查看: 2012|回復(fù): 2
單片機四路搶答器
ID:681382 發(fā)表于 2020-1-5 19:16 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg51.h>
#include <intrins.h>
typedef unsigned int u16;
typedef unsigned char u8;
typedef unsigned char uchar;
u8 code smgduan[17]={0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
     0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//ÏÔʾ1~FµÄÖµ
sbit wei1=P2^2;
sbit wei3=P2^3;
sbit wei4=P2^4;
sbit k1=P3^1;
sbit k2=P3^0;
sbit k3=P3^2;
sbit k4=P3^3;
sbit D1=P2^0;
sbit D2=P2^1;
sbit D3=P2^2;
sbit D4=P2^3;
sbit beep=P2^5;
uchar k;
uchar D;
uchar num;
void T0Int_s(void)
TMOD=0x11;
TH0=0x37;  //??50ms????
TL0=0xb0;
ET0=1;
TR0=1;
EA=1;
void delay(u16 i)
while(--i);
void delays(u16 tm)
while(tm--)
delay(248);
  delay(248);
void keypros1()
  if(k1==0)
D1=~D1;
beep=~beep;
delay(100);
  if(k1!=0)
  break;
void keypros2()
if(k2==0)
D2=~D2;
  beep=~beep;
delay(100);
  if(k2!=0)
  break;
void keypros3()
if(k3==0)
D3=~D3;
  beep=~beep;
delay(100);
  if(k3!=0)
  break;
void keypros4()
if(k4==0)
D4=~D4;
  beep=~beep;
delay(100);
  if(k4!=0)
  break;
if(k1==0)
delays(10);
keypros1();
T0Int_s();
while(1);
if(k2==0)
delays(10);
keypros2();
T0Int_s();
  while(1);
  if(k3==0)
delays(10);
keypros3();
T0Int_s();
  while(1);
  if(k4==0)
delays(10);
keypros4();
T0Int_s();
  while(1);
ID:1 發(fā)表于 2020-1-6 01:03 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細(xì)說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
ID:681382 發(fā)表于 2020-4-23 09:14 | 只看該作者
admin 發(fā)表于 2020-1-6 01:03
沒看到有編輯啊
