查看: 1867|回復: 0
STM32F407ZET6串口調(diào)試程序
ID:721429 發(fā)表于 2020-4-3 09:13 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
使用到了串口123,并且可以和HC-05藍牙模塊進行通信,發(fā)送/接收數(shù)據(jù)
單片機源程序如下:
  1. /* Includes ------------------------------------------------------------------*/
  2. #include "main.h"
  3. #include "stm32f4xx.h"
  4. #include "USART.h"
  5. #include "usart3.h"
  6. /** @addtogroup Template_Project
  7.   * @{
  8.   */
  9. /* Private typedef -----------------------------------------------------------*/
  10. /* Private define ------------------------------------------------------------*/
  11. /* Private macro -------------------------------------------------------------*/
  12. /* Private variables ---------------------------------------------------------*/
  13. static __IO uint32_t uwTimingDelay;
  14. RCC_ClocksTypeDef RCC_Clocks;
  15. /* Private function prototypes -----------------------------------------------*/
  16. static void Delay(__IO uint32_t nTime);
  17. /* Private functions ---------------------------------------------------------*/
  18. /**
  19.   * @brief  Main program
  20.   * @param  None
  21.   * @retval None
  22.   */
  23. int main(void)
  24. {
  25.
  26.   char str3[] = "hahahahaha\r\n";
  27.    /*設置Systick為ms級*/
  28.   SysTick_Config(SystemCoreClock/1000-1);
  29.
  30.    /*設置中斷優(yōu)先級占比*/
  31.   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  32.
  33.     /*配置調(diào)試串口*/
  34.    gec_debug(115200);
  35.    usart3_init(9600);
  36.   while (1)
  37.   {
  38.     usart3_send_string(str3);
  39.
  40.   }
  41.
  42. }
  43. /**
  44.   * @brief  Inserts a delay time.
  45.   * @param  nTime: specifies the delay time length, in milliseconds.
  46.   * @retval None
  47.   */
  48. void Delay(__IO uint32_t nTime)
  49. {
  50.   uwTimingDelay = nTime;
  51.   while(uwTimingDelay != 0);
  52. }
  53. /**
  54.   * @brief  Decrements the TimingDelay variable.
  55.   * @param  None
  56.   * @retval None
  57.   */
  58. void TimingDelay_Decrement(void)
  59. {
  60.   if (uwTimingDelay != 0x00)
  61.   {
  62.     uwTimingDelay--;
  63.   }
  64. }
  65. #ifdef  USE_FULL_ASSERT
  66. /**
  67.   * @brief  Reports the name of the source file and the source line number
  68.   *         where the assert_param error has occurred.
  69.   * @param  file: pointer to the source file name
  70.   * @param  line: assert_param error line source number
  71.   * @retval None
  72.   */
  73. void assert_failed(uint8_t* file, uint32_t line)
  74. {
  75.   /* User can add his own implementation to report the file name and line number,
  76.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  77.   /* Infinite loop */
  78.   while (1)
  79.   {
  80.   }
  81. }
  82. #endif
  83. /**
  84.   * @}
  85.   */
  86. /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
復制代碼
STM32串口調(diào)試.7z (94.41 KB, 下載次數(shù): 38)
admin + 50 共享資料的黑幣獎勵!
