- * 例4.1.1用數(shù)碼管前兩位顯示一個(gè)十進(jìn)制數(shù),變化范圍為00~59,
- * 開(kāi)始時(shí)顯示00,每按下S2鍵一次,數(shù)值加1;
- * 每按下S3鍵一次,數(shù)值減1;
- * 每按下S4鍵一次,數(shù)值歸零;
- * 按下S5鍵一次,利用定時(shí)器功能使數(shù)值開(kāi)始自動(dòng)每秒加1,再次按下S5鍵,數(shù)值停止加1,保持顯示原數(shù)。
- * (part2.2_1.c P82)
- #include <reg52.h> //52系列單片機(jī)頭文件
- #define uchar unsigned char
- #define uint unsigned int
- sbit key1=P3^4;
- sbit key2=P3^5;
- sbit key3=P3^6;
- sbit key4=P3^7;
- sbit dula=P2^6; //申明U1鎖存器的鎖存端
- sbit wela=P2^7; //申明U2鎖存器的鎖存端
- uchar code table[]={
- 0x3f,0x06,0x5b,0x4f,
- 0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71};
- void delayms(uint);
- uchar numt0,num;
- void display(uchar numdis) //顯示子函數(shù)
- uchar shi,ge; //分離兩個(gè)分別要顯示的數(shù)
- shi=numdis/10;
- ge=numdis%10;
- dula=1;
- P0=table[shi]; //送十位段選數(shù)據(jù)
- dula=0;
- P0=0xff; //送位選數(shù)據(jù)前關(guān)閉所有顯示,防止打開(kāi)位選鎖存時(shí)
- wela=1; //原來(lái)段選數(shù)據(jù)通過(guò)位選鎖存器造成混亂
- P0=0xfe; //送位選數(shù)據(jù)
- wela=0;
- delayms(5); //延時(shí)
- dula=1;
- P0=table[ge]; //送個(gè)位段選數(shù)據(jù)
- dula=0;
- P0=0xff;
- wela=1;
- P0=0xfd;
- wela=0;
- delayms(5);
- void delayms(uint xms)
- uint i,j;
- for(i=xms;i>0;i--) //i=xms即延時(shí)約xms毫秒
- for(j=110;j>0;j--);
- void init() //初始化函數(shù)
- TMOD=0x01;//設(shè)置定時(shí)器0為工作方式1(0000 0001)
- TH0=(65536-45872)/256;//裝初值50ms一次中斷
- TL0=(65536-45872)%256;
- EA=1; //開(kāi)總中斷
- ET0=1; //開(kāi)定時(shí)器0中斷
- void keyscan()
- if(key1==0)
- delayms(10);
- if(key1==0)
- num++;
- if(num==60)//當(dāng)?shù)?0時(shí)重新歸0
- num=0;
- while(!key1);//等待按鍵釋放
- if(key2==0)
- delayms(10);
- if(key2==0)
- if(num==0)//當(dāng)?shù)?時(shí)重新歸60
- num=60;
- num--;
- while(!key2);
- if(key3==0)
- delayms(10);
- if(key3==0)
- num=0; //清0
- while(!key3);
- if(key4==0)
- delayms(10);
- if(key4==0)
- while(!key4);
- TR0=~TR0;//啟動(dòng)或停止定時(shí)器0
- void main()
- init();//初始化函數(shù)
- while(1)
- keyscan();
- display(num);
- void T0_time() interrupt 1
- TH0=(65536-45872)/256;//重裝初值
- numt0++;
- if(numt0==20) //如果到了20次,說(shuō)明1秒時(shí)間到
- numt0=0; //然后把num清0重新再計(jì)20次
- num++;
- if(num==60)
- num=0;
