue;
  39.   TempValue=CurrentValue;
  40.   if(TempValue&0x8000)
  41.   return 0;
  42.   if(TempValue&0x0004)
  43.   return 1;
  44. }
  45. void tempdisp()         //ζèÖμÏÔê¾
  46. { unsigned char i;
  47.   unsigned int TempValue;
  48.   unsigned int testD2;
  49.   int xiaoshu;
  50.   TempValue=ReadMAX6675();
  51.   testD2=GetCurrentTemp(TempValue);
  52.   TempValue=ReadMAX6675();
  53.   TempValue&=0x7ff8;
  54.   TempValue>>=3;
  55.   xiaoshu= (TempValue*1023.75/4095)*10-262;
  56.   t_zhi=xiaoshu/10;
  57.   disdata[0]=xiaoshu/10000+0x30;
  58.   xiaoshu=xiaoshu%10000;
  59.   disdata[1]=xiaoshu/1000+0x30;
  60.   xiaoshu=xiaoshu%1000;
  61.   disdata[2]=xiaoshu/100+0x30;
  62.   xiaoshu=xiaoshu%100;
  63.   disdata[3]=xiaoshu/10+0x30;
  64.   xiaoshu=xiaoshu%10;
  65.   disdata[4]=xiaoshu/1+0x30;
  66.   LCD_set_position(68);
  67.   for(i=0;i<4;i++)
  68.   LCD_write_data(disdata[i]);
  69.   LCD_write_data('.');
  70.   LCD_write_data(disdata[4]);
  71.   LCD_write_data(0xDF);
  72.   LCD_write_data(0x43);
  73. }
  74. void main()
  75. {
  76.   LCD_initial();
  77.   LCD_cls();
  78.   LCD_set_position(0);
  79.   //LCD_prints(str1);
  80.   LCD_set_position(3);
  81.   MAX6675_CS=1;
  82.   while(1)
  83.   {
  84.     ReadMAX6675();
  85.      GetCurrentTemp();
  86.            tempdisp();
  87. }
  88. }
ID:485731 發(fā)表于 2019-4-21 15:45 | 顯示全部樓層
樓主你的問(wèn)題解決了么?
ID:417092 發(fā)表于 2019-5-3 12:35 | 顯示全部樓層
求同樣的問(wèn)題。。。
ID:417092 發(fā)表于 2019-5-3 12:41 | 顯示全部樓層
求解,同樣的問(wèn)題。我在網(wǎng)上找了幾個(gè)程序,都無(wú)法讀出溫度
ID:471427 發(fā)表于 2020-11-22 15:45 來(lái)自觸屏版 | 顯示全部樓層
一樣的問(wèn)題
ID:451718 發(fā)表于 2020-11-23 11:52 | 顯示全部樓層
ReadMAX6675(); 這個(gè)函數(shù)要間隔一段時(shí)間運(yùn)行一次。只有一次讀數(shù),大概率是間隔時(shí)間太短了造成的。  有兩種解決方案:
1,把ReadMAX6675()放到定時(shí)器中運(yùn)行,500ms運(yùn)行一次。
2,在主程序while循環(huán)中加一個(gè)500ms的延遲函數(shù)。
ID:731755 發(fā)表于 2022-12-5 20:38 來(lái)自觸屏版 | 顯示全部樓層
robinsonlin 發(fā)表于 2020-11-23 11:52
ReadMAX6675(); 這個(gè)函數(shù)要間隔一段時(shí)間運(yùn)行一次。只有一次讀數(shù),大概率是間隔時(shí)間太短了造成的。  有兩種 ...
謝謝,你的方法好用
ID:1049152 發(fā)表于 2023-1-12 14:52 | 顯示全部樓層
max6675的數(shù)據(jù)轉(zhuǎn)換時(shí)間不能太近,間隔要在200ms左右,你可以加延時(shí)也可以用一個(gè)定時(shí)器,推薦使用定時(shí)器
ID:444215 發(fā)表于 2023-8-28 22:56 | 顯示全部樓層
問(wèn)題解決了嗎?
