//讀取某點的顏色
static void ReadColor( uint16_t usX, uint16_t usY, COLOR_RGB* color_rgb )
unsigned short rgb;
rgb = LCD_ReadPoint( usX, usY ); //獲取顏色數(shù)據(jù)
//轉(zhuǎn)換成值域為[0,255]的三原色值
color_rgb->Red = (unsigned char)( ( rgb & 0xF800 ) >> 8 );
color_rgb->Green = (unsigned char)( ( rgb & 0x07E0 ) >> 3 );
color_rgb->Blue = (unsigned char)( ( rgb & 0x001F ) << 3 );
//RGB轉(zhuǎn)換為HLS
//H:色度
//L:亮度
//S:飽和度
static void RGB2HSL( const COLOR_RGB* color_rgb, COLOR_HLS* color_hls )
int r, g, b;
int h, l, s;
int max, min, dif;
r = color_rgb->Red;
g = color_rgb->Green;
b = color_rgb->Blue;
max = maxOf3Values( r, g, b );
min = minOf3Values( r, g, b );
dif = max - min;
//計算l,亮度
l = ( max + min ) * 240 / 255 / 2;
//計算h,色度
if( max == min )//無定義
s = 0;
h = 0;
//計算色度
if( max == r )
if( min == b )//h介于0到40
h = 40 * ( g - b ) / dif;
else if( min == g )//h介于200到240
h = 40 * ( g - b ) / dif + 240;
else if( max == g )
h = 40 * ( b - r ) / dif + 80;
else if( max == b )
h = 40 * ( r - g ) / dif + 160;
//計算飽和度
if( l == 0 )
s = 0;
else if( l <= 120 )
s = dif * 240 / ( max + min );
s = dif * 240 / ( 480 - ( max + min ) );
color_hls->Hue = h; //色度
color_hls->Lightness = l; //亮度
color_hls->Saturation = s; //飽和度
攝像頭(顏色捕捉).rar
2018-7-14 02:12 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
395.78 KB, 下載次數(shù): 236, 下載積分: 黑幣 -5
