稀缺資源
單片機(jī)源碼:
- #include <REG52.H>
- #include <INTRINS.H>
- #define uchar unsigned char
- #define uint unsigned int
- #define DataPort P0 //LCD1602數(shù)據(jù)端口
- sbit SCL=P3^5; //IIC時(shí)鐘引腳定義;
- sbit SDA=P3^4; //IIC數(shù)據(jù)引腳定義
- uchar code table_num[]="0123456789abcdefg";
- /* *********** LCD1602設(shè)置 *************/
- sbit rs=P2^5; //寄存器選擇信號(hào) H:數(shù)據(jù)寄存器 L:指令寄存器
- sbit rw=P2^6; //寄存器選擇信號(hào) H:數(shù)據(jù)寄存器 L:指令寄存器
- sbit e =P2^7; //片選信號(hào) 下降沿觸發(fā)
- /* ***********清零按鍵設(shè)置 ********/
- sbit key1 = P3^6;
- sbit key2 = P3^7;
- sbit key3 = P1^2;
- #define SlaveAddress 0xA6 /*定義器件在IIC總線中的從地址,根據(jù)ALT ADDRESS地址引腳不同修改ALT ADDRESS引腳接地時(shí)地址為0xA6,接電源時(shí)地址為0x3A*/
- long bushu,zong; //步數(shù)
- uchar BUF[8]; //接收數(shù)據(jù)緩存區(qū)
- uchar ge,shi,bai,qian,wan; //顯示變量
- int dis_data; //變量
- int c;
- int s;
- int h=30.5;
- void Multiple_Read_ADXL345(); //連續(xù)的讀取內(nèi)部寄存器數(shù)據(jù)
- #define RdCommand 0x01 //定義ISP的操作命令
- #define PrgCommand 0x02
- #define EraseCommand 0x03
- #define Error 1
- #define Ok 0
- #define WaitTime 0x01 //定義CPU的等待時(shí)間
- sfr ISP_DATA=0xe2; //寄存器申明
- sfr ISP_ADDRH=0xe3;
- sfr ISP_ADDRL=0xe4;
- sfr ISP_CMD=0xe5;
- sfr ISP_TRIG=0xe6;
- sfr ISP_CONTR=0xe7;
- uchar a_a;
- /**************打開 ISP,IAP 功能 ********* */
- void ISP_IAP_enable(void)
- EA = 0; //關(guān)中斷
- ISP_CONTR = ISP_CONTR & 0x18; // 0001,1000
- ISP_CONTR = ISP_CONTR | WaitTime; // 寫入硬件延時(shí)
- ISP_CONTR = ISP_CONTR | 0x80; // ISPEN=1
- /************** 關(guān)閉 ISP,IAP 功能 *************** */
- void ISP_IAP_disable(void)
- ISP_CONTR = ISP_CONTR & 0x7f; // ISPEN = 0
- ISP_TRIG = 0x00;
- EA = 1; // 開中斷
- /*****************公用的觸發(fā)代碼********* */
- void ISPgoon(void)
- ISP_IAP_enable(); //打開 ISP,IAP 功能
- ISP_TRIG = 0x46; //觸發(fā)ISP_IAP命令字節(jié)1
- ISP_TRIG = 0xb9; //觸發(fā)ISP_IAP命令字節(jié)2
- _nop_();
- /**********字節(jié)讀 *********** */
- unsigned char byte_read(unsigned int byte_addr)
- EA = 0;
- ISP_ADDRH = (unsigned char)(byte_addr >> 8); // 地址賦值
- ISP_ADDRL = (unsigned char)(byte_addr & 0x00ff);
- ISP_CMD = ISP_CMD & 0xf8; //清除低3位
- ISP_CMD = ISP_CMD | RdCommand; // 寫入讀命令
- ISPgoon(); //觸發(fā)執(zhí)行
- ISP_IAP_disable(); // 關(guān)閉ISP,IAP功能
- EA = 1;
- return (ISP_DATA); // 返回讀到的數(shù)據(jù)
- /************ 扇區(qū)擦除*********** */
- void SectorErase(unsigned int sector_addr)
- unsigned int iSectorAddr;
- iSectorAddr = (sector_addr & 0xfe00); // 取扇區(qū)地址
- ISP_ADDRH = (unsigned char)(iSectorAddr >> 8);
- ISP_ADDRL = 0x00;
- ISP_CMD = ISP_CMD & 0xf8; //清空低3位
- ISP_CMD = ISP_CMD | EraseCommand; //擦除命令3
- ISP_IAP_disable(); //關(guān)閉ISP,IAP功能
- /********** 字節(jié)寫 ******* */
- void byte_write(unsigned int byte_addr, unsigned char original_data)
- EA = 0;
- // SectorErase(byte_addr);
- ISP_ADDRH = (unsigned char)(byte_addr >> 8); // 取地址
- ISP_CMD = ISP_CMD & 0xf8; // 清低3位
- ISP_CMD = ISP_CMD | PrgCommand; //寫命令2
- ISP_DATA = original_data; //寫入數(shù)據(jù)準(zhǔn)備
- ISP_IAP_disable(); //關(guān)閉IAP功能
- EA =1;
- /**********把數(shù)據(jù)保存到單片機(jī)內(nèi)部eeprom中**************/
- void write_eeprom() //保存數(shù)據(jù)
- SectorErase(0x2000);
- byte_write(0x2000, bushu);
- byte_write(0x2001, bushu >> 8);
- byte_write(0x2002, bushu >> 16);
- byte_write(0x2003, zong);
- byte_write(0x2004, zong >> 8);
- byte_write(0x2005, zong >> 16);
- byte_write(0x2055, a_a);
- /******************把數(shù)據(jù)從單片機(jī)內(nèi)部eeprom中讀出來(lái)*****************/
- void read_eeprom() //讀出保存數(shù)據(jù)
- bushu = byte_read(0x2002);
- bushu <<= 8;
- bushu |= byte_read(0x2001);
- bushu <<= 8;
- bushu |= byte_read(0x2000);
- zong = byte_read(0x2005);
- zong <<= 8;
- zong |= byte_read(0x2004);
- zong <<= 8;
- zong |= byte_read(0x2003);
- a_a = byte_read(0x2055);
- /**************開機(jī)自檢eeprom初始化*****************/
- void init_eeprom() //開始初始化保存的數(shù)據(jù)
- read_eeprom(); //讀出保存數(shù)據(jù)
- if(a_a != 14) //新的單片機(jī)初始單片機(jī)內(nèi)問(wèn)eeprom
- zong = 0;
- bushu = 0;
- a_a = 14;
- write_eeprom(); //保存數(shù)據(jù)
- void conversion(uint temp_data)
- wan=temp_data/10000+0x30 ;
- temp_data=temp_data%10000; //取余運(yùn)算
- qian=temp_data/1000+0x30 ;
- temp_data=temp_data%1000; //取余運(yùn)算
- bai=temp_data/100+0x30 ;
- temp_data=temp_data%100; //取余運(yùn)算
- shi=temp_data/10+0x30 ;
- temp_data=temp_data%10; //取余運(yùn)算
- ge=temp_data+0x30;
- void delay_1ms(uint q)
- uint i,j;
- for(i=0;i<q;i++)
- for(j=0;j<120;j++);
- void delay_uint(uint q)
- while(q--);
- void write_com(uchar com)
- e=0;
- rs=0;
- rw=0;
- P0=com;
- delay_uint(25);
- e=1;
- delay_uint(100);
- e=0;
- void write_data(uchar dat)
- e=0;
- rs=1;
- rw=0;
- P0=dat;
- delay_uint(25);
- e=1;
- delay_uint(100);
- e=0;
- /***********lcd1602上顯示十進(jìn)制數(shù)************/
- void write_bushu(uchar hang,uchar add,long date)
- if(hang==1)
- write_com(0x80+add);
- else
- write_com(0x80+0x40+add);
- if(date >= 1000000)
- write_data(0x30+date/1000000%10);
- if(date >= 100000)
- write_data(0x30+date/100000%10);
- if(date >= 10000)
- write_data(0x30+date/10000%10);
- if(date >= 1000)
- write_data(0x30+date/1000%10);
- if(date >= 100)
- write_data(0x30+date/100%10);
- if(date >= 10)
- write_data(0x30+date/10%10);
- write_data(0x30+date%10);
- /*************lcd1602上顯示這字符函數(shù)**************/
- void write_string(uchar hang,uchar add,uchar *p)
- if(hang==1)
- else
- while(1)
- if(*p == '\0') break;
- write_data(*p);
- p++;
- /***********lcd1602初始化設(shè)置*************/
- void init_1602() //lcd1602初始化
- write_com(0x38);
- write_com(0x0c);
- write_com(0x06);
- delay_uint(1000);
- write_string(1,0,"B:0 Z:0 ");
- write_string(2,0,"S:0 C:0 ");
- /**********lcd1602上顯示特定的字符***********/
- void write_zifu(uchar hang,uchar add,uchar date)
- if(hang==1)
- else
- write_data(date);
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- void Delay5ms()
- uint n = 560;
- while (n--);
- /*********起始信號(hào)************/
- void ADXL345_Start()
- SDA = 1; //拉高數(shù)據(jù)線
- SCL = 1; //拉高時(shí)鐘線
- Delay5us(); //延時(shí)
- SDA = 0; //產(chǎn)生下降沿
- SCL = 0; //拉低時(shí)鐘線
- /******停止信號(hào)********/
- void ADXL345_Stop()
- SDA = 0; //拉低數(shù)據(jù)線
- SDA = 1; //產(chǎn)生上升沿
- /********發(fā)送應(yīng)答信號(hào) 入口參數(shù):ack (0:ACK 1:NAK)**********/
- void ADXL345_SendACK(bit ack)
- SDA = ack; //寫應(yīng)答信號(hào)
- 接收應(yīng)答信號(hào)
- bit ADXL345_RecvACK()
- CY = SDA; //讀應(yīng)答信號(hào)
- return CY;
- 向IIC總線發(fā)送一個(gè)字節(jié)數(shù)據(jù)
- void ADXL345_SendByte(uchar dat)
- uchar i;
- for (i=0; i<8; i++) //8位計(jì)數(shù)器
- dat <<= 1; //移出數(shù)據(jù)的最高位
- SDA = CY; //送數(shù)據(jù)口
- ADXL345_RecvACK();
- /*************從IIC總線接收一個(gè)字節(jié)數(shù)據(jù)*******/
- uchar ADXL345_RecvByte()
- uchar i;
- uchar dat = 0;
- SDA = 1; //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
- dat <<= 1;
- dat |= SDA; //讀數(shù)據(jù)
- return dat;
- //******單字節(jié)寫入***********//
- void Single_Write_ADXL345(uchar REG_Address,uchar REG_data)
- ADXL345_Start(); //起始信號(hào)
- ADXL345_SendByte(SlaveAddress); //發(fā)送設(shè)備地址+寫信號(hào)
- ADXL345_SendByte(REG_Address); //內(nèi)部寄存器地址,參考中文pdf22頁(yè)
- ADXL345_SendByte(REG_data); //內(nèi)部寄存器數(shù)據(jù),參考中文pdf22頁(yè)
- ADXL345_Stop(); //發(fā)送停止信號(hào)
- //********單字節(jié)讀取************//
- uchar Single_Read_ADXL345(uchar REG_Address)
- { uchar REG_data;
- ADXL345_SendByte(REG_Address); //發(fā)送存儲(chǔ)單元地址,從0開始
- ADXL345_SendByte(SlaveAddress+1); //發(fā)送設(shè)備地址+讀信號(hào)
- REG_data=ADXL345_RecvByte(); //讀出寄存器數(shù)據(jù)
- ADXL345_SendACK(1);
- ADXL345_Stop(); //停止信號(hào)
- return REG_data;
- //*****連續(xù)讀出ADXL345內(nèi)部加速度數(shù)據(jù),地址范圍0x32~0x37*****//
- void Multiple_read_ADXL345(void)
- { uchar i;
- ADXL345_SendByte(0x32); //發(fā)送存儲(chǔ)單元地址,從0x32開始
- for (i=0; i<6; i++) //連續(xù)讀取6個(gè)地址數(shù)據(jù),存儲(chǔ)中BUF
- BUF[i] = ADXL345_RecvByte(); //BUF[0]存儲(chǔ)0x32地址中的數(shù)據(jù)
- if (i == 5)
- ADXL345_SendACK(1); //最后一個(gè)數(shù)據(jù)需要回NOACK
- else
- ADXL345_SendACK(0); //回應(yīng)ACK
- Delay5ms();
- //******初始化ADXL345,根據(jù)需要請(qǐng)參考pdf進(jìn)行修改***//
- void Init_ADXL345()
- Single_Write_ADXL345(0x31,0x0B); //測(cè)量范圍,正負(fù)16g,13位模式
- Single_Write_ADXL345(0x2C,0x08); //速率設(shè)定為12.5 參考pdf13頁(yè)
- Single_Write_ADXL345(0x2D,0x08); //選擇電源模式 參考pdf24頁(yè)
- Single_Write_ADXL345(0x2E,0x80); //使能 DATA_READY 中斷
- Single_Write_ADXL345(0x1E,0x00); //X 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫入pdf29頁(yè)
- Single_Write_ADXL345(0x1F,0x00); //Y 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫入pdf29頁(yè)
- Single_Write_ADXL345(0x20,0x05); //Z 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫入pdf29頁(yè)
- //*******顯示x軸*******//
- void display_y()
- static uchar flag_en,flag_fu;
- float temp;
- dis_data=(BUF[3]<<8)+BUF[2]; //合成數(shù)據(jù)
- if(dis_data<0)
- dis_data=-dis_data;
- flag_fu = 1;
- else
- flag_en = 1;
- flag_fu = 0;
- temp=(float)dis_data*3.9; //計(jì)算數(shù)據(jù)和顯示,查考ADXL345快速入門第4頁(yè)
- if(temp > 100) //步數(shù)加1
- if((flag_en == 1) && (flag_fu == 1))
- flag_en = 0;
- bushu ++;
- zong ++;
- s=bushu*h;
- c=bushu*1.5;
- write_bushu(1,2,bushu); //顯示步數(shù)
- write_bushu(1,11,zong); //顯示總步數(shù)
- write_bushu(2,2,s);
- write_bushu(2,11,c);
- if(temp < 70)
- flag_en = 1;
- //******按鍵控制程序*******//
- void key()
- if(key1 == 0)
- delay_1ms(1);
- if(key1 == 0)
- zong = 0;
- write_string(1,11," ");
- while(key1 == 0); //松手檢測(cè)
- if(key2 == 0)
- delay_1ms(1);
- if(key2 == 0)
- bushu = 0;
- write_string(1,2," ");
- while(key2 == 0); //松手檢測(cè)
- //******主程序********//
- void main()
- static uint flag_value;
- uchar devid;
- init_1602(); //lcd1602初始化
- Init_ADXL345(); //初始化ADXL345
- devid=Single_Read_ADXL345(0X00); //讀出的數(shù)據(jù)為0XE5,表示正確
- delay_1ms(20);
- init_eeprom(); //開始初始化保存的數(shù)據(jù)
- bushu=0;
- while(1) //循環(huán)
- if(key3==0)
- {delay_1ms(1);
- if(key3==0)
- h=h+1.5;}
- if(h==38)
- { h=30.5;}
- key(); //按鍵程序
- flag_value ++;
- if(flag_value >= 100) //100ms
- flag_value = 0;
- if(devid!=0XE5)
- write_string(2,11,"error");
- else
- Multiple_Read_ADXL345(); //連續(xù)讀出數(shù)據(jù),存儲(chǔ)在BUF中
- display_y(); //---------顯示Y軸
- delay_1ms(1); //延時(shí)
2、程序.rar
(133.75 KB, 下載次數(shù): 90)
2018-4-25 11:24 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
