查看: 1952|回復(fù): 1
STM32F103位操作
ID:302293 發(fā)表于 2019-8-22 18:44 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#ifndef __SYS_H
#define __SYS_H
#include "stm32f10x.h"
//0,不支持ucos
//1,支持ucos
#define SYSTEM_SUPPORT_UCOS                0                //定義系統(tǒng)文件夾是否支持UCOS
//位帶操作,實(shí)現(xiàn)51類似的GPIO控制功能
//具體實(shí)現(xiàn)思想,參考<<CM3權(quán)威指南>>第五章(87頁(yè)~92頁(yè)).
//IO口操作宏定義
#define BITBAND(addr, bitnum) ((addr & 0xF0000000)+0x2000000+((addr &0xFFFFF)<<5)+(bitnum<<2))
#define MEM_ADDR(addr)  *((volatile unsigned long  *)(addr))
#define BIT_ADDR(addr, bitnum)   MEM_ADDR(BITBAND(addr, bitnum))
//IO口地址映射
#define GPIOA_ODR_Addr    (GPIOA_BASE+12) //0x4001080C
#define GPIOB_ODR_Addr    (GPIOB_BASE+12) //0x40010C0C
#define GPIOC_ODR_Addr    (GPIOC_BASE+12) //0x4001100C
#define GPIOD_ODR_Addr    (GPIOD_BASE+12) //0x4001140C
#define GPIOE_ODR_Addr    (GPIOE_BASE+12) //0x4001180C
#define GPIOF_ODR_Addr    (GPIOF_BASE+12) //0x40011A0C
#define GPIOG_ODR_Addr    (GPIOG_BASE+12) //0x40011E0C
#define GPIOA_IDR_Addr    (GPIOA_BASE+8) //0x40010808
#define GPIOB_IDR_Addr    (GPIOB_BASE+8) //0x40010C08
#define GPIOC_IDR_Addr    (GPIOC_BASE+8) //0x40011008
#define GPIOD_IDR_Addr    (GPIOD_BASE+8) //0x40011408
#define GPIOE_IDR_Addr    (GPIOE_BASE+8) //0x40011808
#define GPIOF_IDR_Addr    (GPIOF_BASE+8) //0x40011A08
#define GPIOG_IDR_Addr    (GPIOG_BASE+8) //0x40011E08
//IO口操作,只對(duì)單一的IO口!
//確保n的值小于16!
#define PAout(n)   BIT_ADDR(GPIOA_ODR_Addr,n)  //輸出
#define PAin(n)    BIT_ADDR(GPIOA_IDR_Addr,n)  //輸入
#define PBout(n)   BIT_ADDR(GPIOB_ODR_Addr,n)  //輸出
#define PBin(n)    BIT_ADDR(GPIOB_IDR_Addr,n)  //輸入
#define PCout(n)   BIT_ADDR(GPIOC_ODR_Addr,n)  //輸出
#define PCin(n)    BIT_ADDR(GPIOC_IDR_Addr,n)  //輸入
#define PDout(n)   BIT_ADDR(GPIOD_ODR_Addr,n)  //輸出
#define PDin(n)    BIT_ADDR(GPIOD_IDR_Addr,n)  //輸入
#define PEout(n)   BIT_ADDR(GPIOE_ODR_Addr,n)  //輸出
#define PEin(n)    BIT_ADDR(GPIOE_IDR_Addr,n)  //輸入
#define PFout(n)   BIT_ADDR(GPIOF_ODR_Addr,n)  //輸出
#define PFin(n)    BIT_ADDR(GPIOF_IDR_Addr,n)  //輸入
#define PGout(n)   BIT_ADDR(GPIOG_ODR_Addr,n)  //輸出
#define PGin(n)    BIT_ADDR(GPIOG_IDR_Addr,n)  //輸入
#endif
收藏收藏2 分享淘帖 頂 踩
ID:71535 發(fā)表于 2019-9-16 19:43 | 只看該作者
這種好東西一定要及時(shí)的存起來(lái)
