這個代碼我用它顯示是顯示出來了,但是顯示的字和我打的字完全對不上,到底是代碼的問題還是我連線的問題,還是這個LCD12864有問題啊,搞不明白。
顯示成果
2019-1-17 20:09 上傳
代碼部分
2019-1-17 20:09 上傳
- #include "stm32f10x.h"
- #include"12864.h"
- #include"delay.h"
- //FILE:液晶12864驅(qū)動程序
- //VERS:1.0
- @f_name: void LCD12864_InitPort(void)
- @brief: 初始化硬件端口配置
- @param: None
- @return: None
- void LCD12864_InitPort(void)
- GPIO_InitTypeDef GPIO_InitStructure; //定義結(jié)構(gòu)體
- RCC_APB2PeriphClockCmd(GPIOCLK|RCC_APB2Periph_AFIO, ENABLE); //使能功能復(fù)用IO時鐘,不開啟復(fù)用時鐘不能顯示
- GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable,ENABLE); //把調(diào)試設(shè)置普通IO口
- GPIO_InitStructure.GPIO_Pin = LCD_GPIO_DAT; //數(shù)據(jù)口配置成開漏輸出模式,此模式下讀輸入寄存器的值得到IO口狀態(tài)
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD; //開漏輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(LCD12864_GPIO , &GPIO_InitStructure); //IO口初始化函數(shù)(使能上述配置)
- GPIO_InitStructure.GPIO_Pin = LCD_GPIO_CMD;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
- GPIO_Init(LCD12864_GPIO , &GPIO_InitStructure); //初始化IO口配置
- GPIO_Write(LCD12864_GPIO ,0xffff);
- @f_name: void NOP(void)
- @brief: 延時函數(shù)
- @param: None
- @return: None
- void NOP(void)
- { u8 i; for(i=0; i<100; i++); }
- @f_name: u8 LCD12864_busy(void)
- @brief: 檢測忙狀態(tài)
- @param: None
- @return: None
- u8 LCD12864_busy(void)
- u8 x;
- LCD_RS(0);
- LCD_RW(1);
- LCD_EN(1);
- NOP();
- NOP();
- x=Text_Busy;
- LCD_EN(0);
- return x;
- @f_name: void LCD12684_Wcmd(u8 dat)
- @brief: 寫指令
- @param: u8 dat 輸入指令
- @return: None
- void LCD12684_Wcmd(u8 dat)
- while(LCD12864_busy()); //忙檢測
- LCD_RS(0);
- LCD_RW(0);
- LCD_EN(0);
- NOP();
- NOP();
- LCD_WriteData(dat);
- NOP();
- NOP();
- LCD_EN(1);
- NOP();
- NOP();
- LCD_EN(0);
- @brief: 寫數(shù)據(jù)
- @param: u8 dat 輸入數(shù)據(jù)
- @return: None
- void LCD12684_Wdat(u8 dat)
- LCD_RS(1);
- LCD_RW(0);
- LCD_EN(0);
- NOP();
- NOP();
- NOP();
- NOP();
- LCD_EN(1);
- NOP();
- NOP();
- LCD_EN(0);
- @f_name: void LCD12864_Init(void)
- @brief: 液晶初始化
- @param: None
- @return: None
- void LCD12864_Init(void)
- LCD_PSB(1); //并口方式
- LCD_RST(0); //液晶復(fù)位 低電平有效
- delay_ms(3);
- LCD_RST(1); //置高電平等待復(fù)位
- delay_ms(3);
- LCD12684_Wcmd(0x34); //擴(kuò)充指令操作
- delay_ms(5);
- LCD12684_Wcmd(0x30); //基本指令操作
- delay_ms(5);
- LCD12684_Wcmd(0x0c); //顯示開,關(guān)光標(biāo)
- delay_ms(5);
- LCD12684_Wcmd(0x01); //清除LCD的顯示內(nèi)容
- delay_ms(5);
- @f_name: void LCD12864_Clr(void)
- @brief: 清屏
- @param: None
- @return: None
- void LCD12864_Clr(void)
- LCD12684_Wcmd(0x34); //擴(kuò)充指令操作 “繪圖”
- delay_ms(5);
- delay_ms(5);
- LCD12684_Wcmd(0x01); //清屏
- delay_ms(5);
- @f_name: void LCD12864_Pos(u8 x,u8 y)
- @brief: 設(shè)置顯示位置
- @param: u8 x:X軸 u8 y:Y軸
- @return: None
- void LCD12864_Pos(u8 x,u8 y)
- u8 pos;
- if (x==1) {x=0x80;}
- else if (x==2) {x=0x90;}
- else if (x==3) {x=0x88;}
- else if (x==4) {x=0x98;}
- else x=0x80;
- pos = x+y ;
- LCD12684_Wcmd(pos); //顯示地址
- @f_name: void LCD12864_PhotoDis(u8 *bmp)
- @brief: 顯示圖形
- @param: u8 *bmp 圖形數(shù)組
- @return: None
- void LCD12864_PhotoDis(u8 *bmp)
- u8 i,j;
- LCD12684_Wcmd(0x34); //關(guān)閉圖形顯示
- for(i=0;i<32;i++)
- LCD12684_Wcmd(0x80+i); //先寫入水平坐標(biāo)值
- LCD12684_Wcmd(0x80); //寫入垂直坐標(biāo)值
- for(j=0;j<16;j++) //再寫入兩個8位元的數(shù)據(jù)
- LCD12684_Wdat(*bmp++);
- delay_ms(1);
- for(i=0;i<32;i++)
- LCD12684_Wcmd(0x88);
- for(j=0;j<16;j++)
- delay_ms(1);
- LCD12684_Wcmd(0x36); //寫完數(shù)據(jù),開圖形顯示
- @f_name: void LCD_ShowString(u8 x,u8 y,const u8 *p)
- @brief: 顯示字符串
- @return: None
- void LCD_ShowString(u8 x,u8 y,const u8 *p)
- u8 temp;
- if(x>4) {x=1;}
- if(y>4) {y=0;}
- LCD12864_Pos(x,y);
- temp=*p;
- while(temp!='\0')
- LCD12684_Wdat(temp);
- temp=*(++p);
12864顯示成功.7z
(188.48 KB, 下載次數(shù): 25)
2019-1-18 02:30 上傳
點(diǎn)擊文件名下載附件
