這是我之前做的一個(gè)單片機(jī)小實(shí)驗(yàn),用STM32和DS18B20實(shí)現(xiàn)人機(jī)交互
具體功能是將溫度數(shù)據(jù)實(shí)時(shí)顯示在LCD屏以及通過(guò)串口傳回PC端,實(shí)現(xiàn)溫度預(yù)警等等
程序源碼:
/*主函數(shù)/*
#include "led.h"
#include "delay.h"
#include "key.h"
#include "sys.h"
#include "lcd.h"
#include "usart.h"
#include "ds18b20.h"
#include "beep.h"
int main(void)
u8 t=0;
u8 len;
short temperature;
BEEP_Init();
delay_init(); //延時(shí)函數(shù)初始化
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置中斷優(yōu)先級(jí)分組為組2:2位搶占優(yōu)先級(jí),2位響應(yīng)優(yōu)先級(jí)
uart_init(9600); //串口初始化為 9600
LED_Init(); //初始化與LED連接的硬件接口
LCD_Init(); //初始化LCD
POINT_COLOR=RED; //設(shè)置字體為紅色
LCD_ShowString(30,50,200,16,16,"WarShip STM32");
LCD_ShowString(30,70,200,16,16,"DS18B20 TEST");
LCD_ShowString(30,90,200,16,16,"ATOM@ALIENTEK");
LCD_ShowString(30,110,200,16,16,"2019/10/17");
while(DS18B20_Init()) //DS18B20初始化
LCD_ShowString(30,130,200,16,16,"DS18B20 Error");
delay_ms(200);
LCD_Fill(30,130,239,130+16,WHITE);
delay_ms(200);
LCD_ShowString(30,130,200,16,16,"DS18B20 OK");
POINT_COLOR=BLUE;//設(shè)置字體為藍(lán)色
LCD_ShowString(30,150,200,16,16,"Temp: . C");
if(t%10==0) //每100ms讀取一次
temperature=DS18B20_Get_Temp();
if(temperature<0)
LCD_ShowChar(30+40,150,'-',16,0); //顯示負(fù)號(hào)
temperature=-temperature; //轉(zhuǎn)為正數(shù)
}else LCD_ShowChar(30+40,150,' ',16,0); //去掉負(fù)號(hào)
LCD_ShowNum(30+40+8,150,temperature/10,2,16); //顯示正數(shù)部分
LCD_ShowNum(30+40+32,150,temperature%10,1,16); //顯示小數(shù)部分
delay_ms(10);
t++;
if(t==20)
t=0;
LED0=!LED0;
if(temperature/10>=27)
printf("%d.%d C溫度過(guò)高\(yùn)r\n$",temperature/10,temperature%10);
LCD_ShowString(30,170,200,16,16,"Warning!!!!");
LCD_ShowString(30,190,200,16,16,"The Temp is too high!");
printf("%d.%d C\r\n$",temperature/10,temperature%10);
LCD_ShowString(30,170,200,16,16," ");
LCD_ShowString(30,190,200,16,16," ");
if(USART_RX_STA)
len=USART_RX_STA&0x3fff;//得到此次接收到的數(shù)據(jù)長(zhǎng)度
printf("\r\n您發(fā)送的消息為:\r\n$");
for(t=0;t<len;t++)
USART1->DR=USART_RX_BUF[t];
while((USART1->SR&0X40)==0);//等待發(fā)送結(jié)束
printf("\r\n\r\n$");//插入換行
USART_RX_STA=0;
BEEP=1;
delay_ms(100);
BEEP=0;
delay_ms(100);
/*DS18B20驅(qū)動(dòng)程序*/
#include "delay.h"
//復(fù)位DS18B20
void DS18B20_Rst(void)
DS18B20_IO_OUT(); //SET PG11 OUTPUT
DS18B20_DQ_OUT=0; //拉低DQ
delay_us(750); //拉低750us
DS18B20_DQ_OUT=1; //DQ=1
delay_us(15); //15US
//等待DS18B20的回應(yīng)
//返回1:未檢測(cè)到DS18B20的存在
//返回0:存在
u8 DS18B20_Check(void)
u8 retry=0;
DS18B20_IO_IN(); //SET PG11 INPUT
while (DS18B20_DQ_IN&&retry<200)
retry++;
delay_us(1);
if(retry>=200)return 1;
else retry=0;
while (!DS18B20_DQ_IN&&retry<240)
retry++;
delay_us(1);
if(retry>=240)return 1;
return 0;
//從DS18B20讀取一個(gè)位
//返回值:1/0
u8 DS18B20_Read_Bit(void)
u8 data;
DS18B20_DQ_OUT=0;
delay_us(2);
DS18B20_DQ_OUT=1;
delay_us(12);
if(DS18B20_DQ_IN)data=1;
else data=0;
delay_us(50);
return data;
//從DS18B20讀取一個(gè)字節(jié)
//返回值:讀到的數(shù)據(jù)
u8 DS18B20_Read_Byte(void)
u8 i,j,dat;
dat=0;
for (i=1;i<=8;i++)
j=DS18B20_Read_Bit();
dat=(j<<7)|(dat>>1);
return dat;
//寫一個(gè)字節(jié)到DS18B20
//dat:要寫入的字節(jié)
void DS18B20_Write_Byte(u8 dat)
u8 j;
u8 testb;
DS18B20_IO_OUT(); //SET PG11 OUTPUT;
for (j=1;j<=8;j++)
testb=dat&0x01;
dat=dat>>1;
if (testb)
DS18B20_DQ_OUT=0; // Write 1
delay_us(2);
DS18B20_DQ_OUT=1;
delay_us(60);
DS18B20_DQ_OUT=0; // Write 0
delay_us(60);
DS18B20_DQ_OUT=1;
delay_us(2);
//開始溫度轉(zhuǎn)換
void DS18B20_Start(void)
DS18B20_Rst();
DS18B20_Check();
DS18B20_Write_Byte(0xcc); // skip rom
DS18B20_Write_Byte(0x44); // convert
//初始化DS18B20的IO口 DQ 同時(shí)檢測(cè)DS的存在
//返回1:不存在
//返回0:存在
u8 DS18B20_Init(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOG, ENABLE); //使能PORTG口時(shí)鐘
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //PORTG.11 推挽輸出
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOG, &GPIO_InitStructure);
GPIO_SetBits(GPIOG,GPIO_Pin_11); //輸出1
DS18B20_Rst();
return DS18B20_Check();
//從ds18b20得到溫度值
//精度:0.1C
//返回值:溫度值 (-550~1250)
short DS18B20_Get_Temp(void)
u8 temp;
u8 TL,TH;
short tem;
DS18B20_Start (); // ds1820 start convert
DS18B20_Rst();
DS18B20_Check();
DS18B20_Write_Byte(0xbe); // convert
TL=DS18B20_Read_Byte(); // LSB
TH=DS18B20_Read_Byte(); // MSB
if(TH>7)
TH=~TH;
TL=~TL;
temp=0; //溫度為負(fù)
}else temp=1; //溫度為正
tem=TH; //獲得高八位
tem<<=8;
tem+=TL; //獲得底八位
tem=(float)tem*0.625; //轉(zhuǎn)換
if(temp)return tem; //返回溫度值
else return -tem;
完整程序在附件里
人機(jī)交互 18B20數(shù)字溫度傳感器.7z
(223.79 KB, 下載次數(shù): 20)
2020-3-29 14:01 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
