這是郭天祥的示例程序,因?yàn)榘存I掃描程序用了while死循環(huán)等待按鍵松手,此時(shí)除了中斷程序,其他程序都不能執(zhí)行。可以把數(shù)碼管顯示程序放到中斷里,中斷周期改為5ms就行了。
#include<reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit key1=P3^4;
sbit key2=P3^5;
sbit key3=P3^6;
sbit key4=P3^7;
uchar num1,shi,ge;
int num;
bit flag=0;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71
void keyscan();
void delay(uint);
void display(uchar);
TMOD=0x01;
// TH0=(65536-45872)/256;
// TL0=(65536-45872)%256;
TH0=(65536-4608)/256;
TL0=(65536-4608)%256;
EA=1;
ET0=1;
TR0=1;
// display(num);
keyscan();
void keyscan()
if(key1==0)
delay(10);
if(key1==0)
num++;
if(num==60)
num=0;
while(!key1);
if(key2==0)
delay(10);
if(key2==0)
num--;
if(num==-1)
num=59;
while(!key2);
if(key3==0)
delay(10);
if(key3==0)
num=0;
while(!key3);
if(key4==0)
delay(10);
if(key4==0)
flag=~flag;
while(!key4);
void display(uchar num)
static bit sign=0;
shi=num/10;
ge=num%10;
P0=0x00;//消隱
dula=1;
dula=0;
if(sign==0)
P0=0xfe;
wela=1;
wela=0;
P0=table[shi];
dula=1;
dula=0;
sign=~sign;
P0=0xfd;
wela=1;
wela=0;
P0=table[ge];
dula=1;
dula=0;
sign=~sign;
void delay(uint xms)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
void T0_time() interrupt 1
if(flag==1)
num1++;
if(num1==200)
num1=0;
num++;
if(num==60)
num=0;
display(num);
