查看: 1490|回復(fù): 1
STM32三鍵可調(diào)RTC源程序
ID:620851 發(fā)表于 2020-4-10 23:48 | 顯示全部樓層 |閱讀模式
  1. #include "delay.h"
  2. #include "sys.h"
  3. #include "oled.h"
  4. #include "bmp.h"
  5. #include "usmart.h"
  6. #include "rtc.h"
  7. #include "usart.h"
  8. #include  "key.h"
  9. #include "beep.h"
  10. int main(void)
  11. {
  12.
  13.         u8 t;
  14.         u16 i=0;
  15.         u8 key;
  16.         vu8 time_day=1;
  17.         vu8 time_hour=1;
  18.         vu8 time_min=1;
  19.         init_add();
  20.         Stm32_Clock_Init(9);        //系統(tǒng)時(shí)鐘設(shè)置
  21.         uart_init(72,115200);        //串口初始化為115200
  22.         usmart_dev.init(72);        //初始化USMART
  23. delay_init(72);
  24.         OLED_Init();
  25.         OLED_ColorTurn(0);//0正常顯示,1 反色顯示
  26. OLED_DisplayTurn(0);//0正常顯示 1 屏幕翻轉(zhuǎn)顯示
  27.         KEY_Init();
  28.   BEEP_Init();
  29.         while(RTC_Init())                //RTC初始化        ,一定要初始化成功
  30.         {
  31.
  32.                 OLED_ShowString(8,16,"RTC ERROR!",16);
  33.                 delay_ms(800);
  34.                 OLED_ShowString(8,32,"RTC Trying...",16);
  35.
  36.         }
  37.
  38.         while(1)
  39.         {
  40.
  41.                 end:
  42.                 key=KEY_Scan(0);
  43.
  44.                 if(key)
  45.                 {
  46.                         switch(key)
  47.                         {
  48.                                 case 1://調(diào)時(shí)間
  49.
  50.                                 while(1)
  51.                                 {
  52.                                         key=KEY_Scan(0);
  53.                                           switch(key)
  54.                                          {
  55.                                                  case 1://設(shè)置day
  56.                                                         OLED_Clear();
  57.        while(1)
  58.        {
  59.        delay_ms(1);
  60.        i++;
  61.        OLED_ShowString(16,20,"date:",24);
  62.        if(i<66) OLED_ShowNum(80,20,calendar.w_date+add_calendar.day-1,2,24);
  63.        OLED_Refresh();
  64.        if(i<88&&i>66)
  65.        {
  66.
  67.        OLED_ShowString(80,20,"    ",24);
  68.        OLED_Refresh();
  69.
  70.        }
  71.        if(i>88)i=0;
  72.        key=KEY_Scan(0);
  73.        switch(key)
  74.        {
  75.
  76.        case 1: goto end;
  77.
  78.        case 2: add_calendar.day++;
  79.
  80.        RTC->CRL|=1<<4;           //允許配置
  81.        RTC_Set(calendar.w_year,calendar.w_month,calendar.w_date+add_calendar.day-1,calendar.hour+add_calendar.hour-1,
  82.        calendar.min+add_calendar.min-1,calendar.sec);
  83.        RTC->CRL&=~(1<<4);           //配置更新
  84.        init_add();
  85.        break;
  86.        case 3:
  87.        add_calendar.day--;
  88.
  89.        RTC->CRL|=1<<4;           //允許配置
  90.        RTC_Set(calendar.w_year,calendar.w_month,calendar.w_date+add_calendar.day-1,calendar.hour+add_calendar.hour-1,
  91.        calendar.min+add_calendar.min-1,calendar.sec);
  92.        RTC->CRL&=~(1<<4);           //配置更新
  93.        init_add();
  94.        break;
  95.        }
  96.        }
  97.                                                 case 2://設(shè)置hour
  98.                                                         OLED_Clear();
  99.        while(1)
  100.        {
  101.        delay_ms(1);
  102.        i++;
  103.        OLED_ShowString(16,20,"hour:",24);
  104.        if(i<66) OLED_ShowNum(80,20,calendar.hour+add_calendar.hour-1,2,24);
  105.        OLED_Refresh();
  106.        if(i<88&&i>66)
  107.        {
  108.
  109.        OLED_ShowString(80,20,"    ",24);
  110.        OLED_Refresh();
  111.
  112.        }
  113.        if(i>88)i=0;
  114.        key=KEY_Scan(0);
  115.        switch(key)
  116.        {
  117.
  118.        case 1:
  119.        add_calendar.hour++;
  120.
  121.        RTC->CRL|=1<<4;           //允許配置
  122.        RTC_Set(calendar.w_year,calendar.w_month,calendar.w_date+add_calendar.day-1,calendar.hour+add_calendar.hour-1,
  123.        calendar.min+add_calendar.min-1,calendar.sec);
  124.        RTC->CRL&=~(1<<4);           //配置更新
  125.        init_add();
  126.        break;
  127.        case 2: goto end;
  128.
  129.        case 3:
  130.        add_calendar.hour--;
  131.
  132.        RTC->CRL|=1<<4;           //允許配置
  133.        RTC_Set(calendar.w_year,calendar.w_month,calendar.w_date+add_calendar.day-1,calendar.hour+add_calendar.hour-1,
  134.        calendar.min+add_calendar.min-1,calendar.sec);
  135.        RTC->CRL&=~(1<<4);           //配置更新
  136.        init_add();
  137.        break;
  138.        }
  139.        }
  140.
  141.                                                 case 3://設(shè)置min
  142.                                                         OLED_Clear();
  143.        while(1)
  144.        {
  145.        delay_ms(1);
  146.        i++;
  147.        OLED_ShowString(16,20,"min:",24);
  148.        if(i<66) OLED_ShowNum(80,20,calendar.min+add_calendar.min-1,2,24);
  149.        OLED_Refresh();
  150.        if(i<88&&i>66)
  151.        {
  152.
  153.        OLED_ShowString(80,20,"    ",24);
  154.        OLED_Refresh();
  155.
  156.        }
  157.        if(i>88)i=0;
  158.        key=KEY_Scan(0);
  159.        switch(key)
  160.        {
  161.        case 1:
  162.        add_calendar.min++;
  163.
  164.        RTC->CRL|=1<<4;           //允許配置
  165.        RTC_Set(calendar.w_year,calendar.w_month,calendar.w_date+add_calendar.day-1,calendar.hour+add_calendar.hour-1,
  166.        calendar.min+add_calendar.min-1,calendar.sec);
  167.        RTC->CRL&=~(1<<4);           //配置更新
  168.        init_add();
  169.        break;
  170.        case 2:
  171.        add_calendar.min--;
  172.
  173.        RTC->CRL|=1<<4;           //允許配置
  174.        RTC_Set(calendar.w_year,calendar.w_month,calendar.w_date+add_calendar.day-1,calendar.hour+add_calendar.hour-1,
  175.        calendar.min+add_calendar.min-1,calendar.sec);
  176.        RTC->CRL&=~(1<<4);           //配置更新
  177.        init_add();
  178.        break;
  179.        case 3: goto end;
  180.        }
  181.        }
  182.
  183.                                                 default: break;
  184.
  185.                                           }
  186.                                         }
  187.                                 case 2://調(diào)鬧鐘
  188.          while(1)
  189.                                  {
  190.                                 key=KEY_Scan(0);
  191.                                           switch(key)
  192.                                          {
  193.                                                  case 1://設(shè)置day
  194.                                                         OLED_Clear();
  195.        while(1)
  196.        {
  197.        delay_ms(1);
  198.        i++;
  199.        OLED_ShowString(16,20,"date:",24);
  200.        if(i<66) OLED_ShowNum(80,20,calendar.w_date+time_day-1,2,24);
  201.        OLED_Refresh();
  202.        if(i<88&&i>66)
  203.        {
  204.
  205.        OLED_ShowString(80,20,"    ",24);
  206.        OLED_Refresh();
  207.
  208.        }
  209.        if(i>88)i=0;
  210.        key=KEY_Scan(0);
  211.        switch(key)
  212.        {
  213.
  214.        case 1: goto end;
  215.
  216.        case 2: time_day++;
  217.
  218.        RTC->CRL|=1<<4;           //允許配置
  219.        RTC_Alarm_Set(calendar.w_year,calendar.w_month,calendar.w_date+time_day-1,calendar.hour+time_hour-1,
  220.        calendar.min+time_min-1,calendar.sec);
  221.        RTC->CRL&=~(1<<4);           //配置更新
  222.        time_day=1;
  223.        time_hour=1;
  224.        time_min=1;
  225.        break;
  226.        case 3:
  227.        time_day--;
  228.
  229.        RTC->CRL|=1<<4;           //允許配置
  230.        RTC_Alarm_Set(calendar.w_year,calendar.w_month,calendar.w_date+time_day-1,calendar.hour+time_hour-1,
  231.        calendar.min+time_min-1,calendar.sec);
  232.        RTC->CRL&=~(1<<4);           //配置更新
  233.        time_day=1;
  234.        time_hour=1;
  235.        time_min=1;
  236.        break;
  237.        }
  238.        }
  239.                                                 case 2://設(shè)置hour
  240.                                                         OLED_Clear();
  241.        while(1)
  242.        {
  243.        delay_ms(1);
  244.        i++;
  245.        OLED_ShowString(16,20,"hour:",24);
  246.        if(i<66) OLED_ShowNum(80,20,calendar.hour+time_hour-1,2,24);
  247.        OLED_Refresh();
  248.        if(i<88&&i>66)
  249.        {
  250.
  251.        OLED_ShowString(80,20,"    ",24);
  252.        OLED_Refresh();
  253.
  254.        }
  255.        if(i>88)i=0;
  256.        key=KEY_Scan(0);
  257.        switch(key)
  258.        {
  259.
  260.        case 1:
  261.        time_hour++;
  262.
  263.        RTC->CRL|=1<<4;           //允許配置
  264.        RTC_Alarm_Set(calendar.w_year,calendar.w_month,calendar.w_date+time_day-1,calendar.hour+time_hour-1,
  265.        calendar.min+time_min-1,calendar.sec);
  266.        RTC->CRL&=~(1<<4);           //配置更新
  267.        time_day=1;
  268.        time_hour=1;
  269.        time_min=1;
  270.        break;
  271.        case 2: goto end;
  272.
  273.        case 3:
  274.        add_calendar.hour--;
  275.
  276.        RTC->CRL|=1<<4;           //允許配置
  277.        RTC_Alarm_Set(calendar.w_year,calendar.w_month,calendar.w_date+time_day-1,calendar.hour+time_hour-1,
  278.        calendar.min+time_min-1,calendar.sec);
  279.        RTC->CRL&=~(1<<4);           //配置更新
  280.        time_day=1;
  281.        time_hour=1;
  282.        time_min=1;
  283.        break;
  284.        }
  285.        }
  286.
  287.                                                 case 3://設(shè)置min
  288.                                                         OLED_Clear();
  289.        while(1)
  290.        {
  291.        delay_ms(1);
  292.        i++;
  293.        OLED_ShowString(16,20,"min:",24);
  294.        if(i<66) OLED_ShowNum(80,20,calendar.min+time_min-1,2,24);
  295.        OLED_Refresh();
  296.        if(i<88&&i>66)
  297.        {
  298.
  299.        OLED_ShowString(80,20,"    ",24);
  300.        OLED_Refresh();
  301.
  302.        }
  303.        if(i>88)i=0;
  304.        key=KEY_Scan(0);
  305.        switch(key)
  306.        {
  307.        case 1:
  308.        time_min++;
  309.
  310.        RTC->CRL|=1<<4;           //允許配置
  311.        RTC_Alarm_Set(calendar.w_year,calendar.w_month,calendar.w_date+time_day-1,calendar.hour+time_hour-1,
  312.        calendar.min+time_min-1,calendar.sec);
  313.        RTC->CRL&=~(1<<4);           //配置更新
  314.        time_day=1;
  315.        time_hour=1;
  316.        time_min=1;
  317.        break;
  318.        case 2:
  319.        time_min--;
  320.        RTC->CRL|=1<<4;           //允許配置
  321.        RTC_Alarm_Set(calendar.w_year,calendar.w_month,calendar.w_date+time_day-1,calendar.hour+time_hour-1,
  322.        calendar.min+time_min-1,calendar.sec);
  323.        RTC->CRL&=~(1<<4);          //配置更新
  324.        time_day=1;
  325.        time_hour=1;
  326.        time_min=1;
  327.        break;
  328.        case 3: goto end;
  329.        }
  330.        }
  331.
  332.                                                 default: break;
  333.                                 }
  334.                         }
  335.                         default: break;
  336.                         }
  337.                 }
  338. //鬧鐘設(shè)置
  339. //                RTC->CRL|=1<<4;           //允許配置
  340. //                RTC_Alarm_Set(2020,4,3,12,25,00);
  341. //                RTC->CRL&=~(1<<4);           //配置更新
  342. //
  343. ……………………
  344. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
三鍵可調(diào)RTC1.0.7z
121.5 KB, 下載次數(shù): 10, 下載積分: 黑幣 -5
ID:1 發(fā)表于 2020-4-11 13:36 | 顯示全部樓層
本帖需要重新編輯補(bǔ)全電路原理圖,源碼,詳細(xì)說(shuō)明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
