查看: 3835|回復(fù): 1
關(guān)于步進電機正反轉(zhuǎn)控制的問題
ID:353085 發(fā)表于 2018-6-26 23:02 | 顯示全部樓層 |閱讀模式
15黑幣
正轉(zhuǎn)正常,而反轉(zhuǎn)按90度反轉(zhuǎn)正常,按了反轉(zhuǎn)再按圈數(shù)對應(yīng)的按鍵無法實現(xiàn),出現(xiàn)無限正轉(zhuǎn),請問問題所在?
  1. #include<reg52.h>
  2. sbit key_in1=P2^4;
  3. sbit key_in2=P2^5;
  4. sbit key_in3=P2^6;
  5. sbit key_in4=P2^7;
  6. sbit key_out1=P2^0;
  7. sbit key_out2=P2^1;
  8. sbit key_out3=P2^2;
  9. sbit key_out4=P2^3;
  10. bit dirmotor=0;
  11. unsigned char code keymap[4][4]={
  12.         {0x28,0x27,0x26,0x25},
  13.         {0x0D,0x39,0x36,0x33},
  14.         {0x1B,0x38,0x35,0x32},
  15.         {0x30,0x37,0x34,0x31}};
  16. unsigned char keysta[4][4]={
  17.         {1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}};
  18. signed long beats;
  19.         void keyDriver();
  20.
  21.         void main()
  22.         {
  23.                 EA=1;
  24.                 TMOD=0x01;
  25.                 TH0=0xFC;
  26.                 TL0=0x67;
  27.                 ET0=1;
  28.                 TR0=1;
  29.
  30.                 while(1)
  31.                 {
  32.                         keyDriver();
  33.                 }
  34.         }
  35.         void starmotor(signed long angle)
  36.         {
  37.                 EA=0;
  38.                 beats= ( angle * 4076 ) / 360;
  39.                 EA=1;
  40.         }
  41.         void keyaction(unsigned int keycode)
  42.         {
  43.    static bit dirmotor=0;
  44.         if((keycode>=0x30)&&(keycode<=0x39))
  45.                         {
  46.                                 if(dirmotor==0)
  47.
  48.                                         starmotor((keycode-0x30)*360);
  49.
  50.                                         else
  51.             starmotor((keycode-0x30)*360*);
  52.
  53.
  54.                                 }
  55.         else if(keycode==0x0D)
  56.         {
  57.   dirmotor=1;
  58.         }
  59.   else if(keycode==0x26)
  60.         {
  61.   dirmotor=0;
  62.         }
  63.   else if(keycode==0x28)
  64.         {
  65.
  66. starmotor(90);
  67.
  68.         }
  69.   else if(keycode==0x27)
  70.         {
  71. starmotor(-90);
  72.         }
  73.   else if(keycode==0x1B)
  74.         {
  75.   EA=0;
  76.                 beats=0;
  77.                 EA=1;
  78.         }
  79. }
  80.
  81.         void keyDriver()
  82.         {
  83.         static          unsigned char backup[4][4]={
  84.                         {1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}};
  85.
  86.                 unsigned char j=0;
  87.                 unsigned char k=0;
  88.                 for(j=0;j<4;j++)
  89.                   {
  90.                                 for(k=0;k<4;k++)
  91.                                 {
  92.                                         if(keysta[j][k]!=backup[j][k])
  93.                                         {
  94.                                                 if(backup[j][k]==0)
  95.                                                 {
  96.                                                         keyaction(keymap[j][k]);
  97.                                                 }
  98.                                         backup[j][k]=keysta[j][k];
  99.
  100.                                         }
  101.                                 }
  102.                         }
  103.                 }
  104.
  105. void keyscan()
  106. {
  107.         static unsigned char keybuf[4][4]={
  108.                 {0xFF,0xFF,0xFF,0xFF},
  109.                 {0xFF,0xFF,0xFF,0xFF},
  110.                 {0xFF,0xFF,0xFF,0xFF},
  111.                 {0xFF,0xFF,0xFF,0xFF}};
  112.         unsigned char i=0;
  113. static unsigned char cnt=0;
  114.
  115. keybuf[cnt][0]=(keybuf[cnt][0]<<1)|key_in1;
  116. keybuf[cnt][1]=(keybuf[cnt][1]<<1)|key_in2;
  117. keybuf[cnt][2]=(keybuf[cnt][2]<<1)|key_in3;
  118. keybuf[cnt][3]=(keybuf[cnt][3]<<1)|key_in4;
  119. for(i=0;i<4;i++)
  120. {
  121. if((keybuf[cnt][i]&0x0F)==0x0F)
  122. {
  123.   keysta[cnt][i]=1;
  124. }
  125. else if ((keybuf[cnt][i]&0x00)==0x00)
  126. {
  127.         keysta[cnt][i]=0;
  128. }
  129. }
  130. cnt++;
  131. cnt=cnt&0x03;
  132. switch(cnt)
  133. {
  134.         case 0 : key_out4=1;key_out1=0;break;
  135.         case 1 : key_out1=1;key_out2=0;break;
  136.         case 2 : key_out2=1;key_out3=0;break;
  137.         case 3 : key_out3=1;key_out4=0;break;
  138.         default: break;
  139. }
  140. }
  141.
  142.
  143.
  144. void turnmotor()
  145. {
  146.         unsigned char tmp;
  147.         unsigned char code beatscode[8]={
  148.                 0xE,0xC,0xD,0x9,0xB,0x3,0x7,0x6};
  149.         static signed  char index=0;
  150.
  151.         if(beats>0)
  152.         {
  153.                 tmp=P1;
  154.                 tmp=index&0xF0;
  155.                 tmp=tmp|beatscode[index];
  156.                 P1=tmp;
  157.                 index++;
  158.                 index=index&0x07;
  159.                 beats--;
  160.         }
  161.         else if (beats<0)
  162.         {
  163.                 tmp=P1;
  164.                 tmp=index&0xF0;
  165.                 tmp=tmp|beatscode[index];
  166.                 P1=tmp;
  167.                 index--;
  168.                 if(index<0)
  169.                 {
  170.                         index=7;
  171.                 }
  172.                 beats++;
  173.         }
  174.         else
  175.         {
  176.                 P1=P1|0x0F;
  177.         }
  178. }
  179.
  180. void interrupttimer0() interrupt 1
  181. {
  182.         static bit div=0;
  183.          TH0=0xFC;
  184.          TL0=0x67;
  185.         keyscan();
  186.         div=~div;
  187.         if(div==1)
  188.         {
  189.                 turnmotor();
  190.         }
  191. }
ID:320306 發(fā)表于 2018-6-27 08:28 | 顯示全部樓層
正傳和反正的通電順序不同的,代碼要結(jié)合原理圖才能看出來,你可以自己查找!。。。。。。。。。。。
參與人數(shù) 1黑幣 +8 收起 理由
figo88130 + 8 很給力!
