查看: 3199|回復(fù): 2
STM32平衡小車程序與安卓APP源碼
ID:385597 發(fā)表于 2019-1-9 13:19 | 顯示全部樓層 |閱讀模式
內(nèi)含Android控制APP,近期編寫的現(xiàn)在分享給大家
安卓app源碼
  1. #include "stm32f10x.h"
  2. #include "inv_mpu_dmp_motion_driver.h"
  3. #include "math.h"
  4. #include "inv_mpu.h"
  5. #include "oled.h"
  6. #include "delay.h"
  7. #include "adc.h"
  8. #include "motor.h"
  9. #include "mpuiic.h"
  10. #include "mpu6050.h"
  11. #include "timer.h"
  12. #include "usart1.h"
  13. extern int Moto1,Moto2;      //電機(jī)PWM變量 應(yīng)是Motor的 向Moto致敬
  14. extern u8 data[2];           //WIFI數(shù)據(jù)
  15. short aacx=0,aacy=0,aacz=0;         //加速度值
  16. float pitch,roll,yaw=0;      //歐拉角
  17. short y_angle=0;             //Y軸角度
  18. int TIM_2=0,TIM_4=0;         //編碼器脈沖數(shù)
  19. int Battery=0;               //電池電壓
  20. int Balance_PWM=0;           //角度環(huán)輸出脈沖
  21. int Velocity_PWM=0;          //速度環(huán)輸出脈沖
  22. int Turn_PWM=0;              //轉(zhuǎn)向變量
  23. int main(void)
  24. {
  25.
  26.         delay_init();                  //延時(shí)函數(shù)初始化
  27.         OLED_Init();            //OLED初始化
  28.   MiniBalance_PWM_Init(7199,0);
  29.         Encoder_Init_TIM2();    //初始化編碼器左
  30.         Encoder_Init_TIM4();    //初始化編碼器右
  31.         USART1_Init(115200);    //初始化串口1
  32.         ESP8266_Init();         //初始化ESP8266參數(shù)
  33.         Adc_Init();             //ADC初始化
  34.         MPU_Init();             //MPU6050參數(shù)初始化
  35.         mpu_dmp_init();         //MPU6050_DMP初始化
  36.         TIM1_Int_Init(4999,71); //5ms的定時(shí)器中斷
  37.         OLED_Fill(0x00);        //清屏
  38.         OLED_Str_8x16(0,0,"Battery:");
  39.         OLED_Str_8x16(80,0,".");
  40.         OLED_Str_8x16(96,0,"V");
  41.         while(1)
  42.         {
  43.
  44.         Battery=(Get_Adc_Average(8,10)*0.004028)*10;//計(jì)算電池電壓
  45.         OLED_Number_8x16(64,0,Battery/100);
  46.         OLED_Number_8x16(72,0,Battery%100/10);
  47.         OLED_Number_8x16(88,0,Battery%10);
  48.         }
  49. }
  50. /*============================= TIM3定時(shí)5ms================================*/
  51. void TIM1_UP_IRQHandler(void)
  52. {
  53.         if (TIM_GetITStatus(TIM1, TIM_IT_Update) != RESET)//判斷是否更新中斷
  54.         {
  55.         TIM_ClearITPendingBit(TIM1, TIM_IT_Update);//清除中斷標(biāo)志位
  56.         TIM_2=-Read_Encoder(2);//獲取右輪脈沖值
  57.         TIM_4=Read_Encoder(4);//獲取左輪脈沖值
  58.         if(mpu_dmp_get_data(&pitch,&roll,&yaw)==0&&MPU_Get_Gyroscope(&aacx,&aacy,&aacz)==0)//獲取歐拉角和加速度值
  59.         {
  60.
  61.          Balance_PWM=balance(roll,aacx);//直立環(huán)
  62.          Velocity_PWM=velocity(TIM_2,TIM_4);//速度環(huán)
  63.    Moto1=Balance_PWM-Velocity_PWM+Turn_PWM;//計(jì)算右輪PWM值
  64.          Moto2=Balance_PWM-Velocity_PWM-Turn_PWM;//計(jì)算左輪PWM值
  65.          Xianfu_Pwm();//PWM限幅
  66.          Set_Pwm(Moto1,Moto2);//賦值給PWM寄存器
  67.    Motor_Off(roll); //實(shí)時(shí)監(jiān)測(cè)角度 大于或小于50度時(shí) 強(qiáng)制停止電機(jī)
  68.         }
  69.
  70.         }
  71. }
平衡小車APP.7z (5.07 MB, 下載次數(shù): 33)
平衡小車STM32程序.7z (252.55 KB, 下載次數(shù): 43)
ID:493408 發(fā)表于 2019-5-11 23:35 | 顯示全部樓層
老哥,下了你的程序不能用,能聯(lián)系一下嗎,
ID:493408 發(fā)表于 2019-5-11 23:36 | 顯示全部樓層
老哥,下了你的資料不能回復(fù),能聯(lián)系交流一下嗎,非常感謝
