查看: 9003|回復: 20
為什么這個單片機程序獨立按鍵長按才起作用
ID:272459 發(fā)表于 2018-5-16 14:17 | 顯示全部樓層 |閱讀模式
程序是我這里復制的,按鍵程序是我自己寫的,求大神幫看下,為什么按鍵要長按下 才有反應;
  1. while (1)
  2.     {
  3.            if (flag1s)  //每秒更新一次溫度
  4.           {
  5.                   LcdShowStr(0, 1, "WD:");        //顯示到液晶屏上
  6.               LcdShowStr(6, 1, "SD:");        //顯示到液晶屏上
  7.               LcdShowStr(0, 0, "F:");
  8.            DHT_Start();
  9.                         tmp1=DHT_ByteRead(&DHT);
  10.                    if(tmp1==1)
  11.                    {
  12.                    str[0] = (DHT[0]/10)%10 + '0';  //十位轉(zhuǎn)為ASCII碼
  13.            str[1] = (DHT[0]%10) + '0';  //個位轉(zhuǎn)為ASCII
  14.                str[2] = '\0';
  15.                    LcdShowStr(9, 1, str);
  16.                    str[0] = (DHT[2]/10)%10 + '0';  //十位轉(zhuǎn)為ASCII碼
  17.            str[1] = (DHT[2]%10) + '0';  //個位轉(zhuǎn)為ASCII
  18.            str[2] = '\0';
  19.                LcdShowStr(3,1, str);
  20.                    WD= DHT[2];
  21.                    SD=DHT[0];
  22.                   temp2=adc0832(voc);
  23.                   if(temp2==1)
  24.                    {str[0] =  voc/1000 + '0';
  25.            str[1] = (voc%1000)/100 + '0';
  26.                    str[2] = ((voc%1000)%100)/10 + '0';
  27.                    str[3] = ('.')  ;
  28.                    str[4] = ((voc%1000)%100)%10 + '0';
  29.                    str[5] = '\0';
  30.                LcdShowStr(2, 0, str);
  31.
  32.                   }
  33.
  34.                    }
  35.
  36.
  37.                 key();
  38.         }
  39.
  40.
  41.
  42.
  43.
  44.
  45. }
  46.
  47. }
  48. void key (void)
  49. {                 unsigned char str[12];
  50.
  51. if(Key1==0)
  52.                 {
  53.                  set++;
  54.                   delay();
  55.                   if(set==1)
  56.                     LcdShowStr(7, 0, "STH:");
  57.                   if(set==2)
  58.                     LcdShowStr(7, 0, "STL:");
  59.                   if(set==3)
  60.                     LcdShowStr(7, 0, "SRH:");
  61.                   if(set==4)
  62.                     LcdShowStr(7, 0, "SRL:");
  63.                   if(set==5)
  64.                     LcdShowStr(7, 0, "VOC:");
  65.                 if(set>=6)
  66.                 set=0;
  67.         while(!Key1);
  68.                 }
  69.                 if(Key2==0)
  70.                 {
  71.                 if(set==1)
  72.                 {
  73.                  STH++;
  74.                    str[0] = (STH/10)%10 + '0';
  75.            str[1] = (STH%10) + '0';
  76.            str[2] = '\0';
  77.                LcdShowStr(11, 0, str);
  78.                 }
  79.                 if(set==2)
  80.                 {
  81.                  STL++;
  82.                    str[0] = (STL/10)%10 + '0';
  83.            str[1] = (STL%10) + '0';
  84.            str[2] = '\0';
  85.                LcdShowStr(11,0, str);
  86.                 }
  87.                 if(set==3)
  88.                 {
  89.                  SRH++;
  90.                    str[0] = (SRH/10)%10 + '0';
  91.            str[1] = (SRH%10) + '0';
  92.            str[2] = '\0';
  93.                LcdShowStr(11, 0, str);
  94.                 }
  95.                                 if(set==4)
  96.                 {
  97.                   SRL++;
  98.                    str[0] = (SRL/10)%10 + '0';
  99.            str[1] = (SRL%10) + '0';
  100.            str[2] = '\0';
  101.                LcdShowStr(11, 0, str);
  102.                 }
  103.                         if(set==5)
  104.                 {
  105.                   VOC++;
  106.                    str[0] = (VOC/10)%10 + '0';
  107.            str[1] = (VOC%10) + '0';
  108.            str[2] = '\0';
  109.                LcdShowStr(11, 0, str);
  110.                 }
  111.                   delay();
  112.                 }
  113.                 if(Key3==0)
  114.                 {
  115.                                  if(set==1)
  116.                 {
  117.                  STH--;
  118.                  str[0] = (STH/10)%10 + '0';
  119.            str[1] = (STH%10) + '0';
  120.            str[2] = '\0';
  121.                LcdShowStr(11, 0, str);
  122.                 }
  123.                                 if(set==2)
  124.                 {
  125.                   STL--;
  126.                   str[0] = (STL/10)%10 + '0';
  127.            str[1] = (STL%10) + '0';
  128.            str[2] = '\0';
  129.                LcdShowStr(11, 0, str);
  130.                 }
  131.                                 if(set==3)
  132.                 {
  133.                  SRH--;
  134.                  str[0] = (SRH/10)%10 + '0';
  135.            str[1] = (SRH%10) + '0';
  136.            str[2] = '\0';
  137.                LcdShowStr(11, 0, str);
  138.                 }
  139.                                 if(set==4)
  140.                 {
  141.                  SRL--;
  142.                  str[0] = (SRL/10)%10 + '0';
  143.            str[1] = (SRL%10) + '0';
  144.            str[2] = '\0';
  145.                LcdShowStr(11, 0, str);
  146.                 }
  147.                 if(set==5)
  148.                 {
  149.                  VOC--;
  150.                  str[0] = (VOC/10)%10 + '0';
  151.            str[1] = (VOC%10) + '0';
  152.            str[2] = '\0';
  153.                LcdShowStr(11, 0, str);
  154.                 }
  155.                   delay();
  156.                 }
  157.         if(Key4==0)
  158.                 {
  159.                   delay();
  160.                   set=0;
  161.                   InitLcd1602();
  162.                    //初始化液晶
  163.                 }
  164.
  165. }
  166.
  167. void ConfigTimer0(unsigned int ms)
  168. {
  169.     unsigned long tmp;  //臨時變量
  170.     tmp = 11059200 / 12;      //定時器計數(shù)頻率
  171.     tmp = (tmp * ms) / 1000;  //計算所需的計數(shù)值
  172.     tmp = 65536 - tmp;        //計算定時器重載值
  173.     tmp = tmp + 12;           //補償中斷響應延時造成的誤差
  174.     T0RH = (unsigned char)(tmp>>8);  //定時器重載值拆分為高低字節(jié)
  175.     T0RL = (unsigned char)tmp;
  176.     TMOD &= 0xF0;   //清零T0的控制位
  177.     TMOD |= 0x01;   //配置T0為模式1
  178.     TH0 = T0RH;     //加載T0重載值
  179.     TL0 = T0RL;
  180.     ET0 = 1;        //使能T0中斷
  181.     TR0 = 1;        //啟動T0
  182. }
  183. /* T0中斷服務函數(shù),完成1秒定時 */
  184. void InterruptTimer0() interrupt 1
  185. {
  186.     static unsigned char tmr1s = 0;
  187.     TH0 = T0RH;  //重新加載重載值
  188.     TL0 = T0RL;
  189.     tmr1s++;
  190.     if (tmr1s >= 100)  //定時1s
  191.     {
  192.         tmr1s = 0;
  193.         flag1s = 1;
  194.
  195.         }
  196. }
復制代碼
ID:225135 發(fā)表于 2018-5-16 14:44 | 顯示全部樓層
因為你的程序還沒走到按鍵感應吧,不建議用delay寫程序。
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
ID:330198 發(fā)表于 2018-5-16 15:19 | 顯示全部樓層
第一你按鍵沒有做消抖處理,第二你while(!Key1)這句位置應該緊跟著if(Key1==0)的后面。
admin + 20 回帖助人的獎勵!
ID:331281 發(fā)表于 2018-5-16 15:21 | 顯示全部樓層
初步判斷是你的按鍵1s輪詢時間過長,可以按鍵單獨出來,然后新定一個標志,30ms掃描一次按鍵,主要就很快了,
1s對按鍵來說的確太長了
admin + 20 回帖助人的獎勵!
ID:331365 發(fā)表于 2018-5-16 16:08 | 顯示全部樓層
不建議用delay寫程序
admin + 20 回帖助人的獎勵!
ID:315386 發(fā)表于 2018-5-16 16:12 | 顯示全部樓層
消抖的原因吧
admin + 20 回帖助人的獎勵!
ID:304161 發(fā)表于 2018-5-16 17:40 來自手機 | 顯示全部樓層
去抖動,采集按鍵值需要一定的周期才能采集到信號
admin + 20 回帖助人的獎勵!
ID:272459 發(fā)表于 2018-5-16 19:39 | 顯示全部樓層
zhanghyg 發(fā)表于 2018-5-16 15:19
消抖 還是一樣,反應時間長,
admin + 20 回帖助人的獎勵!
ID:272459 發(fā)表于 2018-5-16 19:41 | 顯示全部樓層
liu281469315 發(fā)表于 2018-5-16 15:21
1 ...
按鍵子程序 獨立出來不在FLAG1S里面嗎?
ID:272459 發(fā)表于 2018-5-16 19:42 | 顯示全部樓層
12345yj 發(fā)表于 2018-5-16 17:40
已經(jīng)去抖動了,但是還是按鍵按下后還是要很長時間才能反應
ID:272459 發(fā)表于 2018-5-16 20:42 | 顯示全部樓層
我按下按鍵 5S-6S才會有反應,應該沒有這么長周期吧
ID:272459 發(fā)表于 2018-5-16 21:17 | 顯示全部樓層
感謝大家,我已經(jīng)找出原因了。。
ID:1 發(fā)表于 2018-5-17 01:29 | 顯示全部樓層
abcarry 發(fā)表于 2018-5-16 21:17
原因是什么 能分享下嗎?
ID:194257 發(fā)表于 2018-5-17 09:07 | 顯示全部樓層
1s才讀一次按鍵肯定要長按啊
ID:320371 發(fā)表于 2018-5-17 09:22 | 顯示全部樓層
需要加入防抖才能正常使用,就是判斷兩次按鍵電平,并加入一個延時。例如:
if(key==0)
delay(10);
if(key==0)
{//你需要進行的操作
ID:331894 發(fā)表于 2018-5-17 09:54 | 顯示全部樓層
按鍵  沒做處理   也就是   每次按下按鍵   需要延時
ID:272459 發(fā)表于 2018-5-17 09:54 | 顯示全部樓層
admin 發(fā)表于 2018-5-17 01:29
原因是什么 能分享下嗎?
delay()函數(shù)延時長  并且 多次成倍調(diào)用delay()函數(shù)
ID:223416 發(fā)表于 2018-5-17 11:14 | 顯示全部樓層
對io口查詢的頻率不夠高
ID:399179 發(fā)表于 2020-3-4 18:00 來自手機 | 顯示全部樓層
我的也是這問題,樓主怎么解決的?
ID:755110 發(fā)表于 2020-5-20 09:04 | 顯示全部樓層
abcarry 發(fā)表于 2018-5-17 09:54
請問您是怎么解決的呢,我也遇到了按鍵得長按才能起作用的問題。
ID:601478 發(fā)表于 2020-5-20 14:21 | 顯示全部樓層
5樓說的有道理,剛開始學習寫程序用DELAY能方便地理解程序運行過程,但是往后的話還是養(yǎng)成寫程序盡量不用delay的習慣為好
