查看: 3184|回復: 0
STM32驅(qū)動4*4矩陣鍵盤程序,無上拉電阻,直接可用
ID:581876 發(fā)表于 2019-8-5 09:26 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
STM32單片機源程序如下:
  1. #include "Keyboard.h"
  2. #include "stm32f10x.h"
  3. #define Key_GPIO  GPIOD
  4. #define ReKey     RCC_APB2Periph_GPIOD
  5. #define Key_Hang  0x000f
  6. #define Key_Lie   0x00f0
  7. /**
  8. * 函數(shù)功能:矩陣鍵盤初始化
  9. * 參 數(shù)   :無
  10. * 返回值  :無
  11. */
  12. void KEY_Config(void)
  13. {
  14.         GPIO_InitTypeDef GPIO_InitStructure;
  15.         RCC_APB2PeriphClockCmd(ReKey,ENABLE);  //使能
  16.         GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_IPU;  //上拉輸入
  17.         GPIO_InitStructure.GPIO_Pin   = Key_Hang;
  18.         GPIO_Init(Key_GPIO,&GPIO_InitStructure);
  19.
  20.         GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_Out_PP;  //推挽輸出
  21.         GPIO_InitStructure.GPIO_Pin   = Key_Lie;
  22.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  23.         GPIO_Init(Key_GPIO,&GPIO_InitStructure);
  24.         GPIO_SetBits(Key_GPIO,Key_Lie);
  25. }
  26. /**
  27. * 函數(shù)功能:松手檢測
  28. * 參 數(shù)   :無
  29. * 返回值  :成功-0  失敗-1
  30. */
  31. uint8_t keyScan(GPIO_TypeDef* GPIOx,uint16_t GPIO_Pin)
  32. {
  33.         if(GPIO_ReadInputDataBit(GPIOx,GPIO_Pin) == 0)
  34.         {
  35.                         while(GPIO_ReadInputDataBit(GPIOx,GPIO_Pin) == 0);  //松手檢測
  36.                         return 0;
  37.         }
  38.         else
  39.                 return 1;
  40. }
  41. /**
  42. * 函數(shù)功能:按鍵檢測
  43. * 參 數(shù)   :無
  44. * 返回值  :int型鍵值
  45. */
  46. int Key_Scan(void)
  47. {
  48.         static u16 pin[4] = {GPIO_Pin_4 , GPIO_Pin_5 , GPIO_Pin_6 , GPIO_Pin_7};
  49.         static uint8_t i = 0;
  50.         int temp = -1;
  51.
  52.         GPIO_ResetBits(Key_GPIO,pin[i]);  //輪流置低
  53.
  54.         if(keyScan(Key_GPIO,GPIO_Pin_0) == 0)  //如果第一行有按鍵按下
  55.         {
  56.                 switch(i)
  57.                 {
  58.                         case 0:return 0;
  59.                         case 1:return 1;
  60.                         case 2:return 2;
  61.                         case 3:return 3;
  62.                 }
  63.         }
  64.         else if(keyScan(Key_GPIO,GPIO_Pin_1) == 0)   //如果第二行有按鍵按下
  65.         {
  66.                 switch(i)
  67.                 {
  68.                         case 0:return 4;
  69.                         case 1:return 5;
  70.                         case 2:return 6;
  71.                         case 3:return 7;
  72.                 }
  73.         }
  74.         else if(keyScan(Key_GPIO,GPIO_Pin_2) == 0)   //如果第三行有按鍵按下
  75.         {
  76.                 switch(i)
  77.                 {
  78.                         case 0:return 8;
  79.                         case 1:return 9;
  80.                         case 2:return 10;
  81.                         case 3:return 11;
  82.                 }
  83.         }
  84.         else if(keyScan(Key_GPIO,GPIO_Pin_3) == 0)   //如果第四行有按鍵按下
  85.         {
  86.                 switch(i)
  87.                 {
  88.                         case 0:return 12;
  89.                         case 1:return 13;
  90.                         case 2:return 14;
  91.                         case 3:return 15;
  92.                 }
  93.         }
  94.         GPIO_SetBits(Key_GPIO,pin[i]);  //置高
  95.
  96.         i++;
  97.                 if(i >= 4)
  98.                         i = 0;
  99.         return temp;
  100. }
復制代碼
4×4矩陣鍵盤.7z (175.25 KB, 下載次數(shù): 78)
admin + 50 共享資料的黑幣獎勵!
收藏收藏3 分享淘帖 頂 踩
