查看: 1616|回復: 0
求大神幫忙解決一下下面的單片機程序代表的含義
ID:687931 發(fā)表于 2020-4-30 16:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg51.h>
#define uchar  unsigned char
#define uint   unsigned int
#define ulong   unsigned long
uchar code zifx0[]="0123456789abcdef";
uchar code zifu0[]="Now Number:0000";
uchar code zifu1[]="Set Number:9999";
sbit  RS=P3^1; //д???
sbit  RWW=P3^3; //?????
sbit  E=P3^4;   //??????
#define e1   E=1
#define rd1  RWW=1
#define rs1  RS=1
#define e0   E=0
#define rd0  RWW=0
#define rs0  RS=0
#define PP P1
//???????ms
void _delay_ms(uint t)
   uint i,j;
   for(i=0;i<t;i++)
     for(j=0;j<120;j++);
//???????us
void _delay_us(uchar t)
   while(t>0)t--;
//д1602??????
void  lcd1602_writecrtl(uchar  dat)
  rd0;//???????0
  rs0;//д?????0
  _delay_us(5);
  PP=dat;
  e1;//????????1
  _delay_us(5);
  e0;//????????0
//д1602????
void  lcd1602_writenumber(uchar dat)
  rd0;//???????0
  rs1;//д?????1
  _delay_us(5);
  PP=dat;
  e1;//????????1
  _delay_us(5);
  e0;//????????0
//1602?????
void  lcd1602_init()
  lcd1602_writecrtl(0x38); //?????
  lcd1602_writecrtl(0x06); //?????????λ??
  lcd1602_writecrtl(0x0c); //??????????????
  lcd1602_writecrtl(0x01); //???????
void  lcd1602_adr(uchar dat)
  lcd1602_writecrtl(0x80 | dat);
void LCD1602_string(uchar hang,uchar lie,uchar const *p)
uchar a;
if(hang == 1) a = 0x00;
if(hang == 2) a = 0x40;
a = a + lie - 1;
lcd1602_adr(a);
  if(*p == '\0') break;
  lcd1602_writenumber(*p);
  p++;
uint  keyn1=16;//?????
uint  keyn=16;//????
#define PK P2
void key_z()
PK=0X0F;
if(!(PK==0X0F))
    if(!(PK==0X0F))
    keyn1=0;
    keyn=0;
    PK=0X0F;
    if(PK==0X0E)  keyn1=0;
    if(PK==0X0D)  keyn1=1;
    if(PK==0X0B)  keyn1=2;
    if(PK==0X07)  keyn1=3;
    PK=0XF0;
    if(PK==0XE0)  keyn=0+keyn1;
    if(PK==0XD0)  keyn=4+keyn1;
    if(PK==0XB0)  keyn=8+keyn1;
    if(PK==0X70)  keyn=12+keyn1;
    switch(keyn)
     case 0: keyn1=1; break;
     case 4: keyn1=2; break;
     case 8: keyn1=3; break;
     case 12:keyn1=10; break;
     case 1: keyn1=4; break;
     case 5: keyn1=5; break;
     case 9: keyn1=6; break;
     case 13:keyn1=11; break;
     case 2: keyn1=7; break;
     case 6: keyn1=8; break;
     case 10:keyn1=9;break;
     case 14:keyn1=12;break;
   case 3: keyn1=14;break;//*
     case 7: keyn1=0;break;
     case 11:keyn1=15;break;//#
     case 15:keyn1=13;break;
  else   keyn1=16;
  PK=0X0F;while((!(PK==0X0F)));
}//LED
sbit led1=P0^0;
sbit beer=P3^5;
sbit out=P3^6;
sbit k1=P3^7;
sbit P32=P3^2;
uint  now=0;
uint  set=10;
uint  bzbu=0;//????
uint  bz=0;//??
uint  qidong=0;//????
void dis()
  //now
  lcd1602_adr(0x0B);
  lcd1602_writenumber(0x30+now%10000/1000);
  lcd1602_writenumber(0x30+now%1000/100);
  lcd1602_writenumber(0x30+now%100/10);
  lcd1602_writenumber(0x30+now%10);
  //set
  lcd1602_adr(0x4B);
  lcd1602_writenumber(0x30+set%10000/1000);
  lcd1602_writenumber(0x30+set%1000/100);
  lcd1602_writenumber(0x30+set%100/10);
  lcd1602_writenumber(0x30+set%10);
  if(bz==0)lcd1602_writenumber(' ');
  if(bz==1)lcd1602_writenumber('<');
  if(bz==0)
    if(k1==0){qidong=(qidong+1)%2;if(qidong==1){led1=0;;out=0;}else {led1=1;out=1;}while(k1==0);}
  if(qidong==1)
    if(now>=set){qidong=0;led1=1;out=1;beer=0;_delay_ms(500);  }
  if(qidong==0)
    beer=1;
void key()
  key_z();
  if(keyn1<16)
   if((keyn1<10)&&(bz==1))
  if(bzbu==0){set=keyn1;}
  if(bzbu==1){set=set*10+keyn1;}
  if(bzbu==2){set=set*10+keyn1;}
  if(bzbu==3){set=set*10+keyn1;}
  bzbu=(bzbu+1)%4;
if((keyn1==0x0a)&&(bz==0)){now=0;}//??λ
if((keyn1==0x0b)&&(bz==1)){set=0;}//??λ????
if((keyn1==0x0c)&&(qidong==0)){bz=1;}//????
if(keyn1==0x0d){bz=0;}//???
keyn1=16;
  _delay_us(10);
  _delay_ms(10);
  //?ж?????
  IT0=1;
  EX0=1;
  EA=1;
  lcd1602_init();
  LCD1602_string(1,1,zifu0);
  LCD1602_string(2,1,zifu1);
   dis(); //???
   key();
//INT0?ж????
void  EX_INT0() interrupt 0
if(qidong==1)
  _delay_ms(3);if(P32==0)now=now+1;
