查看: 13226|回復(fù): 10
單片機(jī)步進(jìn)電機(jī)轉(zhuǎn)速控制程序(速度LED顯示)
ID:273166 發(fā)表于 2019-5-10 18:09 | 顯示全部樓層 |閱讀模式
如題,附件里面是hex文件和Keil(無需下載,復(fù)制下面的代碼編譯也是一樣)下面是代碼
  1. //數(shù)碼管位 高位-----低位
  2. //四個(gè)按鍵控制步進(jìn)電機(jī):正轉(zhuǎn),反轉(zhuǎn),加1,減1
  3. //上電時(shí)電機(jī)啟動(dòng),數(shù)碼管上顯示速度最小檔1,加減檔位均能通過數(shù)碼管顯示出來,電機(jī)采用單雙八拍方式
  4. //電機(jī)轉(zhuǎn)速一共10檔,通過按鍵調(diào)節(jié)轉(zhuǎn)速
  5. //電機(jī)正轉(zhuǎn)時(shí)最高位數(shù)碼管顯示0,反轉(zhuǎn)時(shí)顯示1
  6. #include<reg51.h>
  7. #define uchar unsigned char
  8. #define uint unsigned int
  9. #define led P0//數(shù)碼管段選
  10. #define haha P2
  11. sbit s1 = P1^0;
  12. sbit s2 = P1^1;
  13. sbit s3 = P3^0;
  14. sbit s4 = P3^1;
  15. sbit s5 = P3^2;//按鍵定義,s1正轉(zhuǎn),s2反轉(zhuǎn),s3加1,s4減1
  16. sbit wei3 = P2^3;sbit wei2 = P2^2;sbit wei1 = P2^1;sbit wei0 = P2^0;//數(shù)碼管位選定義
  17. sbit a = P2^7;sbit b = P2^6;sbit c = P2^5;sbit d = P2^4;//脈沖信號(hào)輸入端定義
  18. uchar code tab[11]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};//共陽數(shù)碼管驅(qū)動(dòng)信號(hào)0---9,不顯示
  19. uchar code time_counter[10][2]={{0xda,0x1c},{0xde,0xe4},{0xe1,0xec},{0xe5,0xd4},{0xe9,0xbc},  //9.7 ----1ms
  20.                                                             {0xed,0xa4},{0xf1,0x8c},{0xf5,0x74},{0xf9,0x5c},{0xfc,0x18}};
  21. uchar code qudong[8]={0x80,0xc0,0x40,0x60,0x20,0x30,0x10,0x90};
  22. uchar num1 = 0;//控制取勵(lì)磁信號(hào)變量
  23. uchar num2 = 8;
  24. char k=0;//加減檔位控制,1為最小檔
  25. char pause=1;//暫停時(shí)保存之前的轉(zhuǎn)速,開機(jī)默認(rèn)1
  26. bit flag1 = 0;//初始正轉(zhuǎn),正反轉(zhuǎn)標(biāo)志
  27. uchar buf[4]={0,10,0,0};//數(shù)碼管顯示緩存,正轉(zhuǎn),不顯示,不顯示,顯示1檔位,高----低
  28. //================================定時(shí)器0/1初始化函數(shù)================================
  29. void T0_T1_init()
  30. {
  31.         TMOD = 0x11;//定時(shí)器0/1均工作于方式1,16位計(jì)時(shí)方式
  32.            TH1 = time_counter[k-1][0];
  33.         TL1 = time_counter[k-1][1];//定時(shí)器1,定時(shí)10ms用于步進(jìn)電機(jī)轉(zhuǎn)速控制
  34.         TR1 = 0;
  35.         ET1= 1;//開定時(shí)器中斷
  36.         EA = 1;//開總中斷
  37. }
  38. //================================ms級(jí)延時(shí)函數(shù)=======================================
  39. void delay1m(uint x)
  40. {
  41.     uint i,j;
  42.     for(i=0;i<x;i++)      //連數(shù)x次,約 x ms
  43.              for(j=0;j<120;j++);   //數(shù)120 次,約1 ms
  44. }
  45. void display()
  46. {
  47.         wei3=1;wei2=1;wei1=1;wei0=0;led = tab[buf[3]];delay1m(1);led=0xff;
  48.     wei3=1;wei2=1;wei1=0;wei0=1;led = tab[buf[2]];delay1m(1);led=0xff;
  49.     wei3=1;wei2=0;wei1=1;wei0=1;led = tab[buf[1]];delay1m(1);led=0xff;
  50.         wei3=0;wei2=1;wei1=1;wei0=1;led = tab[buf[0]];delay1m(1);led=0xff;
  51. }
  52. //================================主函數(shù)=============================================
  53. void main()
  54. {
  55.         T0_T1_init();
  56.         buf[1] = 10;//不顯示
  57.         while(1)
  58.         {
  59.                 display();
  60.                 if(s1 == 0)
  61.                 {
  62.                         delay1m(3);
  63.                         if(s1 == 0)
  64.                         {
  65.                                 flag1 = 0;//正轉(zhuǎn)
  66.                                 buf[0] = 0;//最高位顯示0
  67.                 //                haha = 0x00;//停止
  68.
  69.                         }
  70.                         while(!s1) display();
  71.                 }
  72.                 if(s2 == 0 )
  73.                 {
  74.
  75.                         delay1m(3);
  76.                         if(s2 == 0)
  77.                         {
  78.
  79.                                 flag1 = 1;//反轉(zhuǎn)
  80.                                 buf[0] = 1;//最高位顯示1
  81.                 //                haha = 0x00;//停止
  82.                         }
  83.                         while(!s2) display();
  84.                 }
  85.                 if(s3 == 0)           //速度加1檔
  86.                 {
  87.                         delay1m(3);
  88.                         if(s3 == 0)
  89.                         {
  90.                                 k++;
  91.                                 TR1=1;
  92.                                 if(k > 10 )
  93.                                 {
  94.                                         k = 1;
  95.                                 }
  96.                                 buf[2]= k/10;
  97.                                 buf[3]= k%10;
  98.                         }
  99.                         while(!s3) display();
  100.                 }
  101.                 if(s4 == 0)         //速度減1檔
  102.                 {
  103.                         delay1m(3);
  104.                         if(s4 == 0)
  105.                         {
  106.                                 k--;
  107.                                 TR1=1;
  108.                                 if(k <= 0)
  109.                                 {
  110.                                         k = 10;
  111.                                 }
  112.                                 buf[2]= k/10;
  113.                                 buf[3]= k%10;
  114.                         }
  115.                         while(!s4) display();
  116.                 }
  117.                 if(s5==0)
  118.                 {
  119.                         delay1m(3);
  120.                         if(s5==0)
  121.                         {
  122.                                 if(TR1==1)
  123.                                 {
  124.                                         pause=k;
  125.                                         k=0;
  126.                                         TR1=0;
  127.                                         a=b=c=d=0;
  128.                                 }
  129.                                 else if(TR1==0)
  130.                                 {
  131.                                         k=pause;
  132.                                         TR1=1;
  133.                                 }
  134.                                 buf[2]= k/10;
  135.                                 buf[3]= k%10;
  136.                                 while(!s5) display();
  137.                         }
  138.                 }
  139.         }
  140. }
  141. //==================================定時(shí)器1中斷函數(shù),用于脈沖頻率控制=====================================
  142. void time1_interrupt()interrupt 3
  143. {
  144.         static num1 = 0;
  145.         static num2 = 0;
  146.         TH1 = time_counter[k-1][0];
  147.         TL1 = time_counter[k-1][1];//定時(shí)器1,定時(shí)1 用于步進(jìn)電機(jī)轉(zhuǎn)速控制
  148.         if(flag1 == 0)//正轉(zhuǎn)
  149.         {
  150.                 switch(num1)
  151.                 {
  152.                         case 0:a = 1;b = 0;c = 0;d = 0;break;
  153.                         case 1:a = 1;b = 1;c = 0;d = 0;break;
  154.                         case 2:a = 0;b = 1;c = 0;d = 0;break;
  155.                         case 3:a = 0;b = 1;c = 1;d = 0;break;
  156.                         case 4:a = 0;b = 0;c = 1;d = 0;break;
  157.                         case 5:a = 0;b = 0;c = 1;d = 1;break;
  158.                         case 6:a = 0;b = 0;c = 0;d = 1;break;
  159.                         case 7:a = 1;b = 0;c = 0;d = 1;break;
  160.                 }
  161.                 num1++;
  162.                 if(num1 == 8)num1 = 0;
  163.         }
  164.         else                  //反轉(zhuǎn)
  165.         {
  166.                 switch(num2)
  167.                 {
  168.                         case 0:a = 1;b = 0;c = 0;d = 1;break;
  169.                         case 1:a = 0;b = 0;c = 0;d = 1;break;
  170.                         case 2:a = 0;b = 0;c = 1;d = 1;break;
  171.                         case 3:a = 0;b = 0;c = 1;d = 0;break;
  172.                         case 4:a = 0;b = 1;c = 1;d = 0;break;
  173.                         case 5:a = 0;b = 1;c = 0;d = 0;break;
  174.                         case 6:a = 1;b = 1;c = 0;d = 0;break;
  175.                         case 7:a = 1;b = 0;c = 0;d = 0;break;
  176.                 }
  177.                 num2++;
  178.                 if(num2 == 8)num2 = 0;
  179.         }
  180. }
此商品已被刪除
1-步進(jìn)程序.rar
25.63 KB, 下載次數(shù):
ID:518363 發(fā)表于 2019-5-17 17:07 | 顯示全部樓層
咋下載啊
ID:118693 發(fā)表于 2019-5-22 20:30 | 顯示全部樓層
感謝樓主的分享,謝謝
ID:242883 發(fā)表于 2019-5-23 16:32 | 顯示全部樓層
非常實(shí)用,感謝分享
ID:584041 發(fā)表于 2019-7-14 20:53 | 顯示全部樓層
請問加速減速有上下限嗎?有沒有那種能直接規(guī)定轉(zhuǎn)速的程序,我覺得這樣更好
ID:680644 發(fā)表于 2020-1-3 18:23 | 顯示全部樓層
樓主您好,想請教個(gè)問題,如何修改上述程序,使步進(jìn)電機(jī)加速時(shí),從1自動(dòng)逐漸加速到10?
ID:688122 發(fā)表于 2020-2-7 15:36 | 顯示全部樓層
感謝樓主的分享,謝謝,以后還要跟樓主學(xué)習(xí)
ID:619412 發(fā)表于 2020-7-24 20:28 | 顯示全部樓層
為啥我下載之后,打不開,啥都沒有,cannot projet。。。。。
ID:328014 發(fā)表于 2020-7-24 20:32 | 顯示全部樓層
懶得想 發(fā)表于 2020-7-24 20:28
這個(gè)沒必要下載吧,下載的文件里面只有代碼,而全部的代碼已經(jīng)在網(wǎng)頁上面了,所以下載完全是多此一舉
ID:842504 發(fā)表于 2020-11-16 14:11 來自觸屏版 | 顯示全部樓層
這個(gè)程序框圖怎么寫呢
ID:304740 發(fā)表于 2023-3-30 23:31 | 顯示全部樓層
感謝你的資料,不錯(cuò)不錯(cuò)下載研究下。
