查看: 1713|回復(fù): 0
msp430計(jì)算機(jī)小程序
ID:325084 發(fā)表于 2018-5-8 15:26 | 顯示全部樓層 |閱讀模式
  1. #include <msp430x22x4.h>
  2. #include<math.h>
  4. #define ep_1 (P4OUT|=BIT3)
  5. #define ep_0 (P4OUT&=~BIT3)
  6. #define rs_1 (P4OUT|=BIT4)
  7. #define rs_0 (P4OUT&=~BIT4)
  8. #define rw_1 (P4OUT|=BIT5)
  9. #define rw_0 (P4OUT&=~BIT5)
  10. double d4=0,x,y,z;
  11. long int i,k;
  12. int key,keyz,keyzz,key,f1,key1;
  13. long int
  14. a,d1=0,d2=0,d3=0,d5=0,d6,d=0,f=0,i,n,flag=0,flag1=0,flag2=0,flag3=0,flag4=0,flag5
  15. =0,flag6=0,flag7=0,flag8=0,h0=11,h1=25,h2=40,h3=0,h4=0,t1=0,t2=0,g;
  16. //............................................................................... void lcd_wcmd(uchar); //
  17. void lcd_pos(uchar);
  18. void lcd_wdat(uchar);
  19. void delay(int ms);
  20. void delayl(int s);
  21. int key_pass();
  22. int inot(void);
  23. double p2(double x)  //開(kāi)方
  24. {    y=sqrt(x);
  25. z=y;
  26.   y=y*y;
  27.   if(y>x)
  28.    {do
  29.       {  z=z-0.0001;
  30.        y=z*z;       }
  31.       while(y>x);
  32.   return z;}
  33.       else if(y==x)
  34. return  z;
  35.   else //if(y<x)
  36.    {do
  37.            {z=z+0.0001;
  38.   y=z*z;       }
  39. while(y<x);
  40. return z;       }
  41.     }
  42. //.............................. 測(cè)試LCD忙碌狀態(tài)................
  43. int inot(void)    //初始化
  44. {
  45.     WDTCTL = WDTPW + WDTHOLD;   //關(guān)看門(mén)狗
  46.     BCSCTL1 = CALBC1_16MHZ;   //設(shè)定DCO為1MHZ
  47. DCOCTL = CALBC1_16MHZ;
  48.     P1DIR&=~0x0f;//////寄存器,決定對(duì)應(yīng)口的的輸入輸出狀態(tài)
  49. P1DIR|=0xf0;// 將P1.4 P1.5 P1.6 P1.7設(shè)置為輸出方向
  50.   P1OUT=0x00;//先輸出低電平
  51.    P2DIR&=~0x00;
  52.    P2DIR|=0xFf;// 將P2.0 P2.1 P2,2 P2.3設(shè)置為輸出方向
  53. P3DIR |=0xff; //P3輸出
  54. P3OUT =0x00;
  55.    P4DIR |=0xff; //P4輸出
  56. P4OUT =0x00;
  57.   P1IE = 0;
  58. P1IES = 0;
  59.   P1IFG = 0;
  60. P1IE |= BIT0;
  61.   P1IES|= BIT0;
  62. P1IE |= BIT1;
  63.    P1IES|= BIT1;
  64. P1IE |= BIT2;
  65. P1IES|= BIT2;
  66. P1IE |= BIT3;
  67. P1IES |= BIT3;
  68.   return 0;
  69. }
  70. void delay(int ms)   //延時(shí) 可能不要
  71. {
  72. while(ms--)
  73. {
  74.     for(i=0;i<=16000;i++);
  75.   }
  76. }
  77. /*void delayl(int s)
  78. {
  79.   while(s--)
  80. {
  81.     delay(100);   }
  82. } */
  83. //.............................. 測(cè)試LCD忙碌狀態(tài)
  84. int lcd_bz()
  85. {
  86. P3DIR&=~BIT7;
  87. int result=0;
  88.   rs_0;
  89. rw_1;
  90. ep_1;
  91. result =(result||(P3IN & 0x80));
  92. ep_0;
  93.   P3DIR|=0xff;
  94. return result;
  95. }
  96. void lcd_wcmd(uchar cmd)
  97. {
  98. while(lcd_bz());
  99.    rs_0;
  100.   rw_0;
  101. ep_0;
  102. P3OUT = cmd;
  103. ep_1;
  104. ep_0;
  105. delay(5); }
  106. void lcd_pos(uchar pos)
  107. {
  108. lcd_wcmd(pos | 0x80);
  109. delay(5); }
  110. void lcd_wdat(uchar dat)
  111. {         while(lcd_bz());
  112. rs_1;
  113. rw_0;
  114. ep_0;
  115.   P3OUT = dat;
  116. ep_1;
  117. ep_0;  }
  118. void lcd_init()
  119. {
  120. lcd_wcmd(0x38);                        //function
  121. set  delay(10);
  122. lcd_wcmd(0x38);                        //function
  123. set  delay(10);
  124. lcd_wcmd(0x0c);                        //display on/off
  125. delay(10);
  126. lcd_wcmd(0x06);                        //entry mode set
  127. delay(10);
  128. lcd_wcmd(0x01);                        //清除LCD的顯示內(nèi)容
  129. delay(10); }
  130. int key_pass()//鍵盤(pán)分析
  131. {
  132.   int keyz;
  133. int key;
  134.   key=(P1IN&0x0f);
  135. switch(key)   {
  136.   case 0x0e:
  137.   // delay(5);
  138.     P2OUT |=BIT0;
  139.     if((P1IN&BIT0)==0x01)
  140. delay(10);
  141.      if((P1IN&BIT0)==0x01)
  142.   { keyz=10;break;}
  143.      P2OUT |=BIT1;
  144.   if((P1IN&BIT0)==0x01)
  145. delay(10);
  146.      if((P1IN&BIT0)==0x01)
  147.      {keyz=11;
  148. break;}
  149.      P2OUT |=BIT2;
  150.     if((P1IN&BIT0)==0x01)
  151. delay(10);
  152.      if((P1IN&BIT0)==0x01)
  153.    { keyz=12;
  154. break;}
  155. P2OUT |=BIT5;
  156. if((P1IN&BIT0)==0x01)
  157. delay(10);
  158.   if((P1IN&BIT0)==0x01)
  159.    { keyz=13;
  160. break;}
  161. break;
  162.     case 0x0d:
  163.     P2OUT |=BIT0;
  164. if((P1IN&BIT1)==0x02)
  165. delay(10);
  166.     if((P1IN&BIT1)==0x02)
  167.    { keyz=3;
  168. break;}
  169.      P2OUT |=BIT1;
  170. if((P1IN&BIT1)==0x02)
  171.    delay(10);
  172.      if((P1IN&BIT1)==0x02)
  173.     {keyz=6;
  174. break;}
  175.      P2OUT |=BIT2;
  176.   if((P1IN&BIT1)==0x02)
  177. delay(10);
  178. if((P1IN&BIT1)==0x02)
  179.     { keyz=9;
  180. break;}
  181.      P2OUT |=BIT5;
  182.   if((P1IN&BIT1)==0x02)
  183. delay(10);
  184.      if((P1IN&BIT1)==0x02)
  185.     { keyz=15;
  186. break;}
  187.    break;
  188.   case 0x0b:
  189.     P2OUT |=BIT0;
  190.     if((P1IN&BIT2)==0x04)
  191.    delay(10);
  192.      if((P1IN&BIT2)==0x04)
  193.    {keyz=2;
  194. break;}
  195.      P2OUT |=BIT1;
  196.   if((P1IN&BIT2)==0x04)
  197. delay(10);
  198.      if((P1IN&BIT2)==0x04)
  199. { keyz=5;
  200. break;}
  201. P2OUT |=BIT2;
  202.     if((P1IN&BIT2)==0x04)
  203.   delay(10);
  204.       if((P1IN&BIT2)==0x04)
  205.     {   keyz=8;break;}
  206.      P2OUT |=BIT5;
  207. if((P1IN&BIT2)==0x04)
  208.   delay(10);
  209.       if((P1IN&BIT2)==0x04)
  210.      { keyz=0;
  211. break;}
  212.     case 0x07:
  213.     P2OUT |=BIT0;
  214.     if((P1IN&BIT3)==0x08)
  215. delay(10);
  216.      if((P1IN&BIT3)==0x08)
  217. {  keyz=1;break;}
  218.      P2OUT |=BIT1;
  219.     if((P1IN&BIT3)==0x08)
  220.   delay(10);
  221.      if((P1IN&BIT3)==0x08)
  222.    { keyz=4;
  223. break;}
  224.      P2OUT |=BIT2;
  225.     if((P1IN&BIT3)==0x08)
  226. delay(10);
  227.      if((P1IN&BIT3)==0x08)
  228. {keyz=7;
  229. break;}
  230. P2OUT |=BIT5;
  231.     if((P1IN&BIT3)==0x08)
  232.    delay(10);
  233.     if((P1IN&BIT3)==0x08)
  234.   { keyz=14;
  235. break;}
  236. default:
  237. keyz=16;
  238. break;   }
  239.   P2OUT&=~0xfF;
  240. return keyz;   }
  241. #pragma vector=PORT1 VECTOR
  242. interrupt void PORT1_ISR(void)
  243.   {
  244.   int key_pass();
  245. key=key_pass();
  246. if(key==14)
  247.   flag6=1;
  248.   // else flag6=0;
  249. switch(key)
  250.   {
  251.   case 0:
  252.   lcd_wdat(0x30);   //寫(xiě)入字符顯示數(shù)據(jù)到LCD
  253. break;   case 1:
  254.   lcd_wdat(0x31);
  255.   break;
  256. case 2:
  257.   lcd_wdat(0x32);
  258. break;
  259. case 3:
  260. lcd_wdat(0x33);
  261.   break;
  262. case 4:
  263.   lcd_wdat(0x34);
  264.    break;
  265.   case 5:
  266.   lcd_wdat(0x35);
  267. break;
  268. case 6:
  269.   lcd_wdat(0x36);
  270. break;
  271.   case 7:
  272.   lcd_wdat(0x37);
  273. break;
  274.   case 8:
  275.   lcd_wdat(0x38);
  276. break;
  277. case 9:
  278.   lcd_wdat(0x39);
  279.   break;
  280.   case 10:
  281. if(flag6!=1)
  282.   {lcd_wdat('/');
  283. d=0;
  284. d2=d1;
  285.    flag=3;}
  286. else{ lcd_wdat('c');
  287.   flag=7;}
  288. break;
  289.   case 11:
  290. if(flag6!=1)
  291. {lcd_wdat('*');
  292. d=0;
  293. d2=d1;
  294.   flag=2;}
  295.    else {{lcd_wdat('?');
  296.    flag=6;}
  297. break;
  298.   case 12:
  299.   if(flag6!=1)
  300.    { lcd_wdat('-');
  301. d=0;
  302.        d2=d1;
  303. flag=1;}
  304. else {lcd_wdat('^');
  305.   flag=5;   }
  306.   break;
  307.   case 13:
  308.     if(flag6!=1)
  309.   {lcd_wdat('+');
  310. d=0;
  311. d2=d1;
  312. flag=0;}
  313.     else {
  314.       lcd_wdat(0xe8);
  315.       flag=4;     }
  316. break;
  317. case 14:
  318. //  lcd_wdat(246);
  319. //flag5=1;
  320. break;
  321.   default:
  322. break;
  323.   }}
  324. //if(flag5==1)  //  變功能 //
  325. flag=flag+4;
  326. if(flag==7)
  327. {lcd_wcmd(0x01);
  328.      d=0,key1=0,flag=flag1=flag2=flag3=flag4=flag5=flag6=0;
  329. i=k=0;d1=d2=d3=d4=d5=0;}
  330. if(key<10) {
  331.   d=key+d*10;}
  332. d1=d;
  333. if(d1!=d2) {
  334. if(key==15)
  335. { lcd_wdat('=');
  336.   delay(5);
  337. flag6=1;
  338.   lcd_pos(0x40);
  339.    lcd_wdat('A');//A   lcd_wdat('N');//
  340. N   lcd_wdat('S');//S   lcd_wdat(':');//
  341.     switch(flag)   {
  342.   case 0:d3=d2+d;break;
  343. case 1:d3=d2-d;break;
  344.   case 2:d3=d2*d;break;
  345. case 3:d4=d2*10000/d;
  346.     flag2=1;   //*d3=d2/d;
  347.    // d5=d2%d;
  348. break;
  349. case 4:d4=p2(d)
  350. flag2=0; break;
  351. case 5: d3=d*d;
  352. // flag2=0; break;
  353. case 6:  d4=10000/d;
  354. flag2=1;break;
  355.   /* case 7:   lcd_wcmd(0x01);
  356.      d=0,key1=0,flag=flag1=flag2=flag3=flag4=flag5=flag6=0;
  357.     i=k=0;d1=d2=d3=d4=d5=0;
  358.    break; */   default:break;   }
  359.   if(d3!=0)
  360. {f=d3;
  361.     lcd_wcmd(0x04);lcd_pos(0x4e);
  362.     while(f!=0) {
  363.              lcd_wdat(0x30+f%10);  f=f/10;            }       }
  364.   if(d4!=0)   {
  365.     switch(flag2)  (
  366. case 0:d4=d4*10000;
  367. f=d4;      f1=f%10000;     f=f/10000;
  368.     lcd_wcmd(0x04); lcd_pos(0x4e);   i=4;
  369. if(f1!=0)     { while(i--)
  370. {
  371.     lcd_wdat(0x30+f1%10);
  372.     f1=f1/10;  }
  373.       lcd_wdat('.');}
  374.    while(f!=0) {
  375.    lcd_wdat(0x30+f%10);
  376.   f=f/10;}
  377.   break;
  378.   case 1:      d4=d4;     f=d4;
  379.   f1=f%10000;
  380.    f=f/10000;
  381. lcd_wcmd(0x04);
  382. lcd_pos(0x4e);
  383.   i=4;
  384.     if(f1!=0)
  385. { while(i--)
  386.     {
  387.        lcd_wdat(0x30+f1%10);
  388. f1=f1/10; }
  389.       lcd_wdat('.');}
  390. while(f!=0)  {
  391.    lcd_wdat(0x30+f%10);
  392. f=f/10;    }
  393. if(d4<10000)
  394. lcd_wdat('0');
  395.    break;
  396.       default:break;}
  397.    }   }
  398.    while(1)     {
  399.     if((P1IN&0x0f)==0x0f)     break;     }
  400.   if(P1IFG & BIT0)
  401.    {
  402.          P1IFG &= ~(BIT0);// 清除中斷標(biāo)志位    }
  403.     if(P1IFG & BIT1)
  404.     {
  405.          P1IFG &= ~(BIT1);// 清除中斷標(biāo)志位     }
  406.     if(P1IFG & BIT2)     {
  407.          P1IFG &= ~(BIT2);// 清除中斷標(biāo)志位
  408.   }
  409.      if(P1IFG & BIT3)
  410.   {
  411.          P1IFG &= ~(BIT3);// 清除中斷標(biāo)志位     }
  412.    /*if(flag6==1) {if(key!=0)
  413. {lcd_wcmd(0x01);flag6=0; d=0;} }*/ }
  414. void main()
  415. {
  416. inot();  _DINT();   lcd_init();
  417.   lcd_wcmd(0x01);   lcd_wcmd(0x06);
  418. lcd_pos(0x05);   lcd_wdat(0x57);
  419. //W   lcd_wdat(0x65);//e   lcd_wdat(0x6c);//l   lcd_wdat(0x63);//c   lcd_wdat(0x6f);//o   lcd_wdat(0x6d);//m   lcd_wdat(0x65);//e   delay(50);
  420.    lcd_wcmd(0x01);
  421.   _EINT();   while(1)
  422.   {  _BIS_SR(CPUOFF);
  423.   _NOP(); }   }
