仿真圖+源代碼
仿真
- date 2018年11月
- #include <reg52.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit ADC_CS=P1^0;
- sbit ADC_CLK=P1^4;
- sbit ADC_DO= P1^6;
- sbit ADC_DI=P1^5;
- uchar voltage[4]={0,0,0,0};//voltage數(shù)組用于存放最后可用來(lái)顯示的各個(gè)位上的數(shù)字
- uchar encode[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};//共陽(yáng)
- void delay(uint xms)
- uint i = 0;
- uint j = 0;
- for(i=0;i<xms;i++)
- for(j=0;j<114;j++);
- //使用定時(shí)器0,工作方式1,定時(shí)5ms,使用定時(shí)器中斷
- void Timer0Set(void)
- TMOD = 0x01;//使用定時(shí)器0工作方式1
- TH0 = (65536-5000)/256;
- TL0 = (65536-5000)%256;
- ET0 = 1;
- EA = 1;
- TR0 = 1;
- //讀取DAC0832的值
- uchar GetVoltage(uchar channel)//形參是選擇的通道
- uchar tmp =0,i = 0;//tmp作為本子函數(shù)的返回值
- ADC_CS=0; //片選,DO為高阻態(tài)
- ADC_DO=0;
- delay(2);
- //三個(gè)脈沖
- ADC_CLK=0;
- delay(2);
- ADC_DI=1;
- ADC_CLK=1;//第一個(gè)脈沖,起始位
- delay(2);
- ADC_CLK=0;
- delay(2);
- ADC_DI=1;
- ADC_CLK=1;//第二個(gè)脈沖,DI=1表示雙通道單極性輸入
- delay(2);
- ADC_CLK=0;
- delay(2);
- ADC_DI=channel; //第三個(gè)脈沖,DI=1表示選擇通道1(CH2),DI=0表示選擇通道0(CH1)
- ADC_CLK=1;
- delay(2);
- ADC_DI=0; //DI轉(zhuǎn)為高阻態(tài),失去輸入意義
- ADC_DO=1; //DO脫離高阻態(tài)為輸出數(shù)據(jù)做準(zhǔn)備
- ADC_CLK=1;
- delay(2);
- ADC_CLK=0; //第一個(gè)下降沿,為去數(shù)做準(zhǔn)備
- delay(2);//這里加一個(gè)脈沖AD才能正確獨(dú)處數(shù)據(jù),不加的話獨(dú)處的 數(shù)據(jù)少一位,且是錯(cuò)的
- //轉(zhuǎn)換成8位的二進(jìn)制數(shù)
- for(i=0;i<8;i++)
- ADC_CLK = 1;
- _nop_();
- ADC_CLK = 0;
- if(ADC_DO)//如果DO是真值,就tmp的相應(yīng)的位數(shù)是1,先輸出的是最高位,最后輸出的是最低位
- tmp = tmp | 1<<(7-i);
- ADC_CS = 1;//關(guān)閉片選,結(jié)束一個(gè)轉(zhuǎn)換周期
- return tmp;
- //把讀取出來(lái)的數(shù)字量轉(zhuǎn)換成實(shí)際的溫度值然后保存在voltage數(shù)組中
- void PrintToBuffer(uchar digit)
- //計(jì)算公式:電壓=5/256*digit,因?yàn)榻Y(jié)果又兩位小數(shù),統(tǒng)一將數(shù)據(jù)放大100倍進(jìn)行運(yùn)算,就可以避免浮點(diǎn)數(shù)運(yùn)算.
- unsigned long val= (unsigned long int)5*200*digit/256;
- voltage[0] = val/1000;//千位
- voltage[1] = val/100;//百位
- voltage[2] = val/10%10;//十位
- voltage[3] = val%10;//個(gè)位
- void main(void)
- Timer0Set();
- while(1)
- PrintToBuffer(GetVoltage(0));//GetVoltage()獲取到的數(shù)據(jù)量*1.0/256計(jì)算出實(shí)際電壓
- delay(50);//每50ms進(jìn)行計(jì)算一次
- void Timer0_Init() interrupt 1
- static uchar pos = 0;//當(dāng)前掃描第幾個(gè)數(shù)碼管
- P3 = 0xF0;
- //如果是第2位數(shù)碼管則顯示dp
- P2 = encode[voltage[pos]] & ((pos == 1)?(0x7F):(0xFF));//段選
- P3 = (1<<pos);//位選
- pos = (pos + 1)%4;
ADC0834簡(jiǎn)易數(shù)字電壓表.rar
(61.36 KB, 下載次數(shù): 112)
2018-5-11 00:51 上傳
點(diǎn)擊文件名下載附件
