- #include "facedetectwnd.h"
- #include "ui_facedetectwnd.h"
- #include <QByteArray>
- #include <QHostAddress>
- #include "FaceDetect.h"
- FaceDetectThr::FaceDetectThr(QObject *parent):
- QThread (parent)
- FaceDetectThr::~FaceDetectThr()
- void FaceDetectThr::run()
- #define MAXLEN int(800*600)
- int size;
- //分配緩存:用于保存接收?qǐng)D片數(shù)據(jù)
- char *buffer = new char[MAXLEN];
- //分配套接字
- QTcpSocket *s = new QTcpSocket;
- // 連接服務(wù)器
- s->connectToHost(QHostAddress("192.168.21.131"), 59999);
- //等連接成功
- if(!s->waitForConnected(~0)){
- goto ERR_STEP;
- //給界面發(fā)生連接成功信號(hào)
- emit sigConnected();
- //死循環(huán)
- while(1){
- char req[]= "clientack";
- //給服務(wù)器發(fā)送請(qǐng)求
- s->write(req, sizeof(req));
- //等待套接字緩存可讀(給服務(wù)器發(fā)送請(qǐng)求后,服務(wù)器收到則采樣一張圖片,回發(fā)客戶端)
- if(s->waitForReadyRead(~0)){
- //讀出4字節(jié)協(xié)議頭:圖片正文的長(zhǎng)度
- s->read((char *)&size, 4);
- int len = size;
- char *p1 = (char *)&len;
- char *p2 = (char *)&size;
- p1[0] = p2[3];
- p1[1] = p2[2];
- p1[2] = p2[1];
- p1[3] = p2[0];
- if(MAXLEN < len){
- goto ERR_STEP;
- //循環(huán)接收l(shuí)en字節(jié)數(shù)據(jù)(不多收也不少收)
- p1 = buffer;
- int pos = len;
- while(pos){
- if(!s->waitForReadyRead(~0)){
- goto ERR_STEP;
- size = int(s->read(p1, pos));
- pos -= size;
- p1 += size;
- qDebug("len = %d, pos=%d\n", len, pos);
- //把接收來(lái)的圖片數(shù)據(jù)裝到字節(jié)數(shù)組
- QByteArray arr;
- arr.append(buffer, len);
- //定義管理圖片的QImage對(duì)象
- QImage img;
- //把字節(jié)數(shù)組中圖片用img對(duì)象管理起來(lái)
- img.loadFromData(arr);
- //把QImage轉(zhuǎn)換成Mat格式
- cv::Mat frame = ::QImage_to_Mat(img);
- //人臉檢測(cè)
- ::detectFaceOpenCV(frame);
- //把Mat轉(zhuǎn)換成QImage
- img = ::Mat_to_QImage(frame);
- //把QImage轉(zhuǎn)換QPixmap
- QPixmap pix = QPixmap::fromImage(img);
- //給界面發(fā)送信號(hào)
- emit sigPixmap(pix);
- ERR_STEP:
- qDebug("線程出錯(cuò)退出");
- delete [] buffer;
- delete s;
- emit sigDisconnected();
- return;
- FaceDetectWnd::FaceDetectWnd(QWidget *parent) :
- QWidget(parent),
- ui(new Ui::FaceDetectWnd)
- ui->setupUi(this);
- //分配一個(gè)接收線程對(duì)象
- detectThr = new FaceDetectThr;
- connect(detectThr, SIGNAL(sigPixmap(QPixmap)),
- this, SLOT(slotRecv(QPixmap)));
- connect(detectThr, SIGNAL(sigConnected()),
- this, SLOT(slotConnected()));
- connect(detectThr, SIGNAL(sigDisconnected()),
- this, SLOT(slotDisconnected()));
- setWindowTitle("智能門崗");
- FaceDetectWnd::~FaceDetectWnd()
- delete ui;
- void FaceDetectWnd::slotConnected()
- setWindowTitle("連接成功");
- ui->pushButton->setEnabled(true);
- void FaceDetectWnd::slotDisconnected()
- setWindowTitle("連接斷開(kāi)");
- ui->pushButton->setText("連接");
- void FaceDetectWnd::slotRecv(QPixmap pix)
- ui->label->setPixmap(pix);
- void FaceDetectWnd::on_pushButton_clicked()
- if("連接" == ui->pushButton->text()){
- ui->pushButton->setText("斷開(kāi)");
- detectThr->start();
- setWindowTitle("連接中...");
- ui->pushButton->setEnabled(false);
- }else{
- detectThr->terminate();
