紅外通信源碼
- #include "include.h"
- 發(fā)送紅外數(shù)據(jù)的邏輯協(xié)議在"ir.c"里面 --> _deflag處查找 *
- u16 tempi = 0;
- u8 IR_val = 0;
- int main(void)
- // u8 i;
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);// 設(shè)置中斷優(yōu)先級分組2
- uart_init(9600);
- delay_init();
- ir_re_init(); //IR接收初始化 PA1--TIM5--CH2
- TIM3_2PWM_Init(1893,0);//不分頻。PWM頻率=38Khz //IR -- PWM發(fā)射初始化 PA7--TIM3--CH2
- KEY_Init();
- LED_Init();
- LED0=0;
- while(1)
- if(tempi >= 250)
- tempi = 1;
- IR_sent(tempi);
- printf("1:%d\r\n",tempi);
- if(IR_receive_finish(&IR_val) == 0)
- LED1=0;
- if(tempi==IR_val)
- tempi += 1;
- printf("2:%d\r\n",IR_val);
- delay_ms(100);
- // uart1_printf("recev",IR_RXBUff,16); //串口1打印出數(shù)組tab內(nèi)的16個數(shù)據(jù)
- LED1=1;
- LED0=1;
復制代碼- #include "ir.h"
- //[7]:保留
- //[6]:保留
- //[5]://標記下降沿是否已經(jīng)被捕獲
- //[4]://標記上升沿是否已經(jīng)被捕獲
- //[3:0]:溢出計時器
- u8 key_sta=0;
- u16 LOW_value=0;
- u16 HIGH_value=0;
- u16 ii=0;
- u16 tab[500];
- u16 IR_RXBUff[500];
- //u16 IR_TXBUff[500];
- u8 num_b[8] = {0}; //十進制轉(zhuǎn)二進制數(shù)組
- u16 num_val[16] = {0}; //發(fā)送數(shù)組
- void ir_re_init(void) //IR接收初始化 PA1--TIM5--CH2
- GPIO_InitTypeDef GPIO_InitStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_ICInitTypeDef TIM_ICInitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5,ENABLE);
- GPIO_InitStructure.GPIO_Pin=GPIO_Pin_1;
- GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPU;//上拉輸入
- GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
- GPIO_Init(GPIOA,&GPIO_InitStructure);
- TIM_TimeBaseStructure.TIM_Period = 0XFFFF; //設(shè)定計數(shù)器自動重裝值 最大10ms溢出
- TIM_TimeBaseStructure.TIM_Prescaler =(72-1); //預分頻器,1M的計數(shù)頻率,1us加1.
- TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //設(shè)置時鐘分割:TDTS = Tck_tim
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上計數(shù)模式
- TIM_TimeBaseInit(TIM5, &TIM_TimeBaseStructure);
- TIM_ICInitStructure.TIM_Channel=TIM_Channel_2;
- TIM_ICInitStructure.TIM_ICPolarity=TIM_ICPolarity_Falling;//下降沿觸發(fā)
- TIM_ICInitStructure.TIM_ICSelection=TIM_ICSelection_DirectTI;
- TIM_ICInitStructure.TIM_ICPrescaler=TIM_ICPSC_DIV1;
- TIM_ICInitStructure.TIM_ICFilter=0x00;
- TIM_ICInit(TIM5,&TIM_ICInitStructure);
- TIM_Cmd(TIM5,ENABLE);
- NVIC_InitStructure.NVIC_IRQChannel= TIM5_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority=0;
- NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- TIM_ITConfig( TIM5,TIM_IT_CC2,ENABLE);
- void TIM5_IRQHandler(void) //IR接收中斷
- if(TIM_GetFlagStatus(TIM5, TIM_FLAG_CC2) == SET)//觸發(fā)中斷
- if(R_DATA==1)
- if(key_sta&0x20)
- LOW_value=TIM_GetCapture2(TIM5);
- IR_RXBUff[ii]=LOW_value;
- ii++;
- TIM_SetCounter(TIM5, 0);//清零計數(shù)器的值
- TIM_OC2PolarityConfig(TIM5, TIM_ICPolarity_Falling);
- key_sta&=0xdf;//下降沿捕獲清除 清除 0x20
- key_sta|=0x10;//上升沿被成功捕獲 標記0x10
- else if(R_DATA==0)
- if(key_sta&0x10)
- HIGH_value=TIM_GetCapture2(TIM5);
- IR_RXBUff[ii]=HIGH_value;
- ii++;
- key_sta&=0xef;//上升沿捕獲清除 清除0x10
- TIM_OC2PolarityConfig(TIM5, TIM_ICPolarity_Rising);
- key_sta|=0x20;//下降沿被成功捕獲 標記 0x20
- TIM_ClearFlag(TIM5,TIM_IT_CC2);
- //0為成功
- u8 IR_receive_finish(u8 *p) //IR接收完成標志 (此處給的10ms等待)
- u8 i,j;
- u8 val_t = 0;
- u16 k=0;
- while(ii<=10 && k<50000) //等待開始接收數(shù)據(jù),50ms沒有收到數(shù)據(jù)就跳出
- k++;
- delay_us(1);
- delay_ms(30);
- // printf("%d\r\n",ii);
- if(ii>20)
- delay_ms(500);
- if(ii>=15 && k<50000)
- for(i=0;i<16;i+=2) //把38k波解調(diào)成邏輯0|1 存到一個字節(jié)的各個位
- if((IR_RXBUff[i]>=Half_IR)||(IR_RXBUff[i+1]>=Half_IR))
- num_b[i/2] = 1;
- else if((IR_RXBUff[i]<Half_IR)&&(IR_RXBUff[i+1]<Half_IR))
- num_b[i/2] = 0;
- for(j=0;j<8;j++) //把2進制數(shù)變?yōu)槭M制數(shù)
- if(num_b[j]==1)
- val_t |= 1<<j;
- *p = val_t;
- ii = 0;
- key_sta = 0;
- return 0;
- return 1;
- //PWM輸出初始化
- //arr:自動重裝值
- //psc:時鐘預分頻數(shù)
- void TIM3_2PWM_Init(u16 arr,u16 psc) //IR -- PWM發(fā)射初始化 PA7--TIM3--CH2
- TIM_OCInitTypeDef TIM_OCInitStructure;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);//
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE); //使能GPIO外設(shè)時鐘使能
- //設(shè)置該引腳為復用輸出功能,輸出TIM1 CH1的PWM脈沖波形
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; //PA7--TIM3--CH2
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //復用推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- TIM_TimeBaseStructure.TIM_Period = arr; //設(shè)置在下一個更新事件裝入活動的自動重裝載寄存器周期的值 80K
- TIM_TimeBaseStructure.TIM_Prescaler =psc; //設(shè)置用來作為TIMx時鐘頻率除數(shù)的預分頻值 不分頻
- TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時間基數(shù)單位
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //選擇定時器模式:TIM脈沖寬度調(diào)制模式2
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比較輸出使能
- TIM_OCInitStructure.TIM_Pulse =0; //設(shè)置待裝入捕獲比較寄存器的脈沖值
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High ; //輸出極性:TIM輸出比較極性高
- TIM_OC2Init(TIM3, &TIM_OCInitStructure); //☆注意這塊的通道數(shù)的選擇☆
- TIM_Cmd(TIM3, ENABLE); //使能TIM4
- void IR_sent(u8 val) //IR發(fā)射 (5ms發(fā)完16位)
- u8 jj=0;
- u8 i,j,k=0;
- //IR發(fā)射前要關(guān)閉紅外接收,防止干擾頻繁進中斷導致單片機hard fuilt
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5,DISABLE); //IR接收初始化 PA1--TIM5--CH2
- for(i=0;i<8;i++) //把十進制數(shù)字變?yōu)槎M制數(shù)字
- if( ( val&(1<<i) ) )
- num_b[i] = 1;
- else
- num_b[i] = 0;
- //調(diào)制數(shù)據(jù)
- for(k=0;k<16;k+=2) //把將二進制的各個位的邏輯0|1加載到38k紅外波上 _deflag
- j=k/2;
- if(num_b[j]==1)
- num_val[k] = L_IR;
- num_val[k+1] = H_IR;
- else if(num_b[j]==0) //為0
- num_val[k+1] = L_IR;
- LED0 = 0;
- for(jj=0;jj<16;jj+=2) //PWM發(fā)射初始化 PA7--TIM3--CH2
- if(num_val[jj]==0)
- TIM_SetCompare2(TIM3,0);
- else
- if(num_val[jj]!=0)
- TIM_SetCompare2(TIM3,(1893/3));
- delay_us(num_val[jj]);
- if(num_val[(jj+1)]!=0)
- delay_us(num_val[(jj+1)]);//程序死在這里了
- delay_us(200);
- delay_ms(1); //延時1毫秒下面這句時鐘使能才會有效.
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5,ENABLE); //IR接收初始化 PA1--TIM5--CH2
- LED0 = 1;
復制代碼
全部資料51hei下載地址:
紅外調(diào)制解調(diào)協(xié)議源碼.rar
(364.8 KB, 下載次數(shù): 40)
2018-7-6 18:32 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
