查看: 1359|回復: 0
數(shù)碼管顯示矩陣鍵盤數(shù)字 單片機程序
ID:582536 發(fā)表于 2020-4-19 14:51 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>     //????????????P0?ο??P1λ??//
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
sbit k1=P3^4;
sbit k2=P3^5;
sbit k3=P3^6;
sbit k4=P3^7;
void delayms(uint);
void display(uchar);
void mkcan();
uchar num;
P0=0x00;
P1=0x00;
     mkcan();
void delayms(uint xms)       //???//
uint i,j;
for(i=xms;i>0;i--)
  for(j=100;j>0;j--);
void mkcan()
uchar temp,k;
P3=0xfe;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
  delayms(10);
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
   temp=P3;
   switch(temp)
    case 0xee:
     k=0;
     break;
    case 0xde:
     k=1;
     break;
    case 0xbe:
     k=2;
     break;
    case 0x7e:
     k=3;
     break;
  while(temp!=0xf0)
   temp=P3;
   temp=temp&0xf0;
  display(k);
P3=0xfd;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
  delayms(10);
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
   temp=P3;
   switch(temp)
    case 0xed:
     k=4;
     break;
    case 0xdd:
     k=5;
     break;
    case 0xbd:
     k=6;
     break;
    case 0x7d:
     k=7;
     break;
  while(temp!=0xf0)
   temp=P3;
   temp=temp&0xf0;
  display(k);
P3=0xfb;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
  delayms(10);
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
   temp=P3;
   switch(temp)
    case 0xeb:
     k=8;
     break;
    case 0xdb:
     k=9;
     break;
    case 0xbb:
     k=10;
     break;
    case 0x7b:
     k=11;
     break;
  while(temp!=0xf0)
   temp=P3;
   temp=temp&0xf0;
  display(k);
P3=0xf7;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
  delayms(10);
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
   temp=P3;
   switch(temp)
    case 0xe7:
     k=12;
     break;
    case 0xd7:
     k=13;
     break;
    case 0xb7:
     k=14;
     break;
    case 0x77:
     k=15;
     break;
  while(temp!=0xf0)
   temp=P3;
   temp=temp&0xf0;
  display(k);
void display(uchar num)
  P0=table[num];
