USB聲卡,用STM32F103RBT6制作,使用TIM驅(qū)動(dòng)IO,PWM方式推挽音頻輸出,驅(qū)動(dòng)8歐姆的喇叭不成問題,僅作為桌面音源使用。
- /* Includes ------------------------------------------------------------------*/
- #include "stm32f1xx_hal.h"
- #include "usb_device.h"
- /* USER CODE BEGIN Includes */
- #include "uart_printf.h"
- #include "usbd_audio.h"
- /* USER CODE END Includes */
- /* Private variables ---------------------------------------------------------*/
- volatile USBD_HandleTypeDef hUsbDeviceFS;
- UART_HandleTypeDef huart1;
- TIM_HandleTypeDef htim2;
- TIM_HandleTypeDef htim3;
- TIM_HandleTypeDef htim4;
- volatile uint8_t Mute;
- uint8_t buffer[AUDIO_TOTAL_BUF_SIZE];
- /* USER CODE BEGIN PV */
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- void Error_Handler(void);
- static void MX_GPIO_Init(void);
- static void MX_TIM3_Init(void);
- static void MX_TIM4_Init(void);
- static void MX_TIM2_Init(void);
- static void MX_USART1_UART_Init(void);
- void HAL_TIM_MspPostInit(TIM_HandleTypeDef *htim);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* USER CODE BEGIN 0 */
- void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
- uint8_t data_tmp;
- if(htim->Instance == TIM2)
- USBD_AUDIO_HandleTypeDef *haudio = (USBD_AUDIO_HandleTypeDef*)(hUsbDeviceFS.pClassData);
- if(haudio->rd_enable == 1)
- //if(haudio->data_len >= 4)
- uint8_t pulse, pulsen;
- haudio->rd_ptr++;
- data_tmp = buffer[haudio->rd_ptr & (AUDIO_TOTAL_BUF_SIZE - 1)];
- pulse = (uint8_t)(data_tmp + 0x80);
- pulsen = (uint8_t)((~data_tmp) + 0x80);
- TIM3->CCR3 = pulse;
- TIM3->CCR4 = pulsen;
- haudio->rd_ptr++;
- haudio->rd_ptr++;
- TIM4->CCR3 = pulse;
- TIM4->CCR4 = pulsen;
- haudio->rd_ptr++;
- haudio->rd_ptr &= (2 * AUDIO_TOTAL_BUF_SIZE -1);
- if(haudio->rd_ptr == haudio->wr_ptr)
- haudio->rd_enable = 0;
- /* USER CODE END 0 */
- int main(void)
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration----------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* Configure the system clock */
- SystemClock_Config();
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_USART1_UART_Init();
- MX_TIM3_Init();
- MX_TIM4_Init();
- MX_TIM2_Init();
- MX_USB_DEVICE_Init();
- /* USER CODE BEGIN 2 */
- Mute = 0;
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- // printf("This is A USB-AUDIO Device\r\n");
- // HAL_Delay(1000);
- /* USER CODE BEGIN 3 */
- /* USER CODE END 3 */
- /** System Clock Configuration
- RCC_OscInitTypeDef RCC_OscInitStruct;
- RCC_ClkInitTypeDef RCC_ClkInitStruct;
- RCC_PeriphCLKInitTypeDef PeriphClkInit;
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
- Error_Handler();
- PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USB;
- PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_PLL_DIV1_5;
- if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
- Error_Handler();
- HAL_RCC_EnableCSS();
- HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
- HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
- /* SysTick_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
- /* USART1 init function */
- huart1.Instance = USART1;
- huart1.Init.BaudRate = 115200;
- huart1.Init.WordLength = UART_WORDLENGTH_8B;
- huart1.Init.StopBits = UART_STOPBITS_1;
- huart1.Init.Parity = UART_PARITY_NONE;
- huart1.Init.Mode = UART_MODE_TX_RX;
- huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
- huart1.Init.OverSampling = UART_OVERSAMPLING_16;
- if (HAL_UART_Init(&huart1) != HAL_OK)
- Error_Handler();
- /* TIM2 init function */
- TIM_ClockConfigTypeDef sClockSourceConfig;
- TIM_MasterConfigTypeDef sMasterConfig;
- htim2.Instance = TIM2;
- htim2.Init.Prescaler = 0;
- htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
- htim2.Init.Period = 2249;
- htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
- if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
- Error_Handler();
- sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
- if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
- Error_Handler();
- sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
- sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
- if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
- Error_Handler();
- /* TIM3 init function */
- // TIM_MasterConfigTypeDef sMasterConfig;
- TIM_OC_InitTypeDef sConfigOC;
- htim3.Instance = TIM3;
- htim3.Init.Prescaler = 0;
- htim3.Init.CounterMode = TIM_COUNTERMODE_UP;
- htim3.Init.Period = 255;
- htim3.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
- if (HAL_TIM_Base_Init(&htim3) != HAL_OK)
- Error_Handler();
- if (HAL_TIM_ConfigClockSource(&htim3, &sClockSourceConfig) != HAL_OK)
- Error_Handler();
- // sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
- // sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
- // if (HAL_TIMEx_MasterConfigSynchronization(&htim3, &sMasterConfig) != HAL_OK)
- // Error_Handler();
- sConfigOC.OCMode = TIM_OCMODE_PWM1;
- sConfigOC.Pulse = 0;
- sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
- sConfigOC.OCFastMode = TIM_OCFAST_ENABLE;
- if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_3) != HAL_OK)
- Error_Handler();
- if (HAL_TIM_PWM_ConfigChannel(&htim3, &sConfigOC, TIM_CHANNEL_4) != HAL_OK)
- Error_Handler();
- HAL_TIM_MspPostInit(&htim3);
- /* TIM4 init function */
- htim4.Instance = TIM4;
- htim4.Init.Prescaler = 0;
- htim4.Init.CounterMode = TIM_COUNTERMODE_UP;
- htim4.Init.Period = 255;
- htim4.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
- if (HAL_TIM_Base_Init(&htim4) != HAL_OK)
- Error_Handler();
- if (HAL_TIM_ConfigClockSource(&htim4, &sClockSourceConfig) != HAL_OK)
- Error_Handler();
- // if (HAL_TIMEx_MasterConfigSynchronization(&htim4, &sMasterConfig) != HAL_OK)
- if (HAL_TIM_OC_ConfigChannel(&htim4, &sConfigOC, TIM_CHANNEL_3) != HAL_OK)
- Error_Handler();
- if (HAL_TIM_OC_ConfigChannel(&htim4, &sConfigOC, TIM_CHANNEL_4) != HAL_OK)
- Error_Handler();
- HAL_TIM_MspPostInit(&htim4);
- /** Configure pins as
- * Analog
- * Input
- * Output
- * EVENT_OUT
- * EXTI
- GPIO_InitTypeDef GPIO_InitStruct;
- /* GPIO Ports Clock Enable */
- __HAL_RCC_GPIOD_CLK_ENABLE();
- __HAL_RCC_GPIOB_CLK_ENABLE();
- __HAL_RCC_GPIOA_CLK_ENABLE();
- /*Configure GPIO pin : PA8 */
- GPIO_InitStruct.Pin = GPIO_PIN_8;
- GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
- HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
- /*Configure GPIO pin Output Level */
- HAL_GPIO_WritePin(GPIOA, GPIO_PIN_8, GPIO_PIN_RESET);
- /*Configure GPIO pin : PD2 */
- GPIO_InitStruct.Pin = GPIO_PIN_2;
- HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
- HAL_GPIO_WritePin(GPIOD, GPIO_PIN_2, GPIO_PIN_SET);
- /* USER CODE BEGIN 4 */
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @param None
- * @retval None
- /* USER CODE BEGIN Error_Handler */
- /* User can add his own implementation to report the HAL error return state */
- while(1)
- /* USER CODE END Error_Handler */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
USB_ADUIO_F1(原版PWM).rar
(1.75 MB, 下載次數(shù): 52)
2018-10-9 21:29 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
