查看: 2398|回復(fù): 1
大一的時候做的非常簡單的紅外循跡小車程序
ID:328225 發(fā)表于 2020-4-6 15:28 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
基本是手動調(diào)節(jié)參數(shù),所以很適合入門吧
大佬就別看了,從來沒有接觸過的可以看看,都是非;A(chǔ)的c語言
  1. #include <reg52.h>
  2. #define uint unsigned int
  4. #define left    0
  5. #define right   1
  6. sbit IN1 = P1^0;
  7. sbit IN2 = P1^1;
  8. sbit ENA = P1^2;
  9. sbit IN3 = P1^3;
  10. sbit IN4 = P1^4;
  11. sbit ENB = P1^5;
  12.
  13. sbit left2 = P0^0;
  14. sbit left1 = P0^1;
  15. sbit right1 = P0^2;
  16. sbit right2 = P0^3;
  17. sbit right3 = P0^4;
  18. sbit left3 = P0^5;
  19. sbit  key1=P3^2;
  20.
  21. sbit beep=P3^4;
  22. sbit DOUT=P1^6;
  23. unsigned char zkb1 = 0;
  24. unsigned char zkb2 = 0;
  25. unsigned char t = 0;
  26. unsigned char i,j,a,b;
  27. unsigned char speed=25;
  28. uint flag=0;
  29. unsigned char SignalFlag[2];
  30. void init()
  31. {
  32.     EA = 1;
  33.     TMOD |= 0x01;
  34.     TH0 =(65536 - 100) / 256;
  35.     TL0 = (65536 - 100)% 256;
  36.     ET0 = 1;
  37.     TR0 = 1;
  38. }
  39.
  40. void timer0() interrupt 1
  41. {
  42.
  43.     TH0 = (65536 - 100) / 256;
  44.     TL0 = (65536 - 100) % 256;
  45.
  46.     if(t < zkb1)
  47.     {
  48.         ENA = 1;
  49.     }
  50.     else
  51.     {
  52.         ENA = 0;
  53.     }
  54.     if(t < zkb2)
  55.     {
  56.         ENB =1;
  57.     }
  58.     else
  59.     {
  60.         ENB = 0;
  61.     }
  62.     ++t;
  63.     if(t >= 200)
  64.     {
  65.         t = 0;
  66.     }
  67.
  68.
  69.
  70. }
  71. void delay( uint z)
  72. { uint j;
  73.   while( z--)
  74.   { for(j=110;j>0;j--);}
  75. }
  76.
  77. void turn_left()
  78. {
  79.     zkb1 =29;//15;
  80.     zkb2 =38;
  81.
  82.     IN1 = 1;
  83.     IN2 = 0;
  84.     IN3 = 1;
  85.     IN4 = 0;
  86. }
  87.
  88. void turn_right()
  89. {
  90.     zkb1 = 38;
  91.     zkb2 = 29;//15;
  92.     IN1 = 1;
  93.     IN2 = 0;
  94.     IN3 = 1;
  95.     IN4 = 0;
  96. }
  97. void turn_left1()
  98. {
  99.     zkb1 =12;//15;
  100.     zkb2 =45;
  101.
  102.     IN1 = 1;
  103.     IN2 = 0;  //左輪反轉(zhuǎn)
  104.     IN3 = 1;
  105.     IN4 = 0;
  106. }
  107.
  108. void turn_right1()
  109. {
  110.     zkb1 = 45;
  111.     zkb2 = 12;//15;
  112.     IN1 = 1;
  113.     IN2 = 0;
  114.     IN3 = 1;
  115.     IN4 = 0;
  116. }
  117.   void turn_right2()
  118. {
  119.
  120.     zkb1 =32;//15;
  121.     zkb2 =32;
  122.
  123.     IN1 = 0;
  124.     IN2 = 1;
  125.     IN3 = 1;
  126.     IN4 = 0;
  127.         }
  128.
  129. void turn_left2()
  130. {
  131.     zkb1 = 32;
  132.     zkb2 = 32;//15;
  133.     IN1 = 1;
  134.     IN2 = 0;
  135.     IN3 = 0;
  136.     IN4 = 1;
  137. }
  138. void qianjin()
  139. {
  140.     zkb1 =30;
  141.     zkb2 =30;
  142.           IN1 = 1;
  143.     IN2 = 0;
  144.     IN3 = 1;
  145.     IN4 = 0;
  146. }
  147. void tingzhi()
  148. {
  149.   zkb1 = 0;
  150.         zkb2 = 0;
  151.    delay(250);
  152.
  153. }
  154. void delay1()//延時程序
  155. {
  156. uchar m,n,s;
  157. for(m=20;m>0;m--)
  158. for(n=20;n>0;n--)
  159. for(s=248;s>0;s--);
  160. }
  161. void xunji()
  162. {
  163.     unsigned char flag=0;
  164.     if((right2 == 0)&&(right1 == 0)&&(left1 == 0)&&(left2 == 0)&&(left3 == 0)&&(right3 == 0))
  165.     {
  166.         flag = 0;
  167.     }
  168.     else if(((right2 == 0)&&(right1 ==0)&&(left1 == 1)&&(left2 == 0))&&(left3 == 0)&&(right3 == 0)||((right2 == 0)&&(right1 == 0)&&(left1 == 1)&&(left2 == 1))&&(left3 == 0)&&(right3 == 0))
  169.                 {
  170.         flag = 1;
  171.     }
  172.     else if(((right2 == 0)&&(right1 == 1)&&(left1 == 0)&&(left2 == 0))&&(left3 == 0)&&(right3 == 0)||((right2 == 1)&&(right1 == 1)&&(left1 == 0)&&(left2 == 0))&&(left3 == 0)&&(right3 == 0))
  173.     {
  174.         flag = 2;
  175.     }
  176.     else if((right2 == 1)&&(right1 == 0)&&(left1 == 0)&&(left2 == 0)&&(left3 == 0)&&(right3 == 0))
  177.     {
  178.         flag = 3;
  179.     }
  180.     else if((right2 == 0)&&(right1 == 0)&&(left1 == 0)&&(left2 == 1)&&(left3 == 0)&&(right3 == 0))
  181.     {
  182.         flag = 4;
  183.     }
  184.     else if((right2 == 0)&&(right1 == 0)&&(left1 == 0)&&(left2 == 0)&&(left3 == 0)&&(right3 == 1))
  185.     {
  186.         flag = 5;
  187.     }
  188.     else if((right2 == 0)&&(right1 == 0)&&(left1 == 0)&&(left2 == 0)&&(left3 == 1)&&(right3 == 0))
  189.     {
  190.         flag = 6;
  191.     }
  192.                 else if((right2 == 1)&&(right1 == 1)&&(left1 == 1)&&(left2 == 1))
  193.     {
  194.         flag = 7;
  195.     }
  196.                 else flag=0;
  197.     switch(flag)
  198.     {
  199.         case 0:qianjin();break;
  200.
  201.         case 1:turn_left();break;
  202.
  203.         case 2:turn_right();break;
  204.
  205.         case 3:turn_right1();break;
  206.
  207.         case 4:turn_left1();break;
  208.
  209.         case 5:turn_right2();break;
  210.
  211.         case 6:turn_left2();break;
  212.
  213.         case 7:tingzhi();break;
  214.
  215.         default:qianjin();break;
  216.     }
  217. }
  218.
  219.    void main()
  220. {
  221.     init();
  222.      while(1)
  223.     {
  224.        if (key1==0)
  225.                           {
  226.                                         do
  227.                                   {
  228.                                                 IN1 = 1;
  229.             IN2 = 0;
  230.             IN3 = 0;
  231.             IN4 = 1;
  232.                                                 zkb1 = 27;
  233.             zkb2 = 27;
  234.                                                 beep=1;
  235.           }
  236.                                         while(right3==0);
  237.                                         do
  238.                                         {
  239.                                                 IN1 = 1;
  240.             IN2 = 0;
  241.             IN3 = 1;
  242.             IN4 = 0;
  243.                                                 beep= 1;
  244.                                                 zkb1 = 40;
  245.             zkb2 = 20;
  246.                                         }
  247.                                         while(right1==0);
  248.                                         turn_left1();
  249.                                         delay(220);
  250.                                 }
  251.                                 else
  252.                                 {
  253.                 xunji();
  254.         }
  255. }
  256. }
以上程序51hei提供下載:
xunji.zip (41.62 KB, 下載次數(shù): 17)
ID:1 發(fā)表于 2020-4-6 22:56 | 只看該作者
本帖需要重新編輯補(bǔ)全電路原理圖,源碼,詳細(xì)說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
