查看: 1799|回復: 1
程序想移植成51單片機的程序,應該注意點什么?
ID:671549 發(fā)表于 2020-1-2 13:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. void Gesture_test(void)
  2. { unsigned char i,status;
  3. unsigned char data[2]={0x00}
  4.          unsigned short gesture_data;
  5.         paj7620u2_selectBank(BANK0);//進入BANK0寄存器區(qū)域
  6.         for(i=0;i<GESTURE_SIZE;i++)
  7.         {
  8.                 GS_Write_Byte(gesture_arry[i][0],gesture_arry[i][1]);//手勢識別模式初始化
  9.         }
  10.         paj7620u2_selectBank(BANK0);//切換回BANK0寄存器區(qū)域
  11.         i=0;
  12.         while(1)
  13.         {
  14.                 if(key==WKUP_PRES)
  15.                 {
  16.                         GS_Write_Byte(PAJ_SET_INT_FLAG1,0X00);//關閉手勢識別中斷輸出
  17.                         GS_Write_Byte(PAJ_SET_INT_FLAG2,0X00);
  18.                         break;
  19.                 }
  20.         status = GS_Read_nByte(PAJ_GET_INT_FLAG1,2,&data[0]);//讀取手勢狀態(tài)
  21.                 if(!status)
  22.                 {
  23.                         gesture_data =(u16)data[1]<<8 | data[0];
  24.                         if(gesture_data)
  25.                         {
  26.                                 switch(gesture_data)
  27.                                 {
  28.                                         case GES_UP:               LCD_ShowString(110,250,200,16,24,"UP          ");
  29.        printf("Up\r\n");            ledflash=1;      break; //向上
  30.                                         case GES_DOWM:             LCD_ShowString(100,250,200,16,24,"Dowm        ");
  31.        printf("Dowm\r\n");          ledflash=1;      break; //向下
  32.                                         case GES_LEFT:             LCD_ShowString(100,250,200,16,24,"Left        ");
  33.        printf("Left\r\n");          ledflash=1;      break; //向左
  34.                                         case GES_RIGHT:            LCD_ShowString(100,250,200,16,24,"Right       ");
  35.        printf("Right\r\n");         ledflash=1;      break; //向右
  36.                                         case GES_FORWARD:          LCD_ShowString(80,250,200,16,24,"Forward     ");
  37.        printf("Forward\r\n");       ledflash=1;      break; //向前
  38.                                         case GES_BACKWARD:         LCD_ShowString(80,250,200,16,24,"Backward    ");
  39.        printf("Backward\r\n");      ledflash=1;      break; //向后
  40.                                         case GES_CLOCKWISE:        LCD_ShowString(70,250,200,16,24,"Clockwise   ");
  41.        printf("Clockwise\r\n");     ledflash=1;      break; //順時針
  42.                                         case GES_COUNT_CLOCKWISE:  LCD_ShowString(50,250,200,16,24,"AntiClockwise");
  43.        printf("AntiClockwise\r\n"); ledflash=1;      break; //逆時針
  44.                                         case GES_WAVE:             LCD_ShowString(100,250,200,16,24,"Wave         ");
  45.        printf("Wave\r\n");          ledflash=1;      break; //揮動
  46.                                         default:  ledflash=0; break;
  47.
  48.                                 }
  49.                         }
  50.
  51.                 }
  52.                 delay_ms(50);
  53.                 i++;
  54.                 if(i==5)
  55.                 {
  56.                         LED0=!LED0;//提示系統(tǒng)正在運行
  57.                         i=0;
  58.                 }
  59.         }
  60. }
復制代碼
要是想移植成51單片機的程序,應該注意點什么
求大神講解一下
ID:395176 發(fā)表于 2020-1-2 16:10 | 只看該作者
寄存器注意一下
其他的復制 粘貼
Powered by 單片機教程網
