15黑幣
采用一個(gè)例程改了一下,從PA3和PA4讀取電壓值,但只輸出了一個(gè)數(shù)據(jù),請(qǐng)問(wèn)一下是不是配置什么的有問(wèn)題?
#include "adc.h"
#include "SysTick.h"
#define ADC1_DR_Address ((u32)0x40012400+0x4c)
// #define ADC1_DR_Address ((uint32_t)0x4001244C)
//u16 AD_Value[3];
uint16_t ADC_ConvertedValue[3];
* 函 數(shù) 名 : ADCx_Init
* 函數(shù)功能 : ADC初始化
* 輸 入 : 無(wú)
* 輸 出 : 無(wú)
void ADCx_Init(void)
GPIO_InitTypeDef GPIO_InitStructure; //定義結(jié)構(gòu)體變量
ADC_InitTypeDef ADC_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOA|RCC_APB2Periph_ADC1|RCC_APB2Periph_AFIO,ENABLE);
RCC_ADCCLKConfig(RCC_PCLK2_Div6);//設(shè)置ADC分頻因子6 72M/6=12,ADC最大時(shí)間不能超過(guò)14M
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
DMA_DeInit(DMA1_Channel1);
DMA_InitStructure.DMA_PeripheralBaseAddr =(u32)&ADC1->DR;
DMA_InitStructure.DMA_MemoryBaseAddr =(u32)&ADC_ConvertedValue;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
DMA_InitStructure.DMA_BufferSize = 2;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
DMA_Cmd(DMA1_Channel1, ENABLE);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3;//ADC
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN; //模擬輸入
// GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOA,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4;//ADC
ADC_DeInit(ADC1);//?? ADC1,?? ADC1,
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_InitStructure.ADC_ScanConvMode = ENABLE;//掃描模式
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//開(kāi)啟連續(xù)轉(zhuǎn)換
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//禁止觸發(fā)檢測(cè),使用軟件觸發(fā)
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//右對(duì)齊
ADC_InitStructure.ADC_NbrOfChannel = 2;//1個(gè)轉(zhuǎn)換在規(guī)則序列中 也就是只轉(zhuǎn)換規(guī)則序列1
ADC_Init(ADC1, &ADC_InitStructure);//ADC初始化
ADC_DMACmd(ADC1, ENABLE);
ADC_Cmd(ADC1, ENABLE);//開(kāi)啟AD轉(zhuǎn)換器
ADC_ResetCalibration(ADC1);//重置指定的ADC的校準(zhǔn)寄存器
while(ADC_GetResetCalibrationStatus(ADC1));//獲取ADC重置校準(zhǔn)寄存器的狀態(tài)
ADC_StartCalibration(ADC1);//開(kāi)始指定ADC的校準(zhǔn)狀態(tài)
while(ADC_GetCalibrationStatus(ADC1));//獲取指定ADC的校準(zhǔn)程序
ADC_SoftwareStartConvCmd(ADC1, ENABLE);//使能或者失能指定的ADC的軟件轉(zhuǎn)換啟動(dòng)功能
* 函 數(shù) 名 : Get_ADC_Value
* 函數(shù)功能 : 獲取通道ch的轉(zhuǎn)換值,取times次,然后平均
* 輸 入 : ch:通道編號(hào)
times:獲取次數(shù)
* 輸 出 : 通道ch的times次轉(zhuǎn)換結(jié)果平均值
u16 Get_ADC_Value(u8 ch,u8 times)
u32 temp_val=0;
u8 t;
//設(shè)置指定ADC的規(guī)則組通道,一個(gè)序列,采樣時(shí)間
ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_239Cycles5); //ADC1,ADC通道,239.5個(gè)周期,提高采樣時(shí)間可以提高精確度
for(t=0;t<times;t++)
// ADC_SoftwareStartConvCmd(ADC1, ENABLE);//使能指定的ADC1的軟件轉(zhuǎn)換啟動(dòng)功能
while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));//等待轉(zhuǎn)換結(jié)束
//temp_val+=ADC_GetConversionValue(ADC1);
temp_val+=ADC_ConvertedValue[0];
// temp_val+=AD_Value[0];
delay_ms(5);
return temp_val/times;
u16 Get_ADC1_Value(u8 ch,u8 times)
u32 temp_val=0;
u8 t;
ADC_RegularChannelConfig(ADC1, ch, 2, ADC_SampleTime_239Cycles5); //ADC1,ADC通道,239.5個(gè)周期,提高采樣時(shí)間可以提高精確度
temp_val+=ADC_ConvertedValue[1];
// temp_val+=AD_Value[1];
delay_ms(5);
