51單片機(jī)作MP3
步驟很詳細(xì)奧
PLAY鍵播放音樂
FUNC用于在樂取選擇、音量控制、音效控制間切換
PREVIOUS,選取時(shí)下一首,音量控制時(shí)為減小音量,音效控制時(shí)為下一音效
PREVIOUS,選取時(shí)上一首,音量控制時(shí)為增大音量,音效控制時(shí)為上一音效
電路原理圖如下:
2020-2-10 02:10 上傳
- /*C**************************************************************************
- * NAME: main.c
- * Copyright (c) 2003 Atmel.
- * RELEASE: snd1c-refd-nf-4_0_3
- * REVISION: 1.6
- * PURPOSE:
- * This is the demonstration software for T8xC51SND1
- /*_____ I N C L U D E S ____________________________________________________*/
- #include "config.h" /* system definition */
- #include "lib_mcu\c51_drv.h" /* c51 driver definition */
- #include "scheduler.h" /* scheduler definition */
- /*_____ M A C R O S ________________________________________________________*/
- /*_____ D E F I N I T I O N ________________________________________________*/
- Byte code __FIRMWARE_VERSION_STRING[]="@(#) Firmware snd1c-refd-nf-4_0_3 - Atmel Chejudo Player Reference Design\15\12\0$Id: main.c,v 1.6 2002/12/20 12:51:12 ffosse Exp $";
- /*_____ D E C L A R A T I O N ______________________________________________*/
- extern void in_system_prog (void);
- static void main (void);
- /*F**************************************************************************
- * NAME: main
- * PARAMS:
- * return:
- * PURPOSE:
- * Main user routine
- * EXAMPLE:
- * NOTE:
- * REQUIREMENTS:
- void main (void)
- in_system_prog(); /* check ISP execution request */
- Enable_interrupt(); /* global enable */
- #ifdef X2_MODE
- Set_x2_mode();
- #endif
- sch_scheduler_init();
- sch_scheduler(); /* endless scheduler execution */
51單片機(jī)作MP3.rar
(1.22 MB, 下載次數(shù): 31)
2020-2-10 01:27 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
