為什么我想修改第一行的年月日,按下y1,光標(biāo)直接跳到第二行上不來了,控制年月日的按鍵都沒用,請教大佬們要怎么修改, 謝謝
單片機源程序如下:
#include<reg52.h>
sbit en=P3^4;
sbit rs=P3^5;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P2^0;
sbit s4=P2^1;
sbit dula=P2^6;
sbit wela=P2^7;
sbit y1=P3^3;
sbit y2=P2^2;
sbit y3=P2^4;
char shi,fen,miao;//char??-128~127
char nian,yue,ri;
uchar count,s1num,y1num; //uchar??0~255
uchar code table[]=" 2020-05-03 SUN";
uchar code table1[]=" 00:00:00";
void write_com(uchar com);
void write_date(uchar date);
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
rs=0;
en=0;
P0=com;
delay(5);
en=1;
delay(5);
en=0;
rs=1;
en=0;
P0=date;
delay(5);
en=1;
delay(5);
en=0;
void init()
uchar num;
dula=0;
wela=0;
num=0;
en=0;
TMOD=0X01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<16;num++)
write_date(table[num]);
delay(5);
write_com(0x80+0x40);
for(num=0;num<12;num++)
write_date(table1[num]);
delay(5);
void write_nyr(uchar add1,uchar date1)
uchar shi1,ge1;
shi1=date1/10;
ge1=date1%10;
write_com(0x80+add1);
write_date(0x30+shi1);
write_date(0x30+ge1);
void write_sfm(uchar add,uchar date)//?????????
{ uchar shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void keyscan()
if(y1==0)
delay(5);
if(y1==0)
y1num++;
while(!y1);
if(y1num==1)
write_com(0x80+0+11);
write_com(0x0f);
if(y1num==2)
write_com(0x80+0+8);
if(y1num==3)
write_com(0x80+0+5);
if(y1num!=0)
if(y2==0)
delay(5);
if(y2==0)
while(!y2);
if(y1num==1)
ri++;
if(ri==30)
ri=0;
write_nyr(12,ri);
write_com(0x80+0+12);
if(y1num==2)
yue++;
if(yue==12)
yue=0;
write_nyr(9,yue);
write_com(0x80+0+9);
if(y1num==3)
nian++;
if(nian==99)
nian=0;
write_nyr(6,nian);
write_com(0x80+0+6);
if(y3==0)
delay(5);
if(y3==0)
while(!y3);
if(y1num==1)
ri--;
if(ri==-1)
ri=30;
write_nyr(12,ri);
if(y1num==2)
yue--;
if(yue==-1)
yue=12;
write_nyr(9,yue);
if(y1num==3)
nian--;
if(nian==-1)
nian=30;
write_nyr(6,nian);
init();
keyscan();
void timer0() interrupt 1
count++;
if(count==20)
count=0;
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
write_sfm(7,fen);
write_sfm(10,miao);
