查看: 2090|回復(fù): 1
中斷控制pwm的呼吸燈實驗,運行后無效果
ID:366743 發(fā)表于 2018-7-20 15:37 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
stm32f103c8t6練習(xí)pwm(脈沖寬度調(diào)制)實驗,從網(wǎng)上找到一串代碼,稍作修改后運行,不能實現(xiàn)呼吸燈效果,僅僅是PB5,PB6 led燈初始化成功發(fā)光,初學(xué)stm32,新手上路諸多問題難解,還望大神賜教
代碼如下:
#include "stm32f10x.h"
#include "my.h"
void RCC_cfg(void);
void GPIO_cfg(void);
void TIMER_cfg(void);
void PWM_cfg(void);
int led_fx=1;
int led_dt=0;
         void LED_Init(void)
GPIO_InitTypeDef  GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOE, ENABLE);         //使能PB,PE端口時鐘
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6;                                 //LED0-->PB.5 端口配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //IO口速度為50MHz
GPIO_Init(GPIOB, &GPIO_InitStructure);                                         //根據(jù)設(shè)定參數(shù)初始化GPIOB.5
GPIO_SetBits(GPIOB,GPIO_Pin_5 | GPIO_Pin_6  );                                                 //PB.5 輸出高
                                                 //PE.5 輸出高
int main(void)
   RCC_cfg();
   GPIO_cfg();
   TIMER_cfg();
   PWM_cfg();
   //使能TIM2計時器,開始輸出PWM
   TIM_Cmd(TIM2, ENABLE);
         LED_Init();
          delay_ms(5);
         if(led_fx==1)
                 led_dt++;
           led_dt--;
         if(led_dt>500) led_fx=0;
         if(led_dt==0)   led_fx=1;
         TIM_SetCompare4(TIM2,led_dt);
void RCC_cfg(void)
       //定義錯誤狀態(tài)變量
       ErrorStatus HSEStartUpStatus;
       //將RCC寄存器重新設(shè)置為默認值
       RCC_DeInit();
       //打開外部高速時鐘晶振
       RCC_HSEConfig(RCC_HSE_ON);
       //等待外部高速時鐘晶振工作
       HSEStartUpStatus = RCC_WaitForHSEStartUp();
       if(HSEStartUpStatus == SUCCESS)
              //設(shè)置AHB時鐘(HCLK)為系統(tǒng)時鐘
              RCC_HCLKConfig(RCC_SYSCLK_Div1);
              //設(shè)置高速AHB時鐘(APB2)為HCLK時鐘
              RCC_PCLK2Config(RCC_HCLK_Div1);
              //設(shè)置低速AHB時鐘(APB1)為HCLK的2分頻
              RCC_PCLK1Config(RCC_HCLK_Div2);
              //設(shè)置FLASH代碼延時
              FLASH_SetLatency(FLASH_Latency_2);
               //使能預(yù)取指緩存
              FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
              //設(shè)置PLL時鐘,為HSE的9倍頻 8MHz * 9 = 72MHz
              RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
              //使能PLL
              RCC_PLLCmd(ENABLE);
              //等待PLL準備就緒
              while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
              //設(shè)置PLL為系統(tǒng)時鐘源
              RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
              //判斷PLL是否是系統(tǒng)時鐘
              while(RCC_GetSYSCLKSource() != 0x08);
       //開啟TIM2的時鐘
       RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
       //開啟GPIOB的時鐘和復(fù)用功能
       RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO,ENABLE);
void GPIO_cfg(void)
        // GPIO_PinRemapConfig(GPIO_PartialRemap1_TIM2, ENABLE);     //映射引腳,默認PA3 ->TIM2_CH4因此不用映射
       //選擇引腳3
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
       //輸出頻率最大50MHz
       //復(fù)用推挽輸出
       GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
             //PA
       GPIO_Init(GPIOA,&GPIO_InitStructure);
       TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
       //重新將Timer設(shè)置為缺省值
       TIM_DeInit(TIM2);
       //采用內(nèi)部時鐘給TIM2提供時鐘源
       TIM_InternalClockConfig(TIM2);
       //預(yù)分頻系數(shù)為0
       TIM_TimeBaseStructure.TIM_Prescaler = 0;
       //設(shè)置計數(shù)溢出大小
       TIM_TimeBaseStructure.TIM_Period = 500;
       //設(shè)置計數(shù)器模式為向上計數(shù)模式(+1)
       TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
       //設(shè)置時鐘分割
       TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
       //將配置應(yīng)用到TIM2中
       TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure);
void PWM_cfg(void)
       TIM_OCInitTypeDef TimOCInitStructure;
       //設(shè)置缺省值
       TIM_OCStructInit(&TimOCInitStructure);
       //PWM模式1輸出
       TimOCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
       //設(shè)置占空比 (Led亮度)
       TimOCInitStructure.TIM_Pulse = 0;
       //TIM輸出比較極性高
       TimOCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
       //使能輸出狀態(tài)
       TimOCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
       //TIM2的CH4輸出
       TIM_OC4Init(TIM2, &TimOCInitStructure);
       //設(shè)置TIM2的PWM輸出為使能
       TIM_CtrlPWMOutputs(TIM2,ENABLE);
ID:366743 發(fā)表于 2018-7-21 16:49 | 只看該作者
TimOCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;將這一句的pwm高極性改成低極性,即TimOCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
