基于DHT11溫濕度傳感器的孵化系統(tǒng)供初學(xué)者練習(xí)。主要有DHT11驅(qū)動(dòng)并將溫濕度顯示等。
- # include <reg51.h>
- # include <intrins.h>
- typedef unsigned char BYTE;
- typedef unsigned int WORD;
- unsigned char c;
- #define uint unsigned int
- #define uchar unsigned char
- #define MotorData P0 //步進(jìn)電機(jī)控制接口定義
- sbit PENWU=P2^0; //加濕器接口定義
- sbit FengShan1=P1^1; //風(fēng)扇1接口定義
- sbit FengShan2=P1^2; // 風(fēng)扇2接口定義
- sbit io=P1^0; //dht11out端接單片機(jī)的P1^0口//
- sbit rw=P0^6; //以下三行是設(shè)置lcd1602的使能端//
- sbit rs=P0^7;
- sbit ep=P0^5;
- typedef bit BOOL; //此聲明一個(gè)布爾型變量即真或假//
- uchar data_byte;
- uchar RH,RL,TH,TL;
- uchar phasecw[4] ={0x08,0x04,0x02,0x01};//電機(jī)導(dǎo)通相序 D-C-B-A
- uchar phaseccw[4]={0x01,0x02,0x04,0x08};//反轉(zhuǎn)機(jī)導(dǎo)通相序 A-B-C-D
- void Delay_xms(uint x) //ms延時(shí)函數(shù)
- uint i,j;
- for(i=0;i<x;i++)
- for(j=0;j<112;j++);
- void MotorCW(void) //順時(shí)針轉(zhuǎn)動(dòng)
- uchar i;
- for(i=0;i<4;i++)
- MotorData=phasecw[i];
- Delay_xms(4); //轉(zhuǎn)速調(diào)節(jié)
- void MotorCCW(void) //逆時(shí)針轉(zhuǎn)動(dòng)
- uchar i;
- for(i=0;i<4;i++)
- MotorData=phaseccw[i];
- void MotorStop(void) //停止轉(zhuǎn)動(dòng)
- MotorData=0x00;
- //***************延時(shí)函數(shù)*************************************
- void delay(uchar ms) //延時(shí)模塊//
- uchar i;
- while(ms--)
- for(i=0;i<100;i++);
- void delay1()//一個(gè)for循環(huán)大概需要8個(gè)多機(jī)器周期一個(gè)機(jī)器周期為1us晶振為12MHz也就是說(shuō)本函數(shù)延時(shí)8us多此延時(shí)函數(shù)必須德稍微精確一點(diǎn)
- uchar i;
- for(i=0;i<1;i++);
- //lcd模塊//
- BOOL lcd_bz()//測(cè)試lcd忙碌狀態(tài)返回值為布爾型數(shù)值真或假'1'.'0'
- BOOL result;
- rs=0; // 讀忙信號(hào)
- rw=1;
- ep=1;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- result = (BOOL)(P2&0x80);
- ep=0;
- result ;
- void write_cmd(uchar cmd)//寫指令//
- while (lcd_bz());
- rs=0;
- rw=0;
- ep=0;
- _nop_();
- _nop_();
- P2=cmd ;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- ep=1;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- ep=0;
- void write_addr(uchar addr)//寫地址//
- write_cmd(addr|0x80);//LCD第一行的首地址為0x80第二行的首地址為0x80+0x40=0xc0
- void write_byte(uchar dat) //寫字節(jié)//
- while (lcd_bz());
- rs=1;
- rw=0;
- ep=0;
- _nop_();
- _nop_();
- P2=dat ;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- ep=1;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- ep=0;
- void lcd_init() //lcd初始化//
- write_cmd(0x38);//設(shè)置LCD兩行顯示一個(gè)數(shù)據(jù)由5*7點(diǎn)陣表示,數(shù)據(jù)由八根線傳輸
- delay(1);
- write_cmd(0x0c);//清除屏幕顯示
- delay(1);
- write_cmd(0x06);//設(shè)定輸入方式增量不移位
- delay(1);
- write_cmd(0x01);//開整體顯示關(guān)光標(biāo)不閃爍
- delay(1);
- void display(uchar addr,uchar q)//在某一地址上顯示內(nèi)容adder表示的是地址偏移量q表示顯示的字符或數(shù)字//
- delay(10); write_addr(addr);
- write_byte(q);
- delay(1);//修改此時(shí)間?梢愿淖僉CD上數(shù)值跳變的數(shù)度
- //**************************dht11測(cè)試某塊*************************************//
- void start()//開始信號(hào)
- io=1;
- delay1();
- io=0;
- delay(25);// 主機(jī)把總線拉低必須大于18ms保證DHT11能檢測(cè)到起始信號(hào)
- io=1; //發(fā)送開始信號(hào)結(jié)束后拉高電平延時(shí)20-40us
- delay1();//以下三個(gè)延時(shí)函數(shù)差不多為24us符合要求
- delay1();
- delay1();
- uchar receive_byte()//接收一個(gè)字節(jié)//
- uchar i,temp;
- for(i=0;i<8;i++)//接收8bit的數(shù)據(jù)
- while(!io);//等待50us的低電平開始信號(hào)結(jié)束
- delay1();//開始信號(hào)結(jié)束之后延時(shí)26us-28us以下三個(gè)延時(shí)函數(shù)
- delay1();
- delay1();
- temp=0;//時(shí)間為26us-28us表示接收的為數(shù)據(jù)'0'
- if(io==1)
- temp=1; //如果26us-28us之后還為高電平則表示接收的數(shù)據(jù)為'1'
- while(io);//等待數(shù)據(jù)信號(hào)高電平'0'為26us-28us'1'為70us
- data_byte<<=1;//接收的數(shù)據(jù)為高位在前右移
- data_byte|=temp;
- return data_byte;
- void receive()//接收數(shù)據(jù)//
- uchar T_H,T_L,R_H,R_L,check,num_check,i;
- start();//開始信號(hào)//
- io=1; //主機(jī)設(shè)為輸入判斷從機(jī)DHT11響應(yīng)信號(hào)
- if(!io)//判斷從機(jī)是否有低電平響應(yīng)信號(hào)//
- while(!io);//判斷從機(jī)發(fā)出 80us 的低電平響應(yīng)信號(hào)是否結(jié)束//
- while(io);//判斷從機(jī)發(fā)出 80us 的高電平是否結(jié)束如結(jié)束則主機(jī)進(jìn)入數(shù)據(jù)接收狀態(tài)
- R_H=receive_byte();//濕度高位
- R_L=receive_byte();//濕度低位
- T_H=receive_byte();//溫度高位
- T_L=receive_byte();//溫度低位
- check=receive_byte();//校驗(yàn)位
- io=0; //當(dāng)最后一bit數(shù)據(jù)接完畢后從機(jī)拉低電平50us//
- for(i=0;i<7;i++)//差不多50us的延時(shí)
- delay1();
- io=1;//總線由上拉電阻拉高進(jìn)入空閑狀態(tài)
- num_check=R_H+R_L+T_H+T_L;
- if(num_check==check)//判斷讀到的四個(gè)數(shù)據(jù)之和是否與校驗(yàn)位相同
- RH=R_H;
- RL=R_L;
- TH=T_H;
- TL=T_L;
- check=num_check;
- void FengShan1QD(void)
- FengShan1=1;
- void FengShan1TZ(void)
- FengShan1=0;
- void FengShan2QD(void)
- FengShan2=1;
- void FengShan2TZ(void)
- FengShan2=0;
- void PENWUQD(void)
- PENWU=1;
- void PENWUTZ(void)
- PENWU=0;
- void main()//主函數(shù)模塊//
- lcd_init();//初始化LCD
- while(1)
- receive();//接收數(shù)據(jù)
- display(0x00,'R');//LCD的第一行顯示
- display(0x01,':');
- display(0x02,RH/10+0x30); //0x30表示帶字庫(kù)的LCD1602中0x30的位置放有數(shù)字0RH/10+0x30即表示濕度的十位數(shù)字在字庫(kù)RH/10+0x30的位置處放著
- display(0x03,RH%10+0x30);
- display(0X04,'%');
- display(0x40,'T');//LCD的第二行顯示
- display(0x41,':');
- display(0x42,TH/10+0x30);
- display(0x43,TH%10+0x30);
- display(0x44,0xdf);//以下兩個(gè)是溫度單位的處理
- display(0x45,0x43);
- if(RH<65)//濕度定義
- PENWUQD();
- if(RH>75)
- PENWUTZ();
- if(TH>37)//溫度定義
- FengShan2QD();
- if(TH<34)
- FengShan2TZ();
- Delay_xms(50); //等待系統(tǒng)穩(wěn)定
- TMOD=0x01;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- EA=1; ET0=1;
- TR0=1;
- c=0;
- while(1);
- void timer0() interrupt 1
- { uint i;
- TR0=0;
- c++;
- if(c==100) // 定時(shí)50ms 定時(shí)20次是1秒,再乘以14400是四個(gè)小時(shí)
- for(i=0;i<500;i++)
- MotorCW(); //順時(shí)針轉(zhuǎn)動(dòng)
- MotorStop(); //停止轉(zhuǎn)動(dòng)
- Delay_xms(500);
- MotorCCW(); //逆時(shí)針轉(zhuǎn)動(dòng)
- Delay_xms(500);
- else
- MotorStop();
- TR0=1;
孵化裝置.zip
(40.6 KB, 下載次數(shù): 25)
2019-12-11 12:05 上傳
點(diǎn)擊文件名下載附件
