查看: 4445|回復(fù): 0
單片機(jī)定時(shí)器0的方式1實(shí)現(xiàn)一個(gè)發(fā)光二極管以500ms間隔閃爍,用定時(shí)器1的方式1實(shí)現(xiàn)兩...
ID:717044 發(fā)表于 2020-3-27 17:02 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
定時(shí)器0的方式1實(shí)現(xiàn)一個(gè)發(fā)光二極管以500ms間隔閃爍,用定時(shí)器1的方式1實(shí)現(xiàn)兩位數(shù)碼...
#include <reg51.h>
sbit LED=P1^0;                 //連的是LED
#define MAX_NUM     99         //最大倒計(jì)時(shí)數(shù)
#define SEGPORT     P0         //定義數(shù)碼管連接端口
sbit LE_DUAN = P2^6;           //定義573鎖存使能端口 段鎖存
sbit LE_WEI  = P2^7;           //定義573鎖存使能端口 位鎖存
unsigned char code Seg_Duan[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};   //共陰數(shù)碼管顯示段碼值 0~9
unsigned char code Seg_Wei[]  = {0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};             //數(shù)碼管的位碼,低電平有效。
static uchar second=MAX_NUM,count0,count1;
uchar shiwei;
uchar gewei;
void delay(unsigned int cnt)
while(--cnt);
  TMOD=0x11;
  TH0=(65536-50000)/256;                                //定時(shí)時(shí)間   50ms
  TL0=(65536-50000)%256;
  TH1=(65536-50000)/256;
  TL1=(65536-50000)%256;
  EA=1;
  ET0=1;
  TR0=1;
  ET1=1;
  TR1=1;
  SEGPORT = 0;
  LE_DUAN = 0;
  LE_WEI  = 0;
   shiwei=second/10;                       //數(shù)碼管十位
   gewei=second%10;                        //數(shù)碼管個(gè)位
   SEGPORT=0;                              //清空數(shù)據(jù)
   LE_DUAN=1;                              //段鎖存
   LE_DUAN=0;
   delay(30);
   SEGPORT = Seg_Wei[1];                   //先送位碼值
   LE_WEI = 1;                             //573高電平鎖存
   LE_WEI = 0;
   SEGPORT = Seg_Duan[shiwei];             //再送段碼值
   LE_DUAN = 1;                            //573高電平鎖存
   LE_DUAN = 0;
   delay(300);
   SEGPORT = Seg_Wei[0];                   //先送位碼值
   LE_WEI = 0;
   SEGPORT = Seg_Duan[gewei];              //再送段碼值
   LE_DUAN = 0;
   delay(300);
void tim0(void) interrupt 1    //定時(shí)器0中斷
  count0++;
  if(count0==10)               //50毫秒定時(shí),50*10=500(毫秒)
   count0=0;
   LED=~LED;                  //LED取反
void tim1(void) interrupt 3    //定時(shí)器1中斷
  count1++;
  if(count1==20)              //50毫秒定時(shí),50*20=1000(毫秒)=1(秒)
   count1=0;
   second--;
   if(second==0xff)
   second=MAX_NUM;
作業(yè).rar
31.81 KB, 下載次數(shù): 6, 下載積分: 黑幣 -5
