MCU型號(hào)為STM32RCT6
庫(kù)函數(shù)為 HAL庫(kù)
初始化代碼生成方式為CUBEMX配置
詳情請(qǐng)見附件源代碼
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "stm32f1xx_hal.h"
- #include "usb_device.h"
- #include "gpio.h"
- /* USER CODE BEGIN Includes */
- #include "usbd_conf.h"
- #include "usbd_cdc.h"
- #include "usbd_desc.h"
- #include "usbd_ctlreq.h"
- /* USER CODE END Includes */
- /* Private variables ---------------------------------------------------------*/
- /* USER CODE BEGIN PV */
- uint8_t USBD_RxCnt = 0;
- uint8_t USBD_RXBuffer[64];
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* USER CODE BEGIN 0 */
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval None
- int main(void) {
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration----------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_USB_DEVICE_Init();
- /* USER CODE BEGIN 2 */
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1) {
- /* USER CODE END WHILE */
- if(USBD_RxCnt > 0) {
- USBD_LL_Transmit(&hUsbDeviceFS,
- CDC_IN_EP,
- USBD_RXBuffer,
- USBD_RxCnt);
- USBD_RxCnt = 0;
- /* USER CODE BEGIN 3 */
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- void SystemClock_Config(void) {
- RCC_OscInitTypeDef RCC_OscInitStruct;
- RCC_ClkInitTypeDef RCC_ClkInitStruct;
- RCC_PeriphCLKInitTypeDef PeriphClkInit;
- /**Initializes the CPU, AHB and APB busses clocks
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
- RCC_OscInitStruct.HSIState = RCC_HSI_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) {
- _Error_Handler(__FILE__, __LINE__);
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
- | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK) {
- PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USB;
- PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_PLL_DIV1_5;
- if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK) {
- /**Configure the Systick interrupt time
- HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq() / 1000);
- HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
- /* SysTick_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
- /* USER CODE BEGIN 4 */
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @param file: The file name as string.
- * @param line: The line in file as a number.
- * @retval None
- void _Error_Handler(char *file, int line) {
- /* USER CODE BEGIN Error_Handler_Debug */
- /* User can add his own implementation to report the HAL error return state */
- while(1) {
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
USB_BULK.7z
(277.72 KB, 下載次數(shù): 48)
2019-3-12 17:59 上傳
點(diǎn)擊文件名下載附件
源代碼
