查看: 3304|回復(fù): 8
求助 DS1302在LCD12864上顯示的時鐘的數(shù)字在閃爍,就好像亂碼,看不到一個數(shù)字那樣
ID:356979 發(fā)表于 2018-6-22 23:36 | 顯示全部樓層 |閱讀模式
/*        TSCLK  -  P10
        TIO    -  P11
        TRST   -  P12   */
#include<reg52.h>
#include <intrins.h>
uchar a,miao,fen,shi,ri,yue,nian,week,temp,flag,key1n;
#define yh 0x80  //第一行的初始位置
#define er 0x90 //第二行初始位置
#define san 0x88
#define si 0x98
void write_week(uchar week);
/*12864端口定義*/
#define LCD_data  P0             //數(shù)據(jù)口
sbit LCD_RS  =  P3^5;            //寄存器選擇輸入
sbit LCD_RW  =  P3^6;            //液晶讀/寫控制
sbit LCD_EN  =  P3^4;            //液晶使能控制
sbit LCD_PSB =  P3^7;            //串/并方式控制
sbit wela    =  P2^6;
sbit dula    =  P2^7;
sbit SCLK=P1^0;
sbit IO=P1^1;
sbit RST=P1^2;
sbit ACC0=ACC^0;
sbit ACC7=ACC^7;
sbit key=P3^3;
sbit key1=P3^0;
sbit key2=P3^1;
sbit key3=P3^2;
uchar code dis1[]={"20"} ;
uchar code dis2[]={""};
uchar code dis3[]={"    "};
uchar code dis4[]={"      "};
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
void delay(int ms)//延時函數(shù)(2ms)
    while(ms--)
      uchar i;
          for(i=0;i<250;i++)
            _nop_();
                _nop_();
                _nop_();
                _nop_();
bit lcd_busy() //檢查LCD忙狀態(tài)
    bit result;
    LCD_RS = 0;
    LCD_RW = 1;
    LCD_EN = 1;
    delayNOP();
    result = (bit)(P0&0x80);
    LCD_EN = 0;
    return(result);
void lcd_wcmd(uchar cmd) //寫指令數(shù)據(jù)
   while(lcd_busy());
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_EN = 0;
    _nop_();
    _nop_();
    P0 = cmd;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
void lcd_wdat(uchar dat) //寫顯示數(shù)據(jù)
   while(lcd_busy());
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_EN = 0;
    P0 = dat;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
void lcd_init()//LCD初始化設(shè)定
    LCD_PSB = 1;         //并口方式
    lcd_wcmd(0x34);      //擴(kuò)充指令操作
    delay(5);
    lcd_wcmd(0x30);      //基本指令操作
    delay(5);
    lcd_wcmd(0x0C);      //顯示開,關(guān)光標(biāo)
    delay(5);
    lcd_wcmd(0x01);      //清除LCD的顯示內(nèi)容
    delay(5);
void lcd_pos(uchar X,uchar Y)  /*設(shè)定顯示位置    */
   uchar  pos;
   if (X==0)
     {X=0x80;}
   else if (X==1)
     {X=0x90;}
   else if (X==2)
     {X=0x88;}
   else if (X==3)
     {X=0x98;}
   pos = X+Y ;
   lcd_wcmd(pos);     //顯示地址
/*DS1302*/
void write_byte(uchar dat) //寫一個字節(jié)
        ACC=dat;
        RST=1;
        for(a=8;a>0;a--)  //循環(huán)8次移位
                IO=ACC0;
                SCLK=0;          //先把時鐘線拉低
                SCLK=1;          //把時鐘線拉高,鎖存數(shù)據(jù)
                ACC=ACC>>1;
uchar read_byte() //讀一個字節(jié)
        RST=1;
        for(a=8;a>0;a--)
                ACC7=IO;
                SCLK=1;
                SCLK=0;
                ACC=ACC>>1;
        return (ACC);
void write_1302(uchar add,uchar dat)//向DS1302寫函數(shù),指定寫入地址、數(shù)據(jù)
        RST=0;
        SCLK=0;
        RST=1;
        write_byte(add);
        write_byte(dat);
        SCLK=1;
        RST=0;         //數(shù)據(jù)傳送中止
uchar read_1302(uchar add)        //從DS1302讀取數(shù)據(jù)函數(shù),指定讀取數(shù)據(jù)來源地址
        uchar temp;
        RST=0;         //芯片處于復(fù)位狀態(tài)
        SCLK=0;         //清零
        RST=1;        //芯片開始工作
        write_byte(add);
        temp=read_byte();
        SCLK=1;
        RST=0;
        return(temp);
uchar BCD_Decimal(uchar bcd) //BDC碼轉(zhuǎn)為十進(jìn)制函數(shù),輸入BCD,返回十進(jìn)制
        uchar Decimal;
        Decimal=bcd>>4;
        return(Decimal=Decimal*10+(bcd&=0x0F));
void ds1302a_init()
        RST=0;
        SCLK=0;
        //write_1302(0x80,miao|0x00);//允許寫
        write_1302(0x8e,0x00);
        write_1302(0xc0,0xfe);
        write_1302(0xc2,0xff);
        write_1302(0x80,0x20);
        write_1302(0x82,0x10);
        write_1302(0x84,0x12);
        write_1302(0x86,0x06);
        write_1302(0x88,0x06);
        write_1302(0x8a,0x18);
        write_1302(0x8e,0x80);
/*void ds1302b_init()
        RST=0;
        SCLK=0;
        write_1302(0x80,ri|0x00);
void write_sfm(uchar dat)//寫時分秒
        uchar gw,sw;
        //lcd_pos(1,0) ;
        //lcd_wcmd(er);
        gw=dat%10;
        sw=dat/10;
        lcd_wdat(0x30+sw);
        lcd_wdat(0x30+gw);
        /*lcd_wdat(0x30+shi/10);
        lcd_wdat(0x30+shi%10);
        lcd_wdat(':');
        lcd_wdat(' ');
        lcd_wdat(0x30+fen/10);
        lcd_wdat(0x30+fen%10);
        lcd_wdat(':');
        lcd_wdat(' ');
        lcd_wdat(0x30+miao/10);
        lcd_wdat(0x30+miao%10);*/
void write_nyr(uchar dat)        //寫年月日
    uchar gw,sw;
        //lcd_pos(0,1);
        //lcd_wcmd(yh);
        gw=dat%10;
        sw=dat/10;
        lcd_wdat(0x30+sw);
        lcd_wdat(0x30+gw);
        /*lcd_wdat(0x30+nian/10);
        lcd_wdat(0x30+nian%10);
        lcd_wdat('-');
        lcd_wdat('-');
        lcd_wdat(0x30+yue/10);
        lcd_wdat(0x30+yue%10);
        lcd_wdat('-');
        lcd_wdat('-');
        lcd_wdat(0x30+ri/10);
        lcd_wdat(0x30+ri%10);*/
void write_week(uchar week)//寫星期函數(shù)
        lcd_pos(0,6);//lcd_wcmd(yh+0x0b);
        lcd_wdat(' ');
        switch(week)
                case 1:lcd_wdat('M');//delay(5);
                           lcd_wdat('O');//delay(5);
                           lcd_wdat('N');
                           break;
                case 2:lcd_wdat('T');//delay(5);
                           lcd_wdat('U');//delay(5);
                           lcd_wdat('E');
                           break;
                case 3:lcd_wdat('W');//delay(5);
                            lcd_wdat('E');//delay(5);
                            lcd_wdat('D');
                           break;
                case 4:lcd_wdat('T');//delay(5);
                           lcd_wdat('H');//delay(5);
                           lcd_wdat('U');
                           break;
                case 5:lcd_wdat('F');//delay(5);
                           lcd_wdat('R');//delay(5);
                           lcd_wdat('I');
                           break;
                case 6:lcd_wdat('S');//delay(5);
                           lcd_wdat('A');
                           break;
                case 7:lcd_wdat('S');//delay(5);
                           lcd_wdat('N');
                           break;
void write_name(uint *s1)//寫姓名
        lcd_pos(2,1);//lcd_wcmd(san);
        lcd_wdat(':');
        while(*s1!=0)
                lcd_wdat(*s1);
                s1++;
                delay(5);
void write_num(uint *s2)//學(xué)號
        lcd_pos(3,1);//lcd_wcmd(si);
        lcd_wdat(':');
        while(*s2!=0)
                lcd_wdat(*s2);
                s2++;
                delay(5);
void Clr_Screen()//清屏命令
  //考慮到前面出現(xiàn)0x34
   lcd_wcmd(0x01);
   delay(100);
void init()//串口初始化
        TMOD=0x11;//00000001定時計數(shù)器0選擇方式1,16位定時計數(shù)器
        TH0=0;
        TL0=0;
        EA=1;        //開全局中斷
        ET0=1;        //定時計數(shù)器0中斷使能控制位
        TR0=1;        //定時器T0開始計數(shù)
void cmg(void)//數(shù)碼管鎖存函數(shù)
        dula=1;
        P0=0x00;
        dula=0;
        wela=1;
        P0=0x00;
        wela=0;
void keyscan()
        if(key1==0)
                delay(5);
                if(key1==0)
                        while(!key1);
                        key1n++;
                        if(key1n==9)
                                key1n=1;
                        switch(key1n)
                                case 1: TR0=0;         //miao
                                                lcd_wcmd(0x90+4);
                                                lcd_wcmd(0x0f);
                                                temp=(miao)/10*16+(miao)%10        ;
                                                   write_1302(0x80,0x80|temp);//miao
                                                   break;
                                case 2: lcd_wcmd(0x90+2); //fen
                                            lcd_wcmd(0x0f);
                                                break;
                                case 3: lcd_wcmd(0x90);        //shi
                                                lcd_wcmd(0x0f);
                                                break;
                                case 4: lcd_wcmd(0x80+7); //week
                                                lcd_wcmd(0x0f);
                                                break;
                            case 5: lcd_wcmd(0x80+5);  //ri
                                                lcd_wcmd(0x0f);
                                                break;
                                case 6: lcd_wcmd(0x80+3);         //yue
                                                lcd_wcmd(0x0f);
                                                break;
                                case 7: lcd_wcmd(0x80+1);        //nian
                                                lcd_wcmd(0x0f);
                                                break;
                                case 8: lcd_wcmd(0x0c);
                                                TR0=1;
                                                temp=(miao)/10*16+(miao)%10;//將十進(jìn)制變成十六進(jìn)制
                                                   write_1302(0x80,0x00|temp);//miao
                                    break;
        if(key1n!=0)//當(dāng)key1按下以下。再按以下鍵才有效
                if(key2==0)  //上調(diào)鍵
                        delay(5);
                        if(key2==0)
                                while(!key2);
                                switch(key1n)
                                        case 1: miao++;
                                                        if(miao==60)
        miao=0;
                                                        write_sfm(miao);
                                                        lcd_pos(1,4);
                                                        lcd_wcmd(0x90+4);
                                                        break;
                                        case 2: fen++;
                                                        if(fen==60)
        fen=0;
                                                        write_sfm(fen);
                                                        temp=(fen)/10*16+(fen)%10;
                                                           write_1302(0x82,temp);
                                                        lcd_wcmd(0x90+2);
                                                        break;
                                        case 3: shi++;
                                                        if(shi==24)
        shi=0;
                                                        write_sfm(shi);
                                                        temp=(shi)/10*16+(shi)%10;
                                                           write_1302(0x84,temp);
                                        lcd_wcmd(0x90);
                                                        break;
                                        case 4: week++;
                                                        if(week==8)
                                                        week=0;
                                                        write_week(week);
                                                        lcd_wcmd(0x80+7);
                                                        lcd_wcmd(0x80+6) ;
                                                        break;
                                        case 5: ri++;
                                                        if(ri==31)
        ri=0;
                                                        write_nyr(ri);
                                                        temp=(ri)/10*16+(ri)%10;
                                                           write_1302(0x86,temp);
                                                        lcd_wcmd(0x80+5);
                                                        break;
                                        case 6: yue++;
                                                        if(yue==13)
                                                        yue=0;
                                                        write_nyr(yue);
                                                        temp=(yue)/10*16+(yue)%10;
                                                           write_1302(0x88,temp);
                                                        lcd_wcmd(0x80+3);
                                                        break;
                                        case 7:
                                                        nian++;
                                    if(nian==100)
                                                        nian=0;
                                                        write_nyr(nian);
                                                        temp=(nian)/10*16+(nian)%10;
                                                           write_1302(0x8a,temp);
                                                        lcd_wcmd(0x80+1);
                                                        break;
        if(key3==0)
                delay(5);
                if(key3==0)
                        while(!key3);
                        switch(key1n)
                                 case 1: miao--;
                                                if(miao==-1)
                                                        miao=59;
                                                write_sfm(miao);
                                                lcd_wcmd(0x90+4);
                                                break;
                                 case 2:fen--;
                                        if(fen==-1)
                                                           fen=59;
                                                write_sfm(fen);
                                                lcd_wcmd(0x90+2);
                                                break;
                                 case 3:shi--;
                                                   if(shi==-1)
                                                        shi=23;
                                                write_sfm(shi);
                                                lcd_wcmd(0x90);
                                                break;
                                case 4: week--;
                                                if(week==-1)
                                                        week=7;
                                                write_week(week);
                                                lcd_wcmd(0x80+7);
                                                lcd_wcmd(0x80+6);
                                                break;
                                case 5: ri--;
                                                if(ri==-1)
                                                        ri=30;
                                                write_nyr(ri);
                                                  lcd_wcmd(0x80+5);
                                                break;
                                case 6: yue--;
                                                if(yue==-1)
                                                        yue=12;
                                                write_nyr(yue);
                                                lcd_wcmd(0x80+3);
                                                break;
                                case 7: nian--;
                                                 if(nian==-1)
                                                        nian=99;
                                                write_nyr(nian);
                                                lcd_wcmd(0x80+1);
                                                break;
   main()//主函數(shù)
    uchar i;
    delay(10);                 //延時
    wela=0;
        dula=0;
    cmg();//數(shù)碼管鎖存
        ds1302a_init();
        //ds1302b_init();
        init();
    lcd_init();                //初始化LCD
    lcd_pos(0,0);             //設(shè)置顯示位置為第一行的第1個字符
     i = 0;
    while(dis1[i] != '\0')
     {                         //顯示字符
       lcd_wdat(dis1[i]);
       i++;
    lcd_pos(1,0);             //設(shè)置顯示位置為第二行的第1個字符
     i = 0;
    while(dis2[i] != '\0')
       lcd_wdat(dis2[i]);      //顯示字符
       i++;
         lcd_pos(2,0);             //設(shè)置顯示位置為第三行的第1個字符
     i = 0;
    while(dis3[i] != '\0')
       lcd_wdat(dis3[i]);      //顯示字符
       i++;
         lcd_pos(3,0);             //設(shè)置顯示位置為第四行的第1個字符
     i = 0;
    while(dis4[i] != '\0')
       lcd_wdat(dis4[i]);      //顯示字符
       i++;
                 keyscan();
void timer0() interrupt 1  //中斷函數(shù)
        miao = BCD_Decimal(read_1302(0x81));
        fen = BCD_Decimal(read_1302(0x83));
        shi  = BCD_Decimal(read_1302(0x85));
        ri  = BCD_Decimal(read_1302(0x87));
        yue = BCD_Decimal(read_1302(0x89));
        nian=BCD_Decimal(read_1302(0x8d));
        week=BCD_Decimal(read_1302(0x8b));
        lcd_pos(1,4);
        write_sfm(miao);
        lcd_pos(1,3);
        lcd_wdat(':');
        lcd_pos(1,2);
        write_sfm(fen);
        lcd_pos(1,1);
        lcd_wdat(':');
        lcd_pos(1,0);
        write_sfm(shi);
        lcd_pos(0,5);
        write_nyr(ri);
        lcd_pos(0,4);
        lcd_wdat('-');
        lcd_wdat('-');
        lcd_pos(0,3);
    write_nyr(yue);
        lcd_pos(0,2);
        lcd_wdat(0x2d);
        lcd_wdat(0x2d);
        lcd_pos(0,1);
        write_nyr(nian);
ID:356979 發(fā)表于 2018-6-22 23:43 | 顯示全部樓層
弄了很久都不行,有沒有大神可以幫幫忙
ID:303383 發(fā)表于 2018-6-23 08:44 | 顯示全部樓層
提示: 作者被禁止或刪除 內(nèi)容自動屏蔽
ID:295783 發(fā)表于 2018-6-23 10:39 | 顯示全部樓層
你的程序太長了 我給你一點建議你自己查一下
1.有沒有進(jìn)行初始化 清零
2.延時問題 必須要有延時 我記得動態(tài)顯示好像是一直不停的顯示 是動態(tài)的 很快 所以肉眼看到的是靜止的 延時不能太長
3.如果你加了按鍵功能的話 看看有沒有按鍵消抖程序 這個是必須有的
希望對你有幫助
ID:356979 發(fā)表于 2018-6-23 23:07 | 顯示全部樓層
程序新手 發(fā)表于 2018-6-23 10:39
1.有沒有進(jìn)行初始化 清零
2.延時問題 必須要有延時 我記得動 ...
初始化是有的,就是它顯示是亂碼,不是說小時的太快,有對應(yīng)的向時鐘顯示,比如顯示了02到03之間它會閃到其他數(shù)字,而且有些就不是02、03、04的順序顯示下去的
ID:356979 發(fā)表于 2018-6-23 23:27 | 顯示全部樓層
今晚弄它突然就行了,但是顯示年的時候用按鍵調(diào)的時候出現(xiàn)了兩種情況,第一是調(diào)完之后時鐘繼續(xù)走時,那個年還是顯示原來沒調(diào)的那個數(shù),第二就是在調(diào)節(jié)時,一按加鍵或減鍵時它不是從原來的那個數(shù)一直加或減的進(jìn)行,在這種情況下調(diào)完就可以正確顯示,
ID:261000 發(fā)表于 2018-6-24 12:29 | 顯示全部樓層
建議一段一段查,,先查端口驅(qū)部分,,硬件也要查一下,io口加上拉電阻“10K。看看。
ID:357739 發(fā)表于 2018-6-24 13:18 | 顯示全部樓層
先檢查電路有沒有問題,連的線是串行還是并行的
ID:357839 發(fā)表于 2018-6-24 16:06 來自觸屏版 | 顯示全部樓層
有沒有可能是你的晶振的頻率調(diào)的不合適 或者LCD時鐘頻率
