查看: 5801|回復(fù): 1
requires ANSI-style prototype誰(shuí)幫我看看這個(gè)程序錯(cuò)誤怎么修改
ID:349392 發(fā)表于 2018-6-11 20:52 | 顯示全部樓層 |閱讀模式
單片機(jī)溫度計(jì)設(shè)計(jì).C(3): warning C318: can't open file 'DS18b20.h'
單片機(jī)溫度計(jì)設(shè)計(jì).C(4): warning C318: can't open file 'eeprom52.h'
單片機(jī)溫度計(jì)設(shè)計(jì).C(5): warning C318: can't open file 'Nixie tube.h'
單片機(jī)溫度計(jì)設(shè)計(jì).C(39): warning C206: 'Nixietube': missing function-prototype
單片機(jī)溫度計(jì)設(shè)計(jì).C(39): error C267: 'Nixietube': requires ANSI-style prototype
單片機(jī)溫度計(jì)設(shè)計(jì).C - 1 Error(s), 4 Warning(s).
  1. #include <reg52.h>
  2. #include "intrins.h"
  3. #include "DS18b20.h"
  4. #include "eeprom52.h"
  5. #include "Nixie tube.h"
  6. #define uchar unsigned char
  7. #define uint unsigned int
  8. uchar code ss[]=
  9. {
  10.   0xc0,0xf9,0xa4,0xb0,0x99,
  11.   0x92,0x82,0xf8,0x80,0x90
  12. };
  13. uchar code ss1[]=
  14. {
  15.   0x40,0x79,0x24,0x30,0x19,
  16.   0x12,0x02,0x78,0x00,0x10,
  17.   0xc7,0x89,0xbf
  18. };
  19. uchar ms;
  20. sbit key1=P3^4;
  21. sbit key2=P3^5;
  22. sbit key3=P3^3;
  23. sbit led_0=P1^0;
  24. sbit led_2=P1^2;
  25. char H,L;
  26. uchar flag;
  27. sbit beep=P1^6;
  28. bit s0,beep_1=1;
  29. int temp,i;
  30. void delay(uint T)
  31. {
  32.   while(T--);
  33. }
  34. void display()
  35. {
  36.   if(flag==0&&temp>=0)
  37.         {
  38.      if(temp>999) Nixietube(ss[temp/1000%10],ss[temp/100%10],ss1[temp/10%10],ss[temp%10]);
  39.          if(temp>99)  Nixietube(0xff,ss[temp/100%10],ss1[temp/10%10],ss[temp%10]);
  40.          if(temp<99&&temp/100%10<=0)  Nixietube(0xff,0xff,ss1[temp/10%10],ss[temp%10]);
  41.     }
  42.   if(flag==0&&temp<0)
  43.         {
  44.      if(temp*-1/100%10<=0) Nixietube(0xff,ss1[12],ss1[temp*-1/10%10],ss[temp*-1%10]);
  45.          if(temp*-1/100%10>0)  Nixietube(ss1[12],ss[temp*-1/100%10],ss1[temp*-1/10%10],ss[temp*-1%10]);
  46.         }
  47.   if(flag==1)
  48.         {
  49.      if(H>99)          Nixietube(ss1[11],ss[H/100],ss[H%100/10],ss[H%10]);
  50.          if(H>=10&&H<=99)  Nixietube(ss1[11],0xff,ss[H/10],ss[H%10]);
  51.          if(H<10&&H>=0)    Nixietube(ss1[11],0xff,0xff,ss[H%10]);
  52.          if(H<0&&H>=-9)    Nixietube(ss1[11],0xff,ss1[12],ss[H*-1%10]);
  53.      if(H<0&&H<-9)     Nixietube(ss1[11],ss1[12],ss[H*-1%100/10],ss[H*-1%10]);
  54.     }
  55. if(flag==2)
  56.         {
  57.      if(L>99)          Nixietube(ss1[10],ss[L/100],ss[L%100/10],ss[L%10]);
  58.          if(L>=10&&L<=99)  Nixietube(ss1[10],0xff,ss[L/10],ss[L%10]);
  59.          if(L<10&&L>=0)    Nixietube(ss1[10],0xff,0xff,ss[L%10]);
  60.          if(L<0&&L>=-9)  Nixietube(ss1[10],0xff,ss1[12],ss[L*-1%10]);
  61.      if(L<0&&L<-9)  Nixietube(ss1[10],ss1[12],ss[L*-1%100/10],ss[L*-1%10]);
  62.     }
  63.
  64.   }
  65. void key()
  66. {
  67.
  68. if(!key1)
  69. {
  70.    delay(500);
  71.    if(!key1)
  72.         {
  73.       while(!key1);
  74.           if(flag==1)
  75.                   {
  76.          if(H<125)H++;
  77.                  SectorErase(0x2000);
  78.                  byte_write(0x2000,H);
  79.         }
  80.           else if        (flag==2)
  81.                 {
  82.           if(L<H-1) L++;
  83.                   SectorErase(0x2200);
  84.                   byte_write(0x2200,L);
  85.         }
  86.     }
  87. }
  88. if(!key2)
  89. {
  90.     delay(500);
  91.         if(!key2)
  92.          {
  93.        while(!key2);
  94.            if(flag==1)
  95.                   {
  96.                   if(H>L+1)  H--;
  97.                   SectorErase(0x2000);
  98.                   byte_write(0x2000,H);
  99.         }
  100.            else if        (flag==2)
  101.                 {
  102.                   if(L>-55)L--;
  103.                   SectorErase(0x2200);
  104.               byte_write(0x2200,L);
  105.         }
  106.      }
  107. }
  108. if(!key3)
  109.         {
  110.          delay(1000);
  111.          if(!key3)
  112.        {
  113.                 while(!key3);
  114.         flag=(flag+1)%3;
  115.        }
  116.   }
  117. }
  118. void alarm()
  119. {
  120. if(temp/10>=H||temp/10<=L)
  121.    {
  122.     beep_1=0;
  123.    }
  124. else
  125.         {
  126.           beep_1=1;
  127.     }
  128. if(temp/10>=H)
  129.         {
  130.           led_0=0;
  131.         }
  132. else
  133.    {
  134.     led_0=1;
  135.    }
  136.
  137. if(temp/10<=L)
  138.    {
  139.          led_2=0;
  140.    }
  141. else
  142.    {
  143.      led_2=1;
  144.    }
  145. }
  146. void main()
  147. {
  148.     do
  149.      {
  150.           temp=Temper();
  151.      }
  152.     while(temp==850);
  153.         delay(1000);
  154.         H=byte_read(0x2000);
  155.         L=byte_read(0x2200);
  156.         if((H>99)||(L>99)||(L>=H))
  157.       {
  158.                 H=35;
  159.                 L=16;
  160.           }
  161.         TMOD=0x01;
  162.         TH0=(65536-10000)/256;
  163.         TL0=(65536-10000)%256;
  164.         EA=1;
  165.         ET0=1;
  166.     TR0=1;
  167.
  168. while(1)
  169.         {
  170.           key();
  171.           alarm();
  172.
  173.
  174.         }
  175. }
  176. void UART_1() interrupt 1
  177. {
  178.         TH0=(65536-10000)/256;
  179.         TL0=(65536-10000)%256;
  180.         ms++;
  181.         display();
  182. if(ms>100)
  183.         {
  184.           ms=0;
  185.           temp=Temper();
  186.         }
  187. if(ms%5==0)
  188.         {
  189.          if(beep_1==0)
  190.           {
  191.                 beep=!beep;
  192.           }
  193.          else
  194.       {
  195.                 beep=1;
  196.           }
  197.     }
  198. }
ID:320306 發(fā)表于 2018-6-12 08:52 | 顯示全部樓層
函數(shù)需要在main之前申明,你沒(méi)有申明函數(shù)。。。!
